May 15, 2024, 06:30:32 AM *
Author Topic: Pallet Amplifiers on AM?  (Read 3138 times)
WA2SQQ
« on: November 04, 2014, 08:37:56 AM »
Currently running a Flex 5000 (barefoot). Been reading about these Pallet amplifiers which are getting cheaper and cheaper. 300-500W for ~$350. Has anyone tried these on 160 / 75 AM? How about reliable T/R switching? Sounds like a great winter project. I'd like to put something together that would produce about 300-400 watts. Comments and suggestions will be appreciated.
« Reply #1 on: November 04, 2014, 11:58:21 AM »
Do you have a model or manufacturer? I looked on the Richardson RF site and only saw one that worked at HF. It was rated at 10 watts and ran Class A. Some of the ones for the FM BC band were good for 500 watts and ran Class B.
WA2SQQ
« Reply #2 on: November 04, 2014, 01:11:59 PM »
Many up on EBAY from a guy in Greece
300W
http://www.ebay.com/itm/2-30-MHz-HF-300-WATTS-amplifier-BRAND-NEW-with-TRANSISTOR-SD2943-by-THOMSON-/320992864624?pt=LH_DefaultDomain_0&hash=item4abcaa6970
600W
http://www.ebay.com/itm/600W-HF-1-6-28-5-MHz-pallet-amplifier-BRAND-NEW-with-2-power-mosfets-by-THOMSON-/221181740697?pt=LH_DefaultDomain_0&hash=item337f758699
They do say AM, but I'm wondering how clean? Reached out to the dealer to ask about duty cycle.
Many are using them on VHF and UHF with great results. They run off of 48V surplus switching power supplies.
« Reply #3 on: November 04, 2014, 07:19:24 PM »
Thanks for the links. Very interesting.
« Reply #4 on: November 04, 2014, 09:18:53 PM »
http://www.commamps.com/amateur/amateur.htm
Here in Texas, the pallet amps are also made. 100% duty cycle rated.
WA2SQQ
« Reply #5 on: November 05, 2014, 08:32:40 PM »
I suspect EBAY dealers will be cheaper. Neither offer any LPF's, so thTs the next puzzle piece I need to find. Would like to speak with someone who actually uses one of these. Want to use it on 160 / 75 AM primarily. Already have the 48V 50A supply and a heat sink from the local scrap metal yard.
