May 08, 2024, 08:58:09 AM *
Author Topic: Think I will convert an old cb radio.....  (Read 27360 times)
kc4umo
« on: October 28, 2015, 08:30:06 AM »
So I have been looking for another project to start on.  Been listening to 10 meters and hearing quite a bit of activity in this area on AM. While doing a bit of shop cleaning I ran across an old radio I used to love talking on 20 years ago.  Remembering back in the day how great the AM audio was on this radio I got to thinking. This should be an easy conversion to 10 meters.  The radio I am talking about is the Tram D201 23 channel cb radio.  It is an all tube rig, uses a 6L6GC in the audio circuit, and has a VFO.
I am going to go through this old radio and give her a try on 10 meters.  Already did a little surgery and got it up on 28.350 without much trouble. I have not talked on a cb radio in over 20 years but I do collect a lot of them. And have some that I bout 40 plus years ago.
Going to give this a shot and may even do some YouTube vids on it.
« Reply #1 on: October 28, 2015, 08:39:05 AM »
That was a dream radio back in the day, along with the high end cobra console later on.
When I got into radio in the 60's CB was a normal radio service, no trash talk.
All the good radios were tube radios.
kc4umo
« Reply #2 on: October 28, 2015, 08:50:43 AM »
Agree with all of that.  I have a few other vintage ones. Browning Mark 3, Sonar 23, Johnson 223.
I think the Tram would be the best for this modification.  VFO is more stable than the Brownings were.
« Reply #3 on: October 28, 2015, 09:06:43 AM »
That's why many of us went with the Siltronix VFOs on the Brownings. The Mark 3 had a really hot receiver and with the Siltronix slider it was a great 11/10meter receiver.
Search the CB sites on the web for tons of info on converting the Tram into the "upper channels"!
kc4umo
« Reply #4 on: October 28, 2015, 09:35:08 AM »
Yep. The mark 3 I have was given to me after a freind passed away 13 years ago. He ran a cb shop for 30 years and I worked there part time. This particular radio was kept on a top shelf in the front room. There was a gas heater on the wall and the heat was insane in the cieling. Every crystal in the transmitter was bad but one. Perhaps the heat help age them further. Any way I put a Siltronix VFO on it and it has sat on a shelf in my store room ever since.
A guy names Ray Phelps in Elkin NC has a conversion he does to these radios so the receiver and transmitter tracks off the VFO and does away with the crystal side. I called and inquired about it but he will not give the information away. He gladly do it for the sum of 150 bucks  Shocked
I dabbled in cb back in the day and still have tons of mods,books, tubes and parts. Just hate seeing these sit there and do nothing. Thought about converting one to 40 meters one day. But that is for another topic.
« Reply #5 on: October 28, 2015, 10:11:43 AM »
I have Sams cb photofacts 1-25 available for sale .... these cover the early ones ....want to sell as a group
moderators please let sit here for a couple of days before moving ...thanks
WA2SQQ
« Reply #6 on: October 28, 2015, 10:13:26 AM »
I've always had three radios that I'd like to put on 10 AM - Browning Eagle, Demco Satellite, or an original Tram Titan.
Yes, in the day they were status symbols!
« Reply #7 on: October 28, 2015, 10:44:56 AM »
My first real radio over 100mw was a Lafayette mobil rig, solid state, no meters or knobs other then the usual three, but friends had a Kriss tube job with meters and all kinds of knobs, tunable receive, mic gain and everything. Way over my lawn mowing for $3.50 each job budget.
There was a cobra that had more knobs then the Gemini spacecraft I think.
WA2SQQ
« Reply #8 on: October 28, 2015, 11:54:59 AM »
A few of the early 23 channel Lafayette radios were made by Hammarlund. I'm in the process of restoring my "roots" radio, and HB-444-25A. That where my radio addiction all started in the 60's! Still got my original '67 Lafayette catalog in the "john" as reading material!
« Reply #9 on: October 28, 2015, 12:09:07 PM »
I've done this.   Kept the 6l6gc in the final,  changed the audio output to a KT88 in  23 channel version,  and in 40 you must use an earlier tube  (I'll have to check,  but  envelope was smaller.   The longer channel selector board made the smaller envelope tube a necessity).
Once all was said and done,  I got very good audio response,  more positive peaks than I knew what to do with,  and a good running radio.
12 watts carrier is about to max.  50 to 55 peak was normal.
The negative bias supply is nothing more than a voltage drop across a resistor.   Much better linearity by adding a lv bias xformer,  especially if you hotrod the audio section.
The mod xformer is decent.
I have a source for NEW audio boards if you end up needing one.   VERY common fault of the tram Cb sets.
I've done a few.   Feel free to ask any questions.
« Reply #10 on: October 28, 2015, 12:11:10 PM »
A slow moving fan is a necessity,  as is recapping the entire radio.
kc4umo
« Reply #11 on: October 28, 2015, 01:04:22 PM »
w4bsf,
I will let a few folks know about those.
Good information guys, brings back lots of memories.
These were real radios back then.
I did not know about the Lafayette radios.
Shane,
Thanks, I am sure I will have some questions as I move along with this.
I also used to make the boards. But since lost part supplier for the connectors. I have seen these burnt so bad components just fall right off.
Before I got out of repairing cb radios I made it mandatory that all capacitors were replaced or they would take it else where. Kust too much of a nightmare chasing ghost from bad caps.
Had this little gem in the shop last week. man I have not seen one in this shape in ages.
« Reply #12 on: October 28, 2015, 02:45:27 PM »
Only one Lafayette model (HB-266) was made by Hammarlund. On the Hammarlund side, it was known as the CB-23.
