May 15, 2024, 08:52:57 AM *
Author Topic: Transister Modulator Assistance Needed  (Read 22648 times)
W5EFR
« on: November 03, 2014, 04:53:04 PM »
Howdy Gents,
I am restoring an old 23 Channel Lafayette Telsat 23 (early 70's era) CB. If I can get it running, I am thinking about putting it up on 10 meters.
Here is the issues...
4 Watt Carrier is good, but when the transmitter is modulated, I can not reach 100%. The Negative peak hits 100%, the positive peaks are considerably less than 100% and then they start to Flat top.
I am trying to decide if I am running out of Modulator headroom, or if the power amplifier section is lacking in the power department.
I have modulated it with a 1kHz signal through the mic jack, then also through the external input on the back of the transmitter, the results are the same.
I already replaced the power section filter caps,
The Thermo-resister is in spec (34 ohms cold), the Voltage is near Spec (16Vdc)... so I decided to ask the Gurus... any ideas?
« Reply #1 on: November 03, 2014, 10:22:00 PM »
Have you looked at the audio signal at the output of the modulator??  You're running out of headroom on half of the sine wave.  Look at the audio from the aux input to the output.  Early audio stages probably not the problem since you say the results were the same with signal injected at the aux input.
What's the 113.9khz as shown on the scope in the second pic??
W5EFR
« Reply #2 on: November 04, 2014, 03:59:10 AM »
Fred,
Thanks for the reply. I have not looked at the output of the modulator output yet, but will check there next. This circuit board is not marked at all, and the "High Quality" Sam's Photofact pictures leave a bit to be desired...
I agree that the issue is in the modulation section itself and not the Mic Preamp area... I actually think one of the 2 - 2SB337 Germanium Transistors (Output Modulators) may be heading South... I have yet to find a modern, silicon replacement...
The is normally the Frequency Counter, as to why it is picking up 113.9 kHz on a  27.005 MHz carrier modulated with a 1kHz Sinewave, I have no idea...
« Reply #3 on: November 04, 2014, 10:45:54 AM »
It does look like head room problems but have you looked at the phase of the microphone?  It might be a phasing problem.  Another issue might be a mismatch between the modulator and the class C load.
I'm leaning toward a mismatch problem.  Just 'cause it was commercially built doesn't mean it was designed right
Al
« Reply #4 on: November 04, 2014, 12:42:44 PM »
I would definitely look at the modulator stage when its into its positive peak clipping condition.   Compare each base to emitter waveform of the push pull pair.  Remember to float your scope since the negative probe will be referenced to a positive voltage due to the PNP topology.  Then look at each of the collectors and see how they look.  Since your using a sine wave generator no need to worry about audio phasing however when talking into the mic, make sure you phase the audio so you have more positive peaks than negative ones.  First try to get it working with the signal generator though.
Not sure if the FCC had any requirement for limiting the modulation percentage on those rigs.  If so, there is a chance that it was designed to not produce 100% modulation.  Then again, as we all know, if your going to limit the audio percentage its mainly necessary to do that in the negative direction since you don't want to cut off the carrier.
Good luck with the project!
Joe, GMS
« Reply #5 on: November 04, 2014, 01:38:42 PM »
I bet if you put a sine wave into any CB it will look like that or worse.
It might look ok with voice, or maybe not, 10% distortion was the optimistic point aimed for...
I think they were all short of audio power and the mod transformer was well undersize for the job.
I am not sure all ham transmitters would do 100% both ways with a sine wave....
Oh, and I do not think transistors go soft, they short or open, resistors change value, but I doubt transistors do...
« Reply #6 on: November 04, 2014, 02:34:25 PM »
You won't.
You will have to find a replacement silicon transistor and re-bias the circuit.
If you can find a schematic that has voltages listed, you can determine circuit currents and biases for the germanium transistors and then convert to silicon device biases.
Look up the old Germanium spec on frequency, current, and power, and then calculate the new biasing components.
W5EFR
« Reply #7 on: November 04, 2014, 03:23:25 PM »
Actually, I have yet to come across a CB that will not do a clean 100% Modulation.... until this one...
