May 06, 2024, 04:31:48 AM *
Author Topic: LTSpice components  (Read 1647 times)
« on: August 27, 2015, 05:36:27 PM »
I have gotten pretty good at drawing CRTs in LTSpice Here are a couple generic ones and a high end one to get anyone started on the modulation scope or making a schematic from tracing out a piece of gear.
There are no accompanying models but that is usually not an issue as you can add the capacitances and odd things like the 200-2000 megohm helical accelerator resistance from measurements or datasheets if you know how to create the full components. I have not figured that out..
Using these shapes, you can place it in a schematic then right-click on it and 'open symbol' to change pin numbers or move/edit/eliminate text.
You will have to rename the files to .asy because zip files and LTSpice files can't be uploaded.
* VT_CRT_3WP_.txt (2.62 KB - downloaded 220 times.)
* VT_CRT_5ADP_.txt (3.07 KB - downloaded 128 times.)
* VT_CRT_Tek545.txt (6.07 KB - downloaded 172 times.)
John K5PRO
« Reply #1 on: August 28, 2015, 12:49:05 PM »
Nice work.
Page created in 0.031 seconds with 18 queries.
