May 27, 2024, 02:23:21 PM *
Author Topic: HELP..TS140 gone deaf..  (Read 2575 times)
ve6pg
« on: September 16, 2012, 04:17:25 PM »
  i was tuning up on 40 with my viker2, my '140 was listening fer the sig...i tuned up the viker, all ok there...but the '140 has gone deaf..if i crank up the volume, i can hear...but damage somewhere..tx output from the rig is fine...is there a diode/resistor that may have blown, to protect the receiver?  if so, where, and what value?...
..tim.
..sk..
« Reply #1 on: September 17, 2012, 03:10:32 PM »
Tim,
   So ho much RF did the 140 take in? Was it connected to another antenna, or direct coax to the Viking II acting as a dummy load? If it was direct connected, was the loading changing on the v2, and did you smell anything?
ve6pg
« Reply #2 on: September 17, 2012, 08:41:19 PM »
  well, i did smell something..the 140 was not connected to anything, directly...i have a ameco pre-amp connected to the 140, but it was not turned on, or active..the tx is fine, receive is deaf..
..tim..
  ..sk..
« Reply #3 on: September 19, 2012, 06:51:26 PM »
when the ameco is turned "off" and if it still permits receive, then it is likely a direct connection... I do not have a print on the 140, but I seem to think there is a small fuse for receive protection in there, I think there was one on my TS120. I may be dreaming this of course...
Does it have a calibrator? Turn on the calibrator and see if it works... it is a built in signal injector in effect. That will tell you if the problem is just in the front end... probably is...
Somewhere there is probably a schematic to look at... online?
Page created in 0.031 seconds with 18 queries.
