May 15, 2024, 05:50:26 AM *
Author Topic: On building a single FET 10 meter transmitter  (Read 1969 times)
ka1tdq
« on: August 07, 2015, 09:32:35 PM »
I guess using switching FETs in saturation is out because of the gate capacitance at 10 meters. A FET designed for linear service would have to be used and biased somewhere below saturation.
I'm thinking about using analog drive from a ricebox to drive the gate. I'm thinking maybe 10 watts of drive and then use a little DC on the gate to bias it in class C. I already have another huge transformer to Heising modulate.
I found an old networking enclose box at a thrift store (imagine an enterprise grade switch) with no holes on the front. On the back where all the factory chassis openings are, I bolted over with a piece of 1.5" steel. Then I painted it all black. It looks really nice and fits neatly below my computer monitor. I think it would make an excellent transmitter.
Jon
KA1TDQ
PD0RTT
« Reply #1 on: August 07, 2015, 11:57:57 PM »
Well Jon if you won't go tun saturation I would apply these Mosfets:
BF548 or the free scale  counterpart was do the same output power.
To spare some enormous modulation power, I would advise to modulate these devices in class AB where they mean't before.
73"
« Reply #2 on: August 08, 2015, 12:21:55 AM »
I guess I thought to see a crystal and MOSFET, how interesting that might be if it would work and make any real juice. Sort of like the old crystal+6L6..
Still this is really interesting to see what drive might be required and how its done. It's good learning for me!
« Reply #3 on: August 08, 2015, 10:57:27 AM »
I have a 1x1 rf deck pwm at 10 meters.   It runs from 10 to 12 fairly decent.
It takes about 3/4 Watt carrier and produces to 200 watts pep.
I can supply you with part numbers of fets I've successfully tried,  if it will help.   Notes are in the garage,  of course.
And I use sinewave drive on most as well.
Page created in 0.069 seconds with 18 queries.
