May 08, 2024, 11:16:11 PM *
Author Topic: Replacement 5 Position Switch (S4 on diagram) for EF Johnson Ranger  (Read 2687 times)
w5gw
« on: November 12, 2014, 09:11:39 PM »
Has anybody got one of these or have a source for a replacement? This is the power, etc. 5 position rotary ceramic switch to left of the VFO dial.
Thanks,
Gary W5GW
WD8KDG
« Reply #1 on: November 13, 2014, 10:40:46 AM »
Gary,
Does anyone have hens teeth? Grin
Last month some lucky person found a NOS Ranger function switch at the Rickreall fester in Orygun. Wish it were me.
So: If'en your issue is just a burned toasted contact, common problem with Rangers; take a good look at the toasted switch. With luck there is an unused contact of the same length. I've used a Dremil tool with a small cutter to remove the rivet holding the burned contact and a good one. Then with a very small machine screw & nut, place the good contact where needed.
Hope this helps.
Craig
« Reply #2 on: November 13, 2014, 08:13:56 PM »
Thanks,
Gary W5GW
Gary,
Let me take a look and see if I still have my parts Ranger.  If so and if it has a switch, I will send it down to you.
Joe, GMS
wa3dsp
« Reply #3 on: November 19, 2014, 01:17:36 AM »
Not sure if you resolved this but it is a common problem on the Ranger. I don't remember exactly what I did when I restored and mod'ed mine several years ago but here is a pretty detail link on my restoration including details with closeup photos on the switch changes. You may not want to do what I did but just presenting it as an option.
http://www.crompton.com/hamradio/JohnsonRanger/RangerRestoration.html
