May 06, 2024, 05:45:16 AM *
Author Topic: Non-Digital Scopes - FYI  (Read 2176 times)
« on: May 28, 2013, 07:53:09 PM »
Got a couple of non-digital scopes off fleapay... one works, the other needs some help in the horizontal and vertical department, haven't tracked it down yet.  15mHz bandwidth.
The photo shows the IF out of the R-388, well it captured a section of it...
« Reply #1 on: May 28, 2013, 08:11:44 PM »
Wow, they're small !
I like the DC supply that's built in.  Those are lead acid 2V cells and they seem to last a lot longer than the newer single module types.
So it looks like you've got a running one and another for spares.  Can't quite get the brand name from the photo.
Cost - Good score?
« Reply #2 on: May 29, 2013, 08:35:34 AM »
hamfest cheap... one out of 10-20 bargains on fleapay I manage to win. Ah yes, the fishes that go away!
NLS, Non-Linear Systems
These have been around for a long time, they made various different models.
They're not Tektronix, but not half bad either.
I have a special project in mind for these, where I need a scope in a small space, with
a small CRT.
« Reply #3 on: May 29, 2013, 03:35:56 PM »
I have exactly the same unit.  They are really nice 'cause you can float them.  Nice triggering on them. Those gel cells are a much better batt than the NiCads that a lot of electronic units use.
Congrats!
« Reply #4 on: May 29, 2013, 03:39:20 PM »
I've had the same model NLS scope in my main road tool kit for over thirty years, still going, and only on the second set of gel-cells.
Really handy when you slip the little wire stand over your belt, and make it man-portable... Wink
