May 05, 2024, 10:24:03 PM *
Author Topic: Ethernet cable  (Read 9060 times)
wavebourn
« on: February 08, 2005, 07:48:25 PM »
Hi!
Is 10-base-5 cable (802.3) usable for antennae feeding?
Barry
« Reply #1 on: February 08, 2005, 10:07:55 PM »
I think that is called 10base5 it is like a quad shielded RG8.
It has 50 ohm characteristic impedance  and I have used it to make coax jumpers between various pieces of equipment.
The only problem with it is that it is very stiff and heavy. (not flexible ;-)
You would need some real support to feed any type of wire antenna that was off the ground with it.
Barry
« Reply #2 on: February 08, 2005, 10:23:49 PM »
No fun to install connectors but otherwise just great stuff. I like the yellow jacket.
wavebourn
« Reply #3 on: February 08, 2005, 10:53:41 PM »
Oops... Sotty for typo, however I mean 10-base-5! Corrected.
So, your opinion is that it is better than usual RG, electrically?
« Reply #4 on: February 08, 2005, 11:07:20 PM »
The stuff I have here is Belden 9880 Ethernet Coax.  It might hold up a little better under high SWR conditions and the shield is certainly better than most RG-8.
More info here:
http://lists.contesting.com/archives/html/Towertalk/1997-02/msg00184.html
wavebourn
« Reply #5 on: February 08, 2005, 11:53:36 PM »
Thanks Dave, it is a good idea to check if it has some vampire punctures!
