July 19, 2026, 11:41:21 PM *
Author Topic: Raspy AM carrier on 1920 kHz  (Read 15134 times)
wx3k
Vintage Ham Gear Enthusiast
« on: April 03, 2013, 11:04:04 PM »
HELLO everyone....
I have been poking around 160 and I hear a raspy AM carrier on 1920 kHz. I live in Northeast PA. I hear this carrier most evenings. It is weak. There is QSB on this carrier. Sometimes it does come up in strength.
I have tried two different antennas and still hear this carrier. After extensive listening, I have identified it as the 3rd harmonic on an AM radio station on 640 kHz. After further research on the FCC website and listening to their stream off their website, I believe it is WHLO in Akron OH.
http://www.640whlo.com/main.html
Using a ICOM PRO 3 as a receiver.
Does anyone else hear this signal HuhHuhHuh?
Stephanie WX3K
Eico 720/722/730  HRO50T
"Thunder is good; Thunder is impressive but it is lightning that does the work" ...Mark Twain
wb8uhz
« Reply #1 on: April 04, 2013, 11:42:36 PM »
   Stephanie
Yes there is a harmonic from 640 Toronto on 1.920. The station is working on the problem. In Michigan where I'm located the signal can be above S9 at times and the audio is understandable.
73 Tim
WB8UHZ
« Reply #2 on: April 05, 2013, 08:13:36 PM »
Sooooo.... what does a 50KW low pass filter look like?
wx3k
« Reply #3 on: April 05, 2013, 10:56:12 PM »
Really ?   Shocked
I suppose they carry similar programming.....I tried listening to 640 and all I heard were a bunch of stations all competing with each other.
How do you know they are working on the problem ? Did you call them ?
   Stephanie
73 Tim
WB8UHZ
Stephanie WX3K
wb8uhz
« Reply #4 on: April 06, 2013, 12:20:05 AM »
       They believe it is their ground system. And yes when asked I have assisted.
 I started hearing the station several months ago. First on an Orion,  then a Flex then an R8B. They want to fix it of course.
« Reply #5 on: April 06, 2013, 01:30:14 AM »
Every BC transmitter built in the last 50 years has very efficient harmonic suppression built in.
Two reasons: Regulations spelling out just what levels are allowed, and that energy going out the line costs $ to make.
A link to a treatise on the subject: http://www.hatdaw.com/papers/review_of_harmonic_suppression_practices.PDF
Canada pretty much follows the US in technical broadcast rules.
A BC antenna matching unit is typically a "tee" net, providing a match from 50Z to whatever the tower impedance is at the op freq.  That further 'losses' the harmonics, but at that point they are many dB down already.
The station in Toronto must have a really dicey antenna system to cause a 3rd harmonic of that magnitude, maybe something corroded causing re-radiation.
« Reply #6 on: April 06, 2013, 07:32:48 AM »
From what I've read, a T is a high pass network.  They seem to be pretty common tuning house networks for AM towers.   I got a Heathkit SA-2040 tuner from an estate a couple of years ago.  As soon as I found out it was a T network I sold it because of the high-pass property.
« Reply #7 on: April 06, 2013, 08:07:30 AM »
There are high-pass T's, and there are low-pass T's
If the series elements are capacitive, then it is a high-pass
If they are inductive, it is low pass.
AFAIK
« Reply #8 on: April 22, 2013, 04:11:57 PM »
Low pass has DC continuity from input port to output port.
High pass does not.
« Reply #9 on: April 22, 2013, 09:40:23 PM »
  Stephanie
73 Tim
WB8UHZ
Toronto has 50KW on 740 which is a flamethrower over a good part of the US with some great music.
« Reply #10 on: April 22, 2013, 09:46:25 PM »
What does that have to do with the subject? The frequency in question is 640 kHz.
« Reply #11 on: April 23, 2013, 09:11:14 PM »
I thought the 640 Toronto was in error but later tuned it in. Sorry if I disturbed you with a one line comment.............
« Reply #12 on: April 23, 2013, 10:33:06 PM »
Dammit Carl, you woke me up!  Grin
wb8uhz
« Reply #13 on: October 08, 2018, 06:35:50 AM »
  The cause of the harmonic from 640 to 1920 was found to be from an antenna the 640 station was leasing space to on their tower. The problem has been corrected for a couple of years now.
73 Tim
WB8UHZ
