May 07, 2024, 10:20:50 AM *
Author Topic: Unequal sidebands on 40m, Valiant  (Read 15896 times)
ka4koe
It's alive. IT'S ALIVE!!!
« on: June 06, 2013, 10:10:56 PM »
Any idea why the modulation sidebands would not be symmetrical? The Valiant has a matched pair of 6146's for the modulator. The upper sideband is decidedly lower in strength than the lower sideband. Only on 40m have I noticed this. Should I swap the tube or B+ lead positions, or do I have something else at work here? The radio is buttoned up and running nicely on 80m and 20m. I understand that on 40m the VFO is prone to issues as it is at the fundamental of the transmitter. Everything is screwed down tight like its supposed to be.
One thinks they can enjoy the scenery for awhile and then something else pops up. Whichever one of you bozos convinced me to get a tube transmitter is on the FIRST KILL list.  Shocked
Seriously though, having fun and it looks great in the shack.
« Reply #1 on: June 06, 2013, 10:36:07 PM »
Might be FMing,  especially if the VFO's fundamental in on 40M.
How does the sidebands look like on other bands.
ka4koe
« Reply #2 on: June 06, 2013, 10:47:28 PM »
Looks fine everywhere else. I found a posting right after I posted this. Apparently, someone's Ranger 2 did it as well, but not with a crystal.
kb3ouk
The Voice of Fulton County
« Reply #3 on: June 06, 2013, 10:52:08 PM »
If it's doing what I think it's doing, there's some kind of phase shifting going on that is causing the lower sideband to somewhat cancel out, I've heard of some others saying they've had the same problem with other kinds of transmitters, they all had one sideband that was either weaker or in one case, not even there (USB with carrier from a plate modulated rig). Usually it seems like it always happens on a band where the VFO is running straight through. It's kinda like the concept behind how the old Kahn AM stereo method worked, something must be causing a slight amount of phase modulation, combined with a slight phase shift of the audio, which is causing one of the sidebands to cancel (in Kahn's system, by giving the proper phase shifts to the stereo sum and stereo difference audio feeds, then phase modulating the L-R onto the carrier, and feeding the L+R into the transmitter's modulator, it was possible to get the right side audio to appear on the upper sideband and the left side audio to appear on the lower sideband).
« Reply #4 on: June 06, 2013, 10:52:43 PM »
Most likely it's FMing.  OK with a crystal, OK on other bands.  FMing is the only thing left.  It would make the upper and lower sidebands look different on a AM trace.
« Reply #5 on: June 07, 2013, 08:47:24 AM »
Yep, look at the link below, then scroll down to "Detecting Incidental FM":
http://www.cliftonlaboratories.com/am_modulation.htm
W8JI has looked into the Johnson VFO's, and here is what he has to say:
http://www.w8ji.com/johnson_vfo_chirp_jump.htm
With the advent of SDR receivers, some of the highly desired BA AM transmitters are showing varying amounts of side-band imbalance. My Gonset G-76 on 15M with the internal VFO has a 30db side-band imbalance.  Huh
ka4koe
« Reply #6 on: June 07, 2013, 10:25:40 AM »
Interesting. Talked with some guys on the upper end of 40 last night, and didn't think it had any issues. Its just something, like your wisdom teeth, that you don't really think about, I would venture to guess.
I've cured the chirp issue "JI" talks about. Very simply fix and mine had it.
« Reply #7 on: June 07, 2013, 10:27:47 AM »
FM that follows the voice, not the FM that results by a modulator PS being shared with the VFO that has no regulation.  You will not hear that "pulling effect" because it is following the voice resulting in incidental FM.  That results in uneven sidebands. Here a paper from Agilent that explains it.
Al
* Pages from AGILENT AM FM PAPER.pdf (39.24 KB - downloaded 241 times.)
ka4koe
« Reply #8 on: June 07, 2013, 10:39:27 AM »
However, I did put the Beast in its cabinet last night as well as enough cabinet screws to establish a Faraday cage. Since I did this, I figure that any latent major problems will surface shortly. I term this act of brazen defiance "Tempting The Fates".
I find the WAAAA-UUUUMPHHH!!! that the transmitter makes when keyed very, very satisfying. So, I can understand the almost visceral appeal of these old AM warhorses.
ka4koe
« Reply #9 on: June 08, 2013, 11:57:42 PM »
Have had several 40m qsos with the Beast, and no one has complained. Someone with a pro setup said I was seeing the unequal sidebands correctly. So this will be relegated to the "things to look at in the future" tasker list.
