May 06, 2024, 06:47:29 PM *
Author Topic: Polarity of oil cap  (Read 1971 times)
W9BHI
« on: May 24, 2014, 09:49:23 PM »
I have a General Electric Pyranol capacitor  CAT 23F406  8MUF  3000VDC.
It is for a Johnson DKW.
It was removed when I got it and has no polarity markings on it.
Any ideas on how to identify the polarity of the terminals or doesn't it matter since they are both insulated from the case.
Thanks,
Don W9BHI
« Reply #1 on: May 24, 2014, 09:54:02 PM »
Don,
With  rare exception oil caps don't have a polarity orientation and the one in the Desk KW certainly doesn't.  The only time I have seen a polarized oil cap was in a piece of mil gear where the case itself was the ground terminal and I think it was designed that way to fit in the minimum space possible.
By the way, be very careful feeding the cables when sliding the mainframe into the pedestal because it is easy to crimp a coax cable.  I believe I have already cautioned you about doing something about reinforcing the bottom rails in the pedestal to prevent them from spreading which would then result in a stuck mainframe with no way to pull it back out short of metal cutting.  That has happened to at least two Desk KW owners.
W9BHI
« Reply #2 on: May 24, 2014, 10:29:13 PM »
Thanks Rodger,
Now I can get that reinstalled in the unit.
I am going to install threaded rods between the lower rails in 3 places.
That should keep the rails from spreading.
Don W9BHI
KA0HCP
« Reply #3 on: May 25, 2014, 12:54:36 AM »
BTW, Pyranol caps have PCB oils, so wash your hands after handling them and avoid any touching any leakage.
