May 14, 2024, 11:00:22 PM *
Author Topic: Viking 2  (Read 17775 times)
Kg6idr
« on: December 26, 2015, 12:59:34 PM »
Hi all, I just picked up a Viking 2 last week that's in beautiful condition . It has very little grid current 2 mills until I turn the drive to 9.  Than there is 7/8 mils of current. There are mods instead of 6au6's there are 12ax7's driving a 6cl6. , 807's to 6146 . I made a mistake trying to tune and had the drive to far and plate current and took out the 5v4ca  rectifer . This is mated to a HRO 50t ,also the Viking has a trans relay the coax to the back  of the case and one that plugs into the two small holes at the bottom. This is my first AM transmitter and I don't want destroy it.
« Reply #1 on: December 26, 2015, 01:11:47 PM »
L,
Welcome back.
You may want to search through this forum to bring you up to speed.
Do you have the manual?? If not, try this.......
http://bama.edebris.com/manuals/johnson/viking2(2)
 The first thing I would do is to add a fuse to the LV power supply, along with a 3 prong power cord to this beast.
gud luck,
kd1nw
« Reply #2 on: December 26, 2015, 03:47:30 PM »
Hi,
I'm working on a Viking II also. Page 23 Section 6b suggests checking your buffer or osc tube. Feel free to email me at kd1nw yahoo.com
Good luck with your V2!
73 Kevin KD1NW
Kg6idr
« Reply #3 on: December 31, 2015, 12:45:47 AM »
So I had another 5v4ga that had the tit broken off but was marked . So I am back to where I was. All tubes test good . Does anyone know about the mods whit the 12ax7s in ace of the 6au6s in v 1 v2 and the 6cl6 in v5 in place of the 6aq5 ?
« Reply #4 on: December 31, 2015, 01:59:46 AM »
I would not consider any mods until you get the transmitter up and running per the factory specs. You may not need any mods. My Viking II has been running stock since 1954 and with some of the original tubes.
« Reply #5 on: December 31, 2015, 08:03:57 AM »
I think the radio has already been modified.
You might think about making it stock, or rather use the stock tubes.
Otherwise you would need to trace out everything and draw a diagram so you know what is going on.
The mods that were done MAY be improvements, or not, but something is not working right.
Test all the resistors and pots, maybe the drive pot is bad or its an audio taper.
Check voltages on tubes.
What are you using, vfo or xtals?
Why do they call it a Viking 2 anyway?
N8ETQ
Mort
« Reply #6 on: December 31, 2015, 08:50:35 AM »
http://amfone.net/Amforum/index.php?topic=10006
/Dan
« Reply #7 on: December 31, 2015, 09:50:00 AM »
Agree.  Get it running FB before doing anything else
Happy New Year all, Al
W4RFM
« Reply #8 on: December 31, 2015, 11:44:29 AM »
I know a lot of people changed the front end of the audio section and installed a 12AX7, you might Google Viking II audio mods, I think that is how I found it several years ago.
« Reply #9 on: December 31, 2015, 12:31:40 PM »
The mod your talking about is a popular one.  The stock Viking 2's or 1's for that matter do not have a lot of mic gain. If you use a mic that has not that great output level, you will run out of mic gain.   The most popular one is replacing the first audio stage with a 12AX7 which give the transmitter more mic gain.
I would go by the manual tune up procedure and see how things turn out.  The manual is your friend!  Just going blindly into one of these transmitters is creating a disaster waiting to happen.
Some mods are good!  So wee what you have and go from there.
Have fun and be safe.
Joe-W3GMS
« Reply #10 on: December 31, 2015, 01:52:25 PM »
Yes, I see the one and the two, but why Viking?
I thought everything Johnson made was a Viking/
Viking ranger, Viking Valiant, Viking 500.
Was there a Viking 0 (zero)?
Or was a Viking 1 the first transmitter they ever built?
Why call it a Viking 1 then?
/Dan
« Reply #11 on: December 31, 2015, 02:12:37 PM »
/Dan
Maybe the product and/or the marketing manager for the product line was of Norse origin.
You can also investigate why Heathkit named a number of their receivers and transmitters after Indian names.  Cheesy
Why do some manufacturers (Hallicrafters, Gonset, Ten-Tec, etc.) use model numbers and a "unique" name to identify their models.
All of this is obviously a task for people who have lots of time on their hands.
