March 07, 2026, 12:52:17 AM *
Author Topic: Audio clippers: Friend or Foe?  (Read 23251 times)
N1BCG
« on: October 23, 2014, 10:12:19 AM »
I recently acquired a Viking Valiant with the stock clipper circuit in place and I've noticed that there is no shortage of posts urging the removal (or bypassing) of that circuit to "improve frequency response and reduce distortion". This makes sense since even a properly designed clipper creates noticeable distortion when over-driven and a low pass filter is required to reduce harmonic content generated by clipping.
However, every single professional broadcast audio processor includes a clipping and LPF circuit as the last stage. Legally this is a must to ensure that peak energy is tightly controlled within -99% to +125%, an FCC rule. As a safety feature, clippers protect expensive modulation transformers from spikes that can make it through compressors. Competatively, properly set clippers produce noticably louder audio than limiters, a must in commercial broadcasting.
So why are clippers scorned in the amateur world?
There's a fine line between loud and distorted when it comes to clippers and properly setting the amount of drive is critical. In broadcast applications, clippers follow compressors (or limiters) so the dynamic range is already tight. Setting a clipper to handle a consistent 1 or 2 dB is considered max, but it makes a big difference in perceived loudness to listeners.
Unfortunately, clippers in most amateur circuits aren't preceded by anything so they become driven by 8-20 dB of dynamic range as if they were compressors and sound like hell. From the Valiant manual: "12 dB peak clipping - not at all objectionable, on the contrary, speech sounds as though the speaker is enunciating with special care".  Hmm.
By the way, the less clipping is needed the less low pass filtering is needed. That means that the LPFs that follow many amateur clipper circuits are designed to manage copious amounts of harmonic content. A clipper used with discretion would require a far more gentle rolloff than is usually employed.
So, my plan is to flatten out the frequency response of my Valiant, use a microphone processor to feed the Valiant with a consistent audio level, and set the 6AL5 circuit to catch the peaks that get through. The LPF can easily be redesigned with some minor component value changes.
I'd be happy to share these circuit suggestions here if anyone's interested...
« Reply #1 on: October 23, 2014, 11:16:39 AM »
The usual recipe is to use the 3 diode high level negative limiter circuit in the modulator, and let the positive peaks drive as high as they happen to go.
My Valiant II does about 115% positive according to WA1QIX's monitoring. It has sweep tubes for modulators.
There's absolutely no reason to limit positive peaks to 100%.
There is a good reason to limit negative peaks to no more than 99%.
The clipper circuit in the Valiant is not a good idea, generally speaking.
It came at a time when "talk power" to compete with the coming SSB "revolution" was important.
A soft knee limiter is a much better plan, if you want "dense" audio. Imo.
                        _-_-
K4RT
« Reply #2 on: October 23, 2014, 11:26:34 AM »
I'm interested in your circuit suggestions.
I have a Heathkit Apache, that, in its stock configuration, included a 6AL5 clipper.  When adjusted properly, the result was good communications grade audio.
Brad
N1BCG
« Reply #3 on: October 23, 2014, 01:23:01 PM »
Everyone understands the importance of keeping negative peaks from cutting off the carrier but the benefit of positive peaks is widely misunderstood.
The problem, particularly for older rigs, is subjecting mod transformers to the higher voltages as a result of >100% positive modulation. Additionally, the audio energy contained in those peaks is miniscule compared to the average modulation level although peaks look cool on mod monitors and they give operators all kinds of bragging material. High risk, low benefit. Besides, perceived loudness is a result of average, not peak, levels.
Properly clipped and symmetric modulation will be much louder and cleaner to the listener than allowing unclipped peaks to reach 200%, and why risk the iron? Motorola released an extensive report in the 1980s outlining the importance of symmetric modulation to reduce distortion generated within receiver detector circuits. Asymmetric modulation also suffers from greater distortion due to propogation.
BTW, the 6AL5 is a soft clipper...
« Reply #4 on: October 23, 2014, 02:12:27 PM »
Interesting comment, Clark.  I'm interested especially because my Collins 32V1 is capable of greater than 125% positive peaks, occasionally going as high at 140%.  So far, so good..
BTW, what operating times are you doing these days?  I confess that my early evening AM operations have suffered a bit lately.
Al
W1DAN
« Reply #5 on: October 23, 2014, 02:15:10 PM »
Hi:
The Valiant (and Apache, and others) clipper preceded audio stages with substantial low frequency roll-off (and often a crystal mic). This reduced the IM distortion created in the clipper. Also remember these manufacturers wanted to create a product with the fewest parts, so that meant no compressor. I agree that carefully controlling the level going to the clipper is a key to it's not getting in the way of the sound. I agree that negative clipping at the modulation secondary is the best place to clip, as there is often less or no phase change after this point, where the low level clipper square waves will be rounded and tilted when going through the driver and modulation transformers.