Although the HB-444 series were nice looking rigs (I had three at one point), they all had trouble handling strong signals.
kc4umo
« Reply #13 on: October 28, 2015, 03:12:26 PM »
Front end overload?
And could it be corrected?
« Reply #14 on: October 28, 2015, 07:19:54 PM »
Front end overload?
I'm sure you could make improvements to the front end, mixer, IF chain, and the AGC circuitry, but it wasn't worth the trouble or energy. Even new out of the box, we sold quite a few of them during their life cycle, strong signals, especially in metro areas, would bugger them up. If you were out in the boondocks, generally they would be fine unless there was a strong "E" opening. I sold the last batch of new old stock meters to some guy down in NC several years ago. The front panel of the meter had the habit of crystallizing making viewing difficult and/or annoying.
kc4umo
« Reply #15 on: October 28, 2015, 07:40:58 PM »
Front end overload?
Ah,
Sounds almost like it was receiving a lot of intermod where different frequencies in the city would mix with the IF. I could be wrong though.
If I recall Frank at Tar heel radio over in Chocowinity sold a few of those many years ago. He is one of the oldest cb radio repair shops I know of in NC. And at 74 years old he is still in business. One of the best Tram repair techs I ever met. I drove down last Friday to see him and picked up a oscilloscope in need of repair. A 35 MHz Dick Smith which is the same as the JDR 3500. High voltage supply failed. Remind me to tell you how much I hate HV switching supplies. I would take heavy iron and a doubling circuit any day.
Anyway I think it is going to be fun bring new life to some of these old rigs. Should make for a good winter project.
« Reply #16 on: October 28, 2015, 08:05:39 PM »
I've had a few Trams here in the past, along with a lot of other CB base-type rigs I acquired through the years.  Most found cheap at yard sales or sitting by the curb waiting for trash pickup. Fix and clean them up and flip them back at the next hamfest. Never desired to even start a collection which would just amount to more dust catchers and used up shelf space. I have one CB in the work bench area which I use as a signal source and monitor.
AF5J
Such is Life
« Reply #17 on: October 28, 2015, 11:45:01 PM »
I have had a project on and off the bench for some time now. It started life as a Siltronics
VFO and a HW12. Really only part i saved was the HW12 case then  married the VFO into that case and cabinet. Still working on it and populating the boards.  The reason i started this was to do something
with a bunch of CB's i was given by a now silent key ham buddy.  The rig will start as a 80 meter
AM receiver. I can add to it later on.
Such is Life
kc4umo
« Reply #18 on: October 31, 2015, 07:52:10 AM »
Now that is an interesting project. Please keep updates as you move along on this.
Worked a lot of overtime this past week. Not much time in the shop.
I did get the D201 on the bench and decided to give it a good once over. Replace caps and tired out components. Lots of solder reflow and inspect tube sockets. This one is not the hand wired chassis.
Someone in the past has partially rebuilt the BA board. But they used ceramic resistors which I think is a no no in this circuit. Carbon or metal film would had been a better choice. At least the board is not burnt up like some I have seen in the past.
I hope to get more done to this today but have a Yaesu 757 and a Kenwood 120 on the bench that has to be looked at first.
« Reply #19 on: October 31, 2015, 11:44:37 AM »
Being audio,  the added inductance of the wire wounds don't disturb the circuit appreciably.
I'd replace them,  once again,  and stand them off from the board.   Mine all look goofy,  wire wounds sitting half inch or more off the board,  but none of my boards are crispy,  either.
kc4umo
« Reply #20 on: October 31, 2015, 12:47:32 PM »
Agreed,
Bad enough there is a hot tube on the foil side and then hot resistors on the other. Will cook the board till it is a golden brown lol. More like chard black...
Good idea to move those resistors up off the board.
« Reply #21 on: November 01, 2015, 03:27:37 PM »
Here ya go, Buddy - TR-72C w/27C base unit. Also a Titan II w/XL-100. Corsair would actually be correct.
I grew up in northern New England and spent a lot of time over around Winnesquam, Wolfboro, Laconia, and on Winnipesaukee. Knew a few folks who worked for Browning and Tram back in the day. Hand wired, Collins mechanical filters, quality components, certainly the Rolls Royce of 11m.
Also knew a number of true old time hams (licensed in the 30s-40s) who swore by their 11 meter radios. When the FCC converted the band to the Citizens Radio Service (or whatever), these guys simply got a license and radio and used it locally. Their description was that 11 meters was the 'local intercom' before the 2 meter band came into widespread use.
kc4umo
« Reply #22 on: November 01, 2015, 04:50:46 PM »
Thanks Todd for sharing that story. And for posting those beautiful old rigs. They look like they are in excellent shape. Really appreciate that Smiley
Did not get a lot of time to work on the tram yesterday. A guy drove 70 plus miles to bring me his Kenwood 120 to look at. His crappy power supply went south and threw 24 volts into the rig. Was an easy fix.
The 757 I was working on took most of my time to troubleshoot.  Rig lost it's -8 volt circuit. Q01 (2SC496Y) went bad. Now to find a replacement.
So back to the tram. Final tube is bad. Got to check and see if I have a good replacement.  Spent a little while checking resistors and making a list of caps to replace. Used the USB microscope to have a look at some solder joints. Finding a few that needs to be reflowed. Someone has done a bias mod to the output section.  Have to remove this and get it back stock.
WA2SQQ
« Reply #23 on: November 02, 2015, 07:54:43 AM »
Ya, and the 6BM8 behind the S meter ran so hot that it melted the plastic! Just starting to look for all the caps. I also have almost a complete set of NOS tubes in Lafayette boxes.
WA2SQQ
« Reply #24 on: November 02, 2015, 07:57:09 AM »
Do you recall who he was? My meter suffers from that condition
