December 05, 2025, 08:28:47 AM *
Author Topic: Henry 2K-4 Power Supply Upgrade and Filament Fix  (Read 15724 times)
« on: September 02, 2014, 01:40:44 AM »
Many people use Henry amplifiers on AM to bump up the power from their Vintage tube exciters.
In the PDF file below is an upgrade to the Henry 2K-4 Power Supply and a fix for a filament supply problem that you may encounter in the future.  Smiley
* Henry 2K-4 PS Mods.pdf (737.35 KB - downloaded 838 times.)
« Reply #1 on: September 02, 2014, 07:25:06 PM »
That's pretty cool. What was the B+ before? was it an increase? I prefer an LC filter usually for regulation, what is the advantage of changing?
« Reply #2 on: September 02, 2014, 08:52:13 PM »
Thanks Pat.
Prior plate voltage with the old LC filter was about 3150V standby and 2750 loaded, measurements taken on 40 meters.
Advantages are:
1. Better voltage regulation, 200 volt drop standby to load instead of a approx. 500 volt drop,
2. Less cabinet heat generated from bleeder system and filter choke, bleeder power reduced to 28 Watts from 216 watts.
Addendum: Updated Schematics only.
Phil
And I would say the "soft start" circuit is a requirement for any power supply using only capacitor filtering.
AC0OB
* Henry 2K-4 PS Mods schematics Only.pdf (286.09 KB - downloaded 418 times.)