Less low pass filtering with less clipping is not really true. While a hard clipper will create harmonics, your natural voice goes beyond 2KHz, the desired bandwidth of SSB stations. If you want to stay within a certain bandwidth, the only way to do that is with a properly designed LPF. Note that any LPF will also tilt a square wave that results from clipping, and your ceiling is no longer as defined. In the end you need to look at occupied bandwidth with whatever you do in the transmitter, compare it to desired bandwidth, and add some form of LPF. My vocal "esses" go out to 6Kc (12Kc occupied bandwidth) before filtering. For broadcasting, AM stations need to stay within their channel, and must have tight filtering to protect the adjacent channel. The designers of ham tube transmitters in the 1950s had limited occupied bandwidth and communications quality audio as main goals. So they had steep high pass and low pass filters. Today, we often desire "hi fi" audio on the ham bands. I clip a little and limit my bandwidth.
Dan
« Reply #6 on: October 23, 2014, 03:09:53 PM »
<snip> High risk, low benefit. Besides, perceived loudness is a result of average, not peak, levels.
Not sure anyone was suggesting 200% peaks.
What Motorola was trying to do in the 1980s differs sufficiently, imo, from what is generally aimed or in today's AM transmitters and operations as to be not terribly relevant.
If you want very symmetric audio, run it through a few sections of all pass filter and ur done. That's pretty much what some broadcast "processors" did or do.
I'm not sure I agree entirely with the perceived loudness being solely a function of average level. Certainly a full modulation is more audible than less than full modulation, under conditions that are less than good. Otoh, I have heard stations that run more than 100% modulation and their audio is both cleaner and appears to have a greater ability to get through marginal conditions.
High average modulation using compressors and peak limiters and the like generally sounds awful except for "battle conditions" that I have heard.
I guess one could make the case for higher peak modulation and less carrier the result eventually being DSB! Cheesy
But there are all sorts of ways to do things, and everyone has their preferences and ideas. Nothing wrong with limiting the rig to 100% positive peaks...
« Reply #7 on: October 23, 2014, 04:47:51 PM »
I don't recall ever seeing anything that approaches 200% pos peaks.  I have, however, had levels approaching 175% with my class E transmitter, which is very linear.
I use enhanced density from my dBx 285s but do not think I sound particularly distorted -  badly adjusted transmitters may result in a distorted sound but not properly designed / adjusted ones.
I see no need to make the AM modulation component symmetrical.  Just design / adjust one's station according to good engineering practice.  Having said that, one should take measures to detect the incoming AM signal with adequate linearity so that transmitting stations that are properly producing the  asymmetrical human voice are accurately reproduced. There are several approaches that achieve that goal, including enhanced carrier detection, precision detectors and Sync AM detection. Several of our folks have designed these type of detectors and have published the results.
Al
W8IXY
« Reply #8 on: October 23, 2014, 05:15:03 PM »
For great and loud audio, referring to AM, the most important thing is to set up and/or design your transmitter to be as flat in audio response as possible, as low in distortion as possible, and able to modulate any waveform applied to it as accurately as possible.  ALL audio processing should be done BEFORE applying it to the transmitter.  That's the way the broadcasters do it.  ALL phase rotation, AGC, limiting, clipping, filtering, should be done BEFORE sending it to the transmitter.
I have spent my entire career in broadcast radio, most of it was AM with a number of AM transmitters in the 50 kilowatt range.  I also design the parameters of some of the AM (and FM as well) Omnia audio processors for broadcast.  And that is how we do it.
Ted  W8IXY
N1BCG
« Reply #9 on: October 23, 2014, 05:28:43 PM »
Here's a link to what I consider THE Bible of audio processing as it was co-written by Bob Orban (Orban) and Frank Foti (Omnia), designers of the two most popular broadcast processors in the world:
http://www.orban.com/support/orban/techtopics/Appdx_Radio_Ready_The_Truth_1.3.pdf
It would be amazing if more people understood and embraced what is being said here.
« Reply #10 on: October 23, 2014, 07:33:30 PM »
A valueable reference, but we are not working with the same considerations or constraints as are AM broadcast stations. Nor do we have the same goals or aims.
« Reply #11 on: October 23, 2014, 07:56:29 PM »
Old school clippers should be avoided for two reasons.
