November 18, 2025, 01:16:51 AM *
Pages: 1 2 [3]   Go Down
Author Topic: Parasitic Chokes  (Read 70914 times)
wavebourn
« Reply #50 on: February 04, 2005, 03:25:15 PM »
Quote from: WA1GFZ
Tolly, 12AU7s can be wired for 6.3 volts. There are 3 heater pins someone
correct me it has been a lot of years.  This allows you to put both heaters in parallel. good luck!
However I know Frank that the 9'th pin is the middle betwen 4 and 5 pins, but I won't resolder  anything in the radio. It is still original Collins made peace of history.
« Reply #51 on: February 04, 2005, 03:36:39 PM »
I understand now.
I once considered building a power supply inside the case. I thought about removing the power connector and install a plate over the hole. Then a power cord could come through the plate. Maybe a little switch would also fit on the plate or the spare fuse holder could be removed and a switch
could go there.
The radio took about 28 volts at 3.5 amps with most of the power used by the audio output. I have heard the radio works better with a little higher plate voltage.
wavebourn
« Reply #52 on: February 04, 2005, 03:41:37 PM »
Quote from: WA1GFZ
Especially in terms of intermodulations. Wink
It is exactly what I am going to do! Cheesy
« Reply #53 on: February 04, 2005, 03:48:36 PM »
I always thought the best thing to do would be rip out all the tubes
and use transistors running class A but AGC would be a problem.
1 module at a time starting from the speaker to the RF input is the path I would have taken. It becomes a big science project.
BTW I notice you use the term crapstal. This is a good sign you will be using "strap" soon.  welcome!
wavebourn
« Reply #54 on: February 04, 2005, 03:54:51 PM »
I prefer to use tubes in RF and 1'st IF.
However, before I saw a schematics, I considered to rewire filaments, because I did not know that B+ and filaments are powered from different pins of sockets. In such case they could be rewired to any voltage. But when I discovered that filaments and plates are powered separately I decided lo leave all wires on place, may be to convert from 26 to 12 volts, since 12 volt versions of the same tubes are much cheaper and widely available.
Pages: 1 2 [3]   Go Up
Page created in 0.095 seconds with 18 queries.
