Over at the shop we use the IX YS DE 475 102 N21A. A pair of these in parallel loaf along at 3KW RF out, class E with resonant sine wave drive. This is at 13.56 Mhz. It takes about 190V DC @ ~ 19 amps supply voltage to get there. I'd estimate the efficiency is mid 80's % if not a little higher. The sine wave drive hurts efficiency a bit. They are around $50-60 apiece.
If I were building an AM rig with 2 of those MOSFETs, I'd run the carrier at around 45 to maybe 50V at 5A to 6A for the pair, with the power supply voltage at 130 to 145V. That would provide enough voltage and current headroom. I think those devices will run nicely up to 10 meters and perhaps above.