 The biggest limiting factor of the modulation transformers is Bass fidelity... Most modern Transformer modulated radios start to distort the waveform around 200Hz...
That maybe true, I only have 2 Amateur transmitters/transceivers that will do AM... A Knight T-60... which will not do 100%, and a ICOM IC-718, which uses that weird Downward Modulation... and doesn't get used on AM
I am starting to agree... I figured those old Gi transistor may have started to get leaky, but when I O'Scoped the Collectors, they are both pushing 25V P-P and 180 out of phase with each other...
W5EFR
« Reply #8 on: November 04, 2014, 03:35:34 PM »
Joe, GMS
Hello Joe,
Thanks for the information and assistance. The Sam's Photo Fact states to set the modulation to 80%...
I have also adjusted the 'Range Boost" R6 and see very little change, which makes me think it isn't driving hard enough to being the feedback into play. Even when I drive it into over-modulation the Range Boost doesn't do anything... but then again, looking at the schematic, if I am inputing the signal through the external Modulation Jack, it won't.... as the feedback goes all the way to the Mic Pre-amp first stage transistor Base...
« Reply #9 on: November 04, 2014, 04:33:27 PM »
What you want to look for with the scope is the audio quality before it gets combined with the RF carrier since you know that does not look great!   If a bias voltage shifted in any of the audio stages you could very easily get the type of waveform that your seeing.  So I would start at the primary of the modulation transformer and if that looks bad then just keep going back stage by stage until you find the problem.  With a scope you should be able to zero in on it very quickly.
Let us know how you make out with it.
Joe, GMS
« Reply #10 on: November 04, 2014, 05:50:10 PM »
From what I remember from doing service on this model and looking at the Lafayette schematic, if you set the modulation to 100%, you will be in distortion mode and even worse if you turn the "range boost" on and modulate it with a microphone. Set the modulation to roughly 80%. After 40 years, the transistors may be starting to deteriorate. I would also check every resistor and capacitor. In the Lafayette original schematic, the mod transistors were labeled 2SBF1, 2SDF1, 2SBF1A, and two 2SBF5. Eventually, those codes rolled into the codes you see on the SAM's schematic.
The receiver section has one IC (ICF-1) which was a known failure device. The receiver also has a "mechanical filter" which will distort receive audio on strong signals.
This model was not one of Lafayette's better performers.
« Reply #11 on: November 04, 2014, 09:47:00 PM »
I think the performance is abut right for that. Those were not the best quality and the positive side of the modulation is always harder or more demanding or so it seems.
W5EFR
« Reply #12 on: November 05, 2014, 02:22:19 PM »
I am starting to think you guys are correct.... this is working "as designed"... I rebuilt the bias section and gained... nothing...  Shocked
I am fighting the urge to make it work correctly now... or trying to understand why it is doing what it is doing...
« Reply #13 on: November 05, 2014, 02:42:33 PM »
Obviously you can redesign the entire modulator with better transistors, mod. transformer, etc. if you feel the need. Some of the later Lafayette models also had better audio and better final and driver transistors. On 10 meters, where the happy day is just working someone on AM, whether you're at 80% or 90% modulation, is probably not a great concern on the receiving end.
« Reply #14 on: November 05, 2014, 04:44:45 PM »
Scott,
It "may" be interesting to find where the problem is.  You may choose not to fix it and that's OK but it would be nice to see whats wrong with the design assuming its a design issue.  I encourage you not to change components and shotgun it hoping you will find the issue, but rather with your scope probe look at the audio stages and see where things go astray.  The audio should be at least symmetrical since your audio source is a sine wave.  You may not be able to modulate fully, but a sine wave should modulate the transmitter equally in both directions.  What you have shown is that your able to modulate in the negative direction fully but the symmetry is such that becomes asymmetrical at some point in the audio chain.  This asymmetrical issue is likely what is keeping it from modulating in the positive direction like its doing correctly in the negative direction.
Yes, in the end on the CB band it may not matter but gaining some addition knowledge by going through it may be rewarding to you.
