March 02, 2026, 10:25:13 PM *
Author Topic: 10.5 VAC DUAL WINDINGS HIGH CURRENT 130V PRI .135KVA 7LBS SOLD  (Read 2993 times)
k4rhh
« on: March 12, 2015, 11:24:13 PM »
THIS IS FOR A TRANSFORMER BY RAPID ELECTRIC CO.INFO ON THE LABEL READS PHASE 1,60HZ CLASS B.HAS M.135D SPEC, AND 83537 SHOP ORDER.130V PRI.WEIGHS 7 LBS.THE LAMINATION IS 2 1/8"THICK3.5" TALL.THIS HAS 2 10.5 SEC (NO CT) THE SOLID SEC WIRES ARE 12GA .AND HAS A 130 AC PRI.SOMEONE SAYS THIS LOOKS TO BE ABOUT 6.5AMPS ON EACH SEC.I HOOKED UP A PAIR  OF 813 TUBES TO 1 OF THE SEC AND A SINGLE 813 TO THE OTHER RAN FOR 3 HOURS AND THE TRANS JUST BARELY GOT WARM.THIS MUST BE A LOT MORE AMPS THAN 6 AMPS HERE.THERE IS A LOT OF TRANSFORMER HERE. ASKING 12.50 PLUS SHIPPING $10  rwcradiocollector@gmail.com  tnx randy K4RHH  SOLD