1. They create distortion than cannot be filter out with a lowpass filter.
2. The lowpass filter designs found in most 50/60s transmitters have horrible impulse response resulting in overshoot. The overshoot results in peaks, the very thing the clipper removed. So, the circuit is essentially fighting against itself.
There are many low cost processors available now or simple level control circuits that can be easily built.  These processors and circuits will control modulation levels better than clippers and will not create distortion. I don't see messing with clippers worthwhile.
« Reply #12 on: October 23, 2014, 08:04:53 PM »
Steve, do you have an example diagram of an old school clipper? I want to understand well.
« Reply #13 on: October 23, 2014, 08:14:31 PM »
Check the schematics for say, a Valiant or Apache or Eico 730 on BAMA.
« Reply #14 on: October 23, 2014, 08:32:04 PM »
I don't think I ever heard anyone using a clipper that sounded good, not that I remember anyway.
And I can never hear much difference between 120% positive and 150%.
I do think a lot of people could use some compression and agc on the audio, unless you watch it all the time, a mic into a rig does not work very well, low audio or closing off the carrier or both just by moving around or talking a bit louder.
« Reply #15 on: October 23, 2014, 09:11:46 PM »
I always thought the plan on "modernizing" these table -top transmitters was to eliminate the 6AL5 all together and update the mic circuits for wider range audio, so they would not be so screetchy. And add some negative audio feedback from the modulator to clean up any distortion.
The 3 diode set-up I tried on a DX100, from long ago, created more problems than I could ever imagine.
A famous AMer here, WA1HLR, Timtron, has some interesting approaches to firing a table-top transmitter using a power transformer as a modulator transformer.
I used one on an Elmac TX with a 6146 final and it made big  audio using 6550's as modulators!!
And 120% or around that number is about max that any AM radio can detect without distortion.
A couple others mentioned here that the audio processing, compressors/limiters, preceding the transmitter input is the real answer.
« Reply #16 on: October 23, 2014, 09:27:04 PM »
I'm proud to say that I own a Collins 32V1 that Timmy HLR did a full up mod on.  I've gotten excellent reports on it.  In fact, I'm told it is hard to tell it from the class E transmitter. It's a pleasure to operate.
Attached photo shows the 32V1, lower Collins unit.  The 75a2 is basically unmodified.  The only processing is the aforementioned dBx 286s
Al
« Reply #17 on: October 24, 2014, 01:19:59 AM »
Look at the page on an eico 730 as attached
PS: Sorry about the previous mixup on the graphic
WB4AIO
WB4AIO
« Reply #18 on: October 24, 2014, 10:37:47 AM »
Built-in ham transmitter clippers have a lot of problems and sound pretty bad.
But a small amount of clipping following other effective processing can help keep modulation levels high and still sound good.
Here are the keys, in my opinion, to making clipping most effective and clean-sounding:
1. The frequency response of all audio circuits past the clipper should be dead-flat and wider than the actual audio you want to transmit. Particularly, the post-clipper response should extend well into the subsonic range, or the flat tops of the clipped waves will become tilted and overshoot their target levels, eliminating the advantages of clipping. DC coupling is best, flat amplitude and phase response down to 10 Hz or so is almost as good. Hard to do with transformer coupling! (The homemade diode high-level clippers in plate-modulated rigs get around this by putting the clipper past the modulation transformer. And Class E and other pulse-modulated rigs are perfect in this regard -- that's one reason why those running them can use quite a lot of clipping and sound loud without sounding very dirty at all.)
2. The source audio and the following audio stages should also be extremely clean. (Another area where older 50s/60s commercial rigs and their clippers fail badly.) The processed audio waveform must be reproduced near-perfectly, and typical commercial ham AM transmitters don't come anywhere near doing that.
3. If low-pass filters are used, they must be of the overshoot-compensated type, or they will impair the level-control advantages of clipping.
4. Bright audio with an extended high end, with lots of pre-clipping treble density, sounds much better when clipped than dull audio. I believe this is because the natural high frequencies mask the IM and harmonics created by the clipper.
One cheap processor that uses clipping well, in my opinion, is the Aphex Dominator. Many famous and good-sounding CDs have been made with them!
Very interesting discussion.
Kevin, WB4AIO.
« Reply #19 on: October 25, 2014, 07:33:15 AM »
I use negative peak clipping on 100% of my transmitters.  Would not operate without it.  If I modify an existing transmitter, I put a negative peak clipper into the circuit.
With this, you can *easily* get 6dB more audio (assuming your modulator is capable of producing the extra audio, that is) and *no one* notices the clipping on the air.
