June 21, 2024, 01:59:32 AM *
Author Topic: Tested 4 of my 13 813's today  (Read 2130 times)
« on: October 26, 2013, 08:29:26 PM »
Thanks to Steve, W2TRH for the loan of his 813 tester.  3 tested really good, 1 was good but not so high as the others.  Onward to the other 9 813's.  Last time I knew, all were essentially new.  Some in box the rest carefully wrapped and stored.  Life is good. Gotta get with that push pull 813 modulated with triode connected 813's
Al
KB3DKS
« Reply #1 on: October 28, 2013, 09:59:19 AM »
What test parameters are you using?
« Reply #2 on: October 28, 2013, 10:22:16 AM »
Steve, TRH would know that.  I was told a variable 800 volt plate supply on a Variac is one parameter and I believe the screen voltage is also available on its own variable supply.  I'm guessing the CG is tied to ground - but that's a guess.
All of my tubes tested high emission with only one "sparkler."
Al
KB3DKS
« Reply #3 on: October 28, 2013, 10:44:30 AM »
Al,
OK, close to what I did awhile back. Used a regulated 1kv variable plate supply, a screen supply set to the textbook voltage and had a ma meter in the grounded grid connection so there was a small bias from that. Found most of my 813s were OK with a couple obviously beat up ones a bit weak. Used the same setup for some 814s and found a couple gassy ones. They lit up real nice inside.
Bill
« Reply #4 on: October 28, 2013, 02:03:02 PM »
Al,
Bill
Bill
I had just that one sparkler.  The rest tested like new so I'm a happy camper.  I have a spare for my ART13 and spares for the 813 transmitter.  Decades of pack ratting has paid off.  OH, one of those tubes was a pull out of my Eldico TR-1 which I (sadly) no longer own.
Now that I think of it - I have yet to test the 813 in my ART13.  That'll be cone ASAP
Al