W9ZSL
« Reply #12 on: December 31, 2015, 02:33:56 PM »
Manufactured in Minnesota as in the Minnesota Vikings who probably will kill the Packers Sunday night?  The founder was named Johnson which is Scandahoovian.  They had a mail order radio parts company in the '20s.  They built a lot of police communication gear and their entire manufacturing output went to the government during WW2.  The first ham transmitter was the Viking 1 made in 1949.
« Reply #13 on: December 31, 2015, 03:28:45 PM »
Ok, but why Viking 1 if it was the first transmitter, I would think it would just be the new Johnson Viking transmitter.
w8khk
Online Online
« Reply #14 on: December 31, 2015, 03:33:06 PM »
I believe it was originally just called  "Viking" by Johnson.  But after the Viking 2 came out, people referred to it as the Viking 1 to differentiate it from the newer model.
« Reply #15 on: December 31, 2015, 04:12:46 PM »
As far as I can find, it was always labeled as a Viking 1 in the product brochures and on the 3 original manuals I have.
However, the original Viking Ranger was never labeled as a "Ranger I". It was just called a "Ranger". Likewise with the original Valiant. They weren't labelled Valiant I. Moving forward, we eventually had a Ranger II and a Valiant II.
Lots of useless info here, but great info for cocktail parties as fill in information when the conversation gets bogged down.
W9ZSL
« Reply #16 on: December 31, 2015, 04:13:11 PM »
Actually if you look at pictures of this particular xtr, the front decal actually says Johnson Viking 1 so they must have had a model 2 in the works or planning stage from the get-go.
w8khk
Online Online
« Reply #17 on: December 31, 2015, 04:21:57 PM »
As far as I can find, it was always labeled as a Viking 1 in the product brochures and on the 3 original manuals I have.  snip...
Thanks for correcting me, Pete.   Sometimes when voicing an assumption, I learn the facts quickly from the folks on the forum.  I have had a Viking II for years, but never looked closely at the predecessor.
« Reply #18 on: December 31, 2015, 04:25:02 PM »
Probably after they used up all their surplus procured 4D32's. Someone once told me that in the mature life cycle of the Viking I, they actually started producing these transmitters with 6146's. Johnson probably also saw the money value in producing hardened versions of the original design with the Viking II and the CD version.
« Reply #19 on: December 31, 2015, 07:13:06 PM »
There was a kit that allowed Viking 1 users to substitute the 829B.  Here's one resource link:
http://www.boatanchors.org/viking1.htm
Another link: see W1BKZ's comments.  Coincidentally, Peter knew the same W1AVP that I knew back in the 50's who owned a Viking 1  Peter's Viking 1 came with the 829B mod
http://www.eham.net/reviews/detail/4702
Also from this forum:
http://amfone.net/Amforum/index.php?topic=26700.0
As a kid (15 yrs old) I dreamed of owning a V1 and finally got one.  It is now residing at Steve's QIX lab for some experimentation.
I am currently working on a V2 that looks in pretty good condition
Al
WB4AM
« Reply #20 on: December 31, 2015, 10:59:51 PM »
Hello,
Does anyone have an explanation of this transmitter?
It says it is a Viking 2 yet it looks like a Viking 1 yet again it has the insides of a Viking 2.
I have a Viking 1 and a Viking 2 plus this one.  I have only used the Viking 2 the one with the original case that does not have the top lid.  So I don't know how they perform against one another.
Ken
« Reply #21 on: January 01, 2016, 12:23:16 AM »
Is this question relevant to OP's problem?  Huh
« Reply #22 on: January 01, 2016, 12:29:03 AM »
As Pete alluded to, the major difference is the Viking I uses a single 4D32 final, whereas the Viking II has a pair of 6146's.
I own both a Viking I and a Viking II-CDC. I just wish the Viking II-CDC had the 4D32 final.
Just got finished tonight rebuilding a Viking Valiant for a guy  - What a monster; lots of iron and real blue-glow  Cheesy  gas rectifiers and regulators. Three- 6146's as finals.
Happy New Year from:
* QSL CARD.pdf (179.35 KB - downloaded 219 times.)
« Reply #23 on: January 01, 2016, 03:24:46 AM »
Hello,
Ken
Early version of the Viking II using the cabinet from the Viking I. Design changed over to 6146's but if you still have a bunch of Viking I cabinets, why not use them. Silk screen a new front panel with the Viking II designation. I also suspect the later cabinet design was done to provide better TVI shielding and move towards Federal Civil Defense Administration (FCDA) compliance.
« Reply #24 on: January 01, 2016, 09:11:17 AM »
If the drive control rotation suddenly increases the drive from 2 to 8mA, could it be open? It is a large 25K pot to the screen of the driver.
