April 26, 2024, 08:17:33 AM *
Author Topic: Making a Halli SX-62B from a SX-62A  (Read 2313 times)
AB3FL
« on: February 13, 2013, 09:28:20 AM »
I am trying to add the AFC circuit from the Halli SX-62B to my SX-62A.  The schematic shows a 1n3182 varicap/varactor diode doing the dirtry work.  The NTE replacement is NTE614 which I have.  I have wired everything up exactly as the SX-62B, but it seems to be working as an anti AFC.  It only works on Band 6(52-108MC).  It is fed from the Discriminator which would be at 0 DCV when everything is properly tuned.  When I turn on the AFC, it jumps up or down too far.  Example if I zero the discriminator it will jump to roughly -1.6VDC or +1.6VDC.  It will never lock at zero.  The diode is not backwards.  I have attached the SX-62B skizmatic
thx
Tom - AB3FL
AB3FL
« Reply #1 on: February 13, 2013, 03:37:17 PM »
I got it working.  Damn discriminator.  Hardest thing to align even with a Heath IG-57A sweep generator and a scope.
Tom - AB3FL
Edward Cain
« Reply #2 on: February 13, 2013, 05:54:45 PM »
Hi Tom,
   Can you tell us more about what the problem was. I may try this mod on my 62.
Thanks,
Ed
AB3FL
« Reply #3 on: February 16, 2013, 10:31:38 AM »
What is the nominal voltage swing on the outpooot of the discriminator?
Tom-AB3FL
Page created in 0.048 seconds with 16 queries.