Running around 390 mils to take some strain off the screens. It modulates 100% with the D104.
Philip
« Reply #10 on: June 09, 2013, 08:12:52 PM »
That characteristic whomp makes the Valiant seem a lot more burly than it really is  Grin  My GPT-750 barely makes a click when keyed.
ka4koe
« Reply #11 on: June 10, 2013, 02:30:45 PM »
My postings may have made me somewhat of a minor ham household name, eg. the time and a half I'd had fixing the Valiant. Seems like every other QSO I have on AM lately, I get asked..."Hey, are you the guy who's been posting on AMfone about the Valiant"?
Almost afraid to answer in the affirmative, but the replies have always been nice.
IN3IEX
« Reply #12 on: June 11, 2013, 01:46:55 PM »
Al
Right. FM with modulation index lower than the modulation frequency, for instance modulating with 1 kHz audio and 300 Hz delta f produces a spectrum that is similar to AM but sidebands (at 1 kHz from the carrier in this case) have opposite polarity. AM has sidebands with the same polarity. Therefore the right amount of FM over an AM modulated signal can produce AM with unequal sidebands. It is nearly impossible to see this effect on the envelope.
The envelope of single sideband AM looks identical to the envelope of DSB AM.
Technically SSB AM is better than DSB AM. It requires half the spectrum and sounds the same after a traditional AM demodulator.
Now it may require a SSB like generation chain (remeber the old Collins KWM2 AM mod).
Maybe combined AM plate modulated generation and a "touch" of FM could become a new topic for us to reduce frequency occupation.
Giorgio
ka4koe
« Reply #13 on: June 12, 2013, 06:00:21 PM »
This doesn't really sound applicable, and I believe simultaneous AM/FM is illegal. In any case, the FMing is a technical fault on 40m only, and may or may not have related to one of the big HV filter caps cooking off.
ka4koe
« Reply #14 on: June 19, 2013, 08:43:54 AM »
In related news, replaced the HV filter caps (blew up one as I had it in backwards) with a pair of Xicon 450V, 100 uF. No effect on the unequal sidebands. Swapped tubes. Also no effect.
Other than RF circulating currents, I have no other ideas on how to solve this issue, or whether I should even bother. On air reports on the 40M band are favorable, ie "good audio".
Should we move on? One doesn't really notice the lopsided sidebands unless you are listening/looking at me with a Flex or other radio with a panadapter.
Steve W8TOW
« Reply #15 on: June 19, 2013, 09:32:01 AM »
In regards to Johnson VFO's...I had the VFO in a Ranger Chirping on 40m CW
for years. After extensive rebuilding of the rig, still the Chirp, ONLY WHEN IN THE CABINET!
out of the cabinet it was clean...finally I was working on a friend's Valiant one
day and noticed the coupling shaft between the exciter & the cap was non-conductive...
I pondered this and looking on the spectrum analyzer, the Valiant was clean on all bands...
In short order, I pulled my Ranger, replaced the shaft between both caps with non-conductive
material...put it back in the cabinet...no more chirp...clean on all bands...
go figure...
73  W8TOW
WA9NQW
« Reply #16 on: June 19, 2013, 09:37:05 AM »
Speaking of Johnson VFOs and shafts, how is the "hot melt glue" coupler fix holding up?
Thanks & 73,
Jack
Jack
« Reply #17 on: June 19, 2013, 11:46:53 AM »
go figure...
Check out W8JI's analysis on the Johnson VFO issue in relationship to ground loops.
Joe, W3GMS
ka4koe
« Reply #18 on: June 19, 2013, 01:33:55 PM »
The repair seems to be holding. I'll likely end up redoing it with some plastic tubing. The reduction mechanism needs reworking with new grease. It seems to be holding calibration reasonably well.
WB4AIO
WB4AIO
« Reply #19 on: June 19, 2013, 06:08:20 PM »
AME (SSB with carrier) has around 35% distortion on a diode detector at 100% modulation.
Which stands to reason: it would be identical to a two-tone SSB test with equal tones. The envelope is not a sine wave; it is extremely pinched at the negative peak.
