June 26, 2024, 10:44:56 AM *
Author Topic: Valiant Knobs  (Read 4745 times)
W7SOE
« on: April 03, 2014, 01:44:27 PM »
Anyone have a trick for replacing  missing white dots on the Valiant knobs?
Rich
N8ETQ
Mort
« Reply #1 on: April 03, 2014, 03:30:16 PM »
   I do
       Those little flags the Lawn People put on Your neighbors
grass to warn all the "Innocent" people of the "Toxic" danger.
The little white staff is perfect fit...
GL
/Dan
« Reply #2 on: April 03, 2014, 03:38:18 PM »
Go buy some lollipops. After using, cut the stems to a desirable length. Spray the stems with some clear spray to keep them hard. Dab some glue on one end and slip into hole. Let set.
« Reply #3 on: April 03, 2014, 04:17:27 PM »
Rich,
I have bought some in the past from Glen and have been pleased.  He also sells some custom made cables that plug int the XTAL jack on the back for antenna relay control.  Here is his URL:
http://k9sth.com/Page_3.html
Mc Master Carr has some as well.  They are not as bright white as Glen's, but still white.
Part number 97155A413
Price is $3.11 for 50 pieces
The Mc Master Carr sample is on the left one of the pair shown and K9STH's is the one on the right.
Hope that helps!
Joe, W3GMS
W7SOE
« Reply #4 on: April 03, 2014, 04:30:14 PM »
Thank you all for the suggestions!
Rich
« Reply #5 on: April 03, 2014, 05:28:11 PM »
Become an entrepreneur of Johnson white gizmo pointer inserts.
WB5IRI
« Reply #6 on: April 04, 2014, 11:38:00 AM »
Ahhh, McMaster-Carr. Great place. They also are a source for 1/4" long machine screws used in Multi-Elmac cabinets. A bit over $5 for 100. I only needed 4 -- anyone want any?
Doug, WB5IRI
ka4koe
It's alive. IT'S ALIVE!!!
« Reply #7 on: April 04, 2014, 01:37:59 PM »
Lollipops?? Are you serious???
Is there anything slightly Freudian about the brand "Dum Dums"?
« Reply #8 on: April 04, 2014, 02:22:45 PM »
Only if you feel insecure:
http://www.dumdumpops.com/
ka4koe
« Reply #9 on: April 04, 2014, 02:36:04 PM »
btw, my daughter absolutely loves your doggie avatar.
W8IXY
« Reply #10 on: April 04, 2014, 04:59:50 PM »
I found some plastic rods used in model building at a hobby shop.  Worked great.  Cut to about 3/16" and filed the tip round.   At spot of glue and good as new.
Ted  W8IXY
