May 01, 2024, 12:06:39 AM *
Author Topic: How do I clean without damaging original wiring  (Read 3690 times)
kv5i
Me & best friend John-W5ZKT(SK)
« on: January 23, 2013, 01:38:44 AM »
I am working on a Collins 32v. After all these years it is discolored to the point of not being able to tell the color code. Any advice on what and how to use, to retain the original wiring?
Thanks,
ed-kv5i
There are more things in heaven and earth, Horatio,<br />Than are dreamt of in your philosophy. <br />- Hamlet (1.5.166-7), Hamlet to Horatio
« Reply #1 on: January 23, 2013, 09:49:29 PM »
Some old wiring with waxy material will come back to color with application of heat. Also some WD40 may help, but that isn't so good either. An old guy I knew used to take a propane torch and pass it along the harness. A lighter under a wire, on old transformers, to bring the colors out. These are probably not good suggestions and much wire insulation isn't the old waxy type.
KB5MD
« Reply #2 on: March 22, 2013, 10:52:51 AM »
The propane torch is also a great way to let the smoke out. Wink Wink
« Reply #3 on: March 22, 2013, 11:10:30 AM »
About a half and half mixture of 409 and Ammonia (cleaning type) and a paint brush.
Liberally apply/scrub and rinse off withe a hose.
Remove any meters and try not to spray water directly into any transformers/I.F. cans.
Bake in oven on WARM setting (190F) for 2 hrs.
Did that to many 32V's and Rangers when I was doing some piece work for Howard Mills W3HM. Chassis and wiring looks like new.
wa3dsp
« Reply #4 on: March 22, 2013, 03:56:51 PM »
You will have to experiment to make sure there is no problem but I have had great results with Krud Kutter available at Lowes and other places. It is a green product but a very good cleaner. I spray down the entire chassis being careful not to get it in transformers, IF's etc.  On really dirty areas I use a stiff brush. Then I use a sprayer in a sink and very hot water and rinse with that. Always let things dry for a day or two in a warm area before applying power.
Page created in 0.073 seconds with 18 queries.