With AME, you also lose the diversity advantage of having two sidebands. That can be a very great advantage at times, as sync detector and PowerSDR users well know.
Kevin, WB4AIO.
« Reply #20 on: June 20, 2013, 07:27:58 AM »
I am wondering if there is a way to harness some incidental FM in a plate modulated transmitter? For example, if you are in a QSO on 3880 AM, and then a sideband QSO starts up on 3878. All of a sudden the receiving station has to tighten up the receiver bandwidth, and tune to your upper sideband. So in this situation, if the transmitting AM station could move more audio power to the USB, then communication capability is enhanced. Conversely, going on the offense, if the AM station boosts his LSB energy enough, maybe the 3878 sideband station will just go away, or perhaps move down to 3875... Cheesy
Perhaps the RF PA neutralizing capacitor could be tweaked either side of a feedthrough power null to create the desired effect since this would change the phase between a lead and a lag of the RF feedback. Then there is the audio phase variable.
To recap, if a plate modulated transmitter can have unequal sidebands due to incidental FM, is there a way to control the depth of the sideband energy lower to upper ratio, and is there a way to select which sideband, lower or higher, is the strongest? If so, this could be a valuable tool, perhaps a highly refined version of SBE.
« Reply #21 on: June 20, 2013, 11:53:02 AM »
First a clarification:
FMing, for the reasons already discussed here and elsewhere, will cause the sidebands to be unequal. However, to get partial cancellation/enhancement of one of the two sidebands, over the range of audio frequencies associated with the modulation, one would have to modulate the phase of the RF signal with the Hilbert transform of the audio signal that is already modulating the amplitude.
At any particular audio modulation frequency (e.g. when the modulation is a sine wave) FMing will result in the enhancement of one of the sidebands and the reduction of the other sideband. However the effect is smaller at higher modulating frequencies (actually inversely proportional to the modulating frequency), and therefore not useful for approximating SSB + carrier.
A way to see this is to note that using the modulating waveform, m(t), to modulate the frequency is the same as using the integral of m(u)du to modulate the phase. But the integral of m(u)du is not the same as the Hilbert transform of m(t). In the frequency domain, the integral of m(u)du is 1/(j x 2pi x f)) x M(f); but the Hilbert transform of m(u)du is j x M(f). The sign (I.e. j = -1/j) is not a problem, but the extra term: 1/(2pi x f) is a problem.
This is well known, and easy to prove using algebra and trigonometric identities, plus the approximations for sin(x) and cos(x) when x is small compared to 1.
The good news is that it is easy to introduce small amounts of phase modulation in the path between the VFO and the AM modulated RF output stage. Performing the Hilbert transform on the modulating signal, to obtain the input to the phase modulator, can be done with a classical 90 degree phase shifting network or by using modern DSP methods.
The bad news is that this approach (simultaneous AM and phase modulation) to enhancing one of the sidebands with respect to the other sideband will introduce large distortion products (unless the modulation index is very small, which would defeat the purpose intended here).
Whether this is a useful way of fighting QRM... versus the alternatives... including switching to another frequency... is not clear.
« Reply #22 on: June 20, 2013, 03:21:13 PM »
When one finds unequal sidebands in an AM broadcast op, it usually means the antenna system is too narrow-banded, henceforth overly reactive either going up or down in frequency.
In other words the sidebands check in, but they can never leave Tongue.
ka4koe
« Reply #23 on: June 20, 2013, 04:25:13 PM »
DG:
Find out how many geigers you have with that counter?
Also, I note that most of the unequal-ness is in the bandwidth below about 300-400Hz in the audio. After that, it starts to pick up and get more or less even. So, perhaps, for whatever reason it is, we gets lots of FMing in the low end. In which case, its NOT that big a deal, since most of the audio power for intelligibility is around 2 KC. Now, why it does it only on 40m, is anyone's guess.
I can't believe you're quoting math I haven't seen in years. I'll have to pull out my network analysis book and relearn Laplace transforms. Of course, Abe Lincoln's favorite equation was taking the indefinite integral of the reciprocal of cabin. The answer is log (cabin).
« Reply #24 on: June 23, 2013, 07:49:56 AM »
The waaa-uumph is probably the power supply / transformer recovering from the overload to go into transmit.
The table top transmitters were nice in their day. And had serious limitations, except for the Collins TX's. 32V1 was a brute transmitter!!! And no waaa-uuumph.......hi
