Roger Roger
Thanks for the info on the Hammarlund HC10. It might be worth looking into.
I understand what folks are saying about the Diode load on the 390A, but is there really a clear audio advantage to a product detector?
Hey Fred,
The product detector is kind of required for the
locally injected carrier which is strong and stable.
The recieved carrier is either fading (AM) or absent
(SSB). As long as the Local carrier can be phase locked
to the recieved carrier the adapter will enjance the
AM audio signal. Seems it takes less carrier to phase
lock a PLL than it does to properly demodulate an AM
sideband. Hence the need for product detector.(s)
On SSB the AFC is shut off to allow just the use
of the product detecter.(s) which is/was the point for
the CV 591 and the CV-157. The CV 591 does not suport
phase lock to the recieved carrier therefor is esentially
an external product detector relying on the stability
of the RX involved. With the CV-157 you can choose to
use the Recieved carrier or the Local carrier for
demodulation.
I assumed you were looking for the "Ultimate"
AM detector for HI-FI reception. If you just want to
copy SSB cleaner any of the above mentioned devices will
work fine.
Clear as Mud, right?
/Dan
