November 26, 2025, 06:59:34 AM *
Author Topic: Transistor data sheets  (Read 1736 times)
Don, W2DL
« on: March 09, 2013, 08:46:44 AM »
Hi everyone,
I have an Astro 102BX rig that probably has a dead final transistor. It uses a MRF 335 and a MRF 338, but I can't find any data sheet source that has these on it. The rig mfg date is 1980, so the data sheet(s) must be way back there somewhere. I want to try some newer transistors but need to find out what the parameters are for the original ones.
Don, W2DL
Don, W2DL
57years a ham!!
W4AMV
« Reply #1 on: March 09, 2013, 09:13:53 AM »
Hello Don. The MRF338 per Moto was replaced by and equivalent to the MRF393. This device is in the so called GEMINI package as it has 2- matched pair of bipolar devices that are internally Z matched. It is 100W 30-500 MHz, intended for 28V operation, 8.5-9.5 dB gain. Before I scan in this data sheet, to be sure, is this the correct package for your unit? It is in a ceramic package and has 4- input, 4- output tab leads. I have an older Moto text, but need to search.
Alan
Page created in 0.042 seconds with 17 queries.