Joe, W3GMS
W5EFR
« Reply #15 on: November 05, 2014, 05:13:12 PM »
Joe,
Thanks for the reply...
I have been probing though the audio chain and I haven't found the smoking gun stage ...yet...
I'll take another look at it tonight/tomorrow. I am interested as to the why it is doing what it is doing, or where the lacking in design is, Heck, I wouldn't mind making it work the right way... I have $5 into this radio, it is asking to modified into submission.
I would like to put it up on 10M, on the rare chance I hear someone out there. 10M is about the only Ham band I can run on at the moment due antenna restrictions... and VHF/UHF around here is pretty lacking... I like HF...
« Reply #16 on: November 05, 2014, 06:05:23 PM »
Glad to hear that you have not thrown the towel in on it yet  Smiley
Let us know what you find.
Have fun with it.
Joe, GMS
« Reply #17 on: November 05, 2014, 10:49:41 PM »
If you can reverse the connections on mod xfmr primary, you may see the positive peaks hitting at 100% while the negative peaks may at 80%.  This may be difficult to do because of the printed circuit board, but may be a good test.
If you're able to do this and you see no change, then the problem is in the RF final.  May be something in the design limiting the positive peaks to 80%
« Reply #18 on: November 05, 2014, 11:08:55 PM »
Maybe RF base drive and biasing?
On a tube rig, poor positive modulation can be caused by screen problems, grid drive and bias problems.
Maybe the RF section can not put out enough additional power under modulation.
At 100% modulation, the RF output device will get 24 volts I would guess, and maybe the circuits or parts will not pass that power.
Or something is biased off center.
If you crank the audio up, does the positive modulation increase or stick at the same level?
W5EFR
« Reply #19 on: November 06, 2014, 03:34:34 PM »
I am not 100% convinced that the problem is all in the audio/modulation section... but I am starting there is working my way to the antenna jack... Wink
Originally, when I cranked up the audio, both of the positive peaks flat top at the same time, and the Negative peak hits or exceeds 100% shortly after... More to follow
W5EFR
« Reply #20 on: November 06, 2014, 03:49:20 PM »
So I started probing the audio section:
Baseline Modulation is first photo, then the collectors of Q12 and Q13, the Output Modulation transistors... that don't look right...  Shocked
W5EFR
« Reply #21 on: November 06, 2014, 04:00:08 PM »
So I mis-typed above and decided to go in an start rebuilding the Output-modulation bias section as required...
My first part to pull and check was R63 (2200 ohms). It read 2800 ohms... so I installed a 2.2k and that made a couple changes.
The Emitter voltages are still about 15v on both Q12/Q13 transistors.
Now the modulation and collectors look like this after the R63 change:
My next targets are R64 (47 ohm) and R65 (Thermister  33 ohms cold)
W5EFR
« Reply #22 on: November 06, 2014, 04:53:11 PM »
Fred, do you mean basically switch the connections to to the Primary from the collectors on the transistors?
That would be actually easy to try as this uses T0-3 style transistors and they are wired to the PC mounted transformer...
« Reply #23 on: November 06, 2014, 10:04:40 PM »
Al
I'm going to withdraw my phasing problem suggestion although it may be an issue with voice audio (as Joe pointed out, we are dealing with a sine wave source here) and stick with the mismatch suggestion.  I think what you have was designed into the circuit - namely, a better match from the modulator to the class C load might yield better positive peak results..
Al
« Reply #24 on: November 06, 2014, 10:32:25 PM »
If you can reverse the connections on mod xfmr primary, you may see the positive peaks hitting at 100% while the negative peaks may be at 80%.  This may be difficult to do because of the printed circuit board, but may be a good test.
Yes, switch the leads from the xfmr to the collectors.  This will put the flat topping on the negative peaks,  if the problem is in the audio chain.  OTH if you end up with the same conditions as you have now then the problem is in the RF output.  Most likely something in the design to prevent positive peaks running over 80%.
Another thing to look at is the power supply B+.  Put a scope on the B+ and see what it looks like at full modulation.  It may be sagging on positive peaks.
