May 18, 2024, 10:33:23 AM *
Author Topic: NEW HIGH VOLTAGE MICROWAVE SWITCHING POWER SUPPLY  (Read 14320 times)
« Reply #25 on: December 05, 2014, 02:48:17 PM »
Patrick, nice find! Cheesy
« Reply #26 on: December 05, 2014, 03:24:09 PM »
Here's another way, found on ebay. Looks to be maybe 20yrs old now. (geez, that's NOT so far back as to be called "old" is it??)
http://www.ebay.com/itm/High-Voltage-Capacitor-Charging-Power-Supply-1-7-kv-1-kw-/301422095495?pt=LH_DefaultDomain_0&hash=item462e282c87
takes 3ph input...
"Input power goes through a 15 amp breaker to a 3 phase full wave rectifier. This DC power feeds two SCRs in push-pull that drive a transformer. The SCRs are fired by a circuit that accepts an external low voltage signal to control the output voltage. The transformer has 4 identical isolated secondary windings that go to individual full wave bridge rectifiers. The rectifier outputs are wired in series to provide the module’s actual output voltage. There are also 2 opto-isolated low voltage inputs that appear to be for interlock/enable functions. The red pilot light on the front panel may be for fault indication."
Control circuitry is on the bottom, FYI. Not shown in the image.
Page created in 0.033 seconds with 19 queries.
