November 26, 2025, 03:41:29 AM *
Author Topic: ID transformer please?  (Read 3576 times)
« on: March 02, 2013, 10:42:55 PM »
Can anyone ID this filament transformer for the insulation or working voltage rating?
G.E. 7477922
5V@7A
or what  came out of?
thanks!
wa3dsp
« Reply #1 on: March 03, 2013, 02:55:57 AM »
Well unless someone either knows that transformer or has data you are going to have to guess. I looked at the 5V filament rectifier tubes and an 866B is 5V @ 5A but it may have been used in a full wave circuit with two tubes. So maybe a pair of 3B24's.  What did you intend to use it for? I would suspect it is rated at least 2-3K volts.
« Reply #2 on: March 03, 2013, 04:19:07 AM »
If was used for HV rectifiers it would normally have HV insulators on the the 5 volt terminals.
« Reply #3 on: March 03, 2013, 11:51:41 AM »
It has insulators about 1/2" tall.
The job is for an 8020 vacuum diode's filament, so it is not the usual 866 or 872 which wants 5A. The filament current is stated as 5.5 to 6.5A.
I believe an open frame 5A unit would do it because it could cool itself.
It's for a negative peak limiter. It will see 7KV peaks if it's right to say that B+ of 3500V plus  100% modulation makes 7000V.
The goal is not to exceed 100% positive by any impressive amount, just prevent the B+ hitting 0V.
If Ashtabulah Bill could run tube diodes on this modulation limiter so can I. It's a question of finding suitable transformers. In the video it shows he used three 866's. He used them for ultramodulation but then he had a bigger modulator. I only want to clamp the negative peaks to 350V.
The diagram shows what I want to do. I'm putting the main parts on the chassis now.
« Reply #4 on: March 04, 2013, 03:33:45 AM »
You will need a xfmr with high voltage insulation.  10KV rating should be the lowest you should use.   Using SS diodes is a lot easier.
« Reply #5 on: March 04, 2013, 09:10:44 PM »
I will temporarily use a plug-in replacement for the 8020. It's almost twice as tall as the 866 type stick and the same diameter. More diodes inside I guess. It might need some resistance in series.
I agree it is easier with a SS rectifier.
nothings etched in stone, it might not even work in real transmitting. I tried the idea before with high idle on the 4-1000 and some audio and a battery supply sitting on a piece of thick plastic for the heater.
If nothing turns up I will have to find a  suitable trans. and wind a new secondary with some HV wire. I guess it is not that hard and then I can choose the insulation level by the spec of the wire and wrap the core in nylon tape or something to avoid sharp edges, correct?