Of course as many others have pointed out here, the other half of the equation is audio processing and having a clean, flat modulator to start with.
No real need for positive peak clipping here on ham radio, since we are not limited as to positive modulation percentage.
By the way, I usually set my negative peak limiters to around 95% negative.
Under quiet band conditions and good signal to noise ratio operating, I back everything off a bit for full fidelity, largely unclipped operation. The clipper at that point is just a watchdog and hardly ever is really doing much of anything.
« Reply #20 on: October 25, 2014, 11:47:02 AM »
Yes, an AM transmitter MUST be very clean to start with.  Otherwise, by simply increasing audio power, the modulator will generally become dirtier on its own, regardless of clipping.
I have run various transmitter IMD tests using the excellent QIX clipper design taken from the class E PDM generator.  It has an audio aliasing LP filter after the clipper.   I find that the overall transmitter RF IMD will degrade very slightly from excellent to good as the NPL is dialed in aggressively. (About 5dB degradation in 3rd order IMD) There are no free rides, but it is acceptable.   These tests were run with both a class E MOSFET PDM rig and my new dual quads tube PDM rig.
I use the NPL clipper as a safety net  for occasional over-modulated negative peaks that would either cause some splatter or do damage to the mod transformer of my 4X1 plate modulated rig.   Certainly, we need a method of stopping the carrier from being totally cut off during negative peaks, whether using a negative peak clipper, limiter, or whatever.
To lean hard against a clipper all the time can invite splatter if the rig is not already very clean, so it pays to either use it as an occasional  safety net OR work on the transmitter to make it near-perfect first.
The point is, with the stock Valiant type rigs, positive peak IMD is already so bad when the audio is hit hard, that the neg peak clipping will not help - and even add some slight crud to the negative peaks.   A neg peak clipper will not change the waveform of already distorted positive peaks.
If you can build or modify a super clean AM transmitter, the whirl is your oyster. Talk anywhere and never have to worry about splatter reports.   At least -30 dB THD and -30dB 3rd order IMD is required for entry into this exclusive club.  Wink
Additional notes:
1) THD and IMD tests can be performed with simple audio tones using most any SDR pan scope.
2) On AM, there is a difference between "splatter" and normal side channel products. Splatter is the nasty, spitting, tearing sound of distorted audio up the band that extends higher than the fundamental audio freqs.  Clean side products produce a nice wispy, diminishing smooth S sound as tuned higher.
3) The comments above pertain to using a low level negative peak limiter.
« Reply #21 on: October 25, 2014, 01:23:32 PM »
<snip>
Additional notes:
On point "2)"  An observation not to be overlooked by the careful operator of an AM station.
All observations on this post are excellent in my view
Al
« Reply #22 on: October 26, 2014, 07:58:40 AM »
"...submitted for your approval..." - Rod Serling
Genuine old school clipper.
N1BCG
« Reply #23 on: October 26, 2014, 09:17:30 AM »
It's important to point out that a clipper, like any tool, has to be used properly and those early ham transmitter circuits certainly were not good examples of proper use.
Clippers should be used in conjunction with processing that will limit what the clipper stage to just peaks. Some broadcast processors even monitor the current flowing through clipper diodes and use that to adjust the gain of the preceeding limiter in order to prevent overdriving.
Music store processors are a great value for increasing average levels of modulation, but very few have the ability to catch peaks that would show up on mod monitors, even if they claim to be limiters. Also, decreasing attack times on compressors to reduce peaks will only increase gain reduction and lead to "pumping".
The best way to view a clipper is as a means to eliminate peaks that get past compressors so that modulation level can be increased. It's like trimming hedges. That's how they best increase loudness. Those same peaks can punch holes in mod iron insulation... another benefit of clipping.
A simple but effective processing combination would be to use compression with modest attack times followed by a clipper to take out the peaks. The compressor bring up the average levels and increases perceived loudness and the clipper eliminates the peaks that do nothing for loudness and cause mod levels to have to be reduced.
VE3AJM
« Reply #24 on: October 26, 2014, 10:03:30 AM »
A lot of good information here on clippers. Just my 2 cents on this.
Yes, clippers can create nasty products up the down the band if they are conducting and the operator is leaning into them. But in the real world of operating AM under tough conditions from my observations, the stations that are also running 20-25kc of audio bandwidth using so called "good" engineering practices and that are "clean" with low IMD, can cause the just as much interference problems to co-channel QSOs as poorly used/designed clipping circuits.
Good engineering practice but very poor operating practice.
Al VE3AJM
Page created in 0.065 seconds with 17 queries.
