April 28, 2024, 07:05:21 AM *
Author Topic: 4-1000A grid driven transmitter layout  (Read 21496 times)
N4LTA
« Reply #25 on: August 03, 2012, 06:22:09 PM »
Older editions of the ARRL Handbook describe running a GG amp in class C. In fact thats is how they describe a GG amp - Run in class C and AM modulated. GG does not mean the amp is linear - it depends how it is biased.
The older Handbooks indicate that GG is only worthwhile if you have excessive drive to pay for the simpler circuit (they are talking about AM operation.
If you plate modulate a GG amp that is biased for linear operation, you will get non-linear modulation.
Pat
kb3ouk
The Voice of Fulton County
« Reply #26 on: August 03, 2012, 09:48:26 PM »
As I saw on here a while back, back under the kw input rules, it was possible to run a carrier power that was over what you normally got from a kw input if you ran a grounded grid final. The tube that was mentioned as being used was the 304TL, which also needed to be biased to run well in GG service. But how it worked was the drive that was passed through the final added to the power that the final tube produced. The final would be working at a kw input, but the drive power would add up to that carrier to give more power.
« Reply #27 on: August 04, 2012, 12:38:22 PM »
A 100W driver is more than enough to drive a swamped grid Class C 4X1, about 500-600 Ohms will do it depending upon plate voltage. A 4D32 or a couple of 6146B, both at 700V, should have plenty of reserve. Design the pi net to directly match it and dont worry about no stinkin baluns Grin
« Reply #28 on: August 04, 2012, 02:10:53 PM »
Pat,
      If you really want to get down with yo bad self, build a GG 2-holer. I have a filament transformer here for that specific application. If you're interested, you can have it for the shipping. I'll fire it off and test it, give it a hi-pot, box it up and send it off your way.
You will be da boss wit da hotttttt sauce ! ! ! ! ! ! ! !    Grin  Grin
« Reply #29 on: August 04, 2012, 02:23:42 PM »
Better to use it on a 3CX3000A7 or F7 if you dont need to watch the light show Grin
KC2ZFA
« Reply #30 on: August 06, 2012, 02:27:02 PM »
Grid driven, but NOT swamped. Just biased way down in class C. (-150 or 200v IIRC)
The heavy biass and low resting carrier screen voltage is what keeps it so stable. there isn't even ANY control grid circuitry in the final deck. The grid lead comes right off of the socket into a piece of RG-142 double shield coass and goes out up to the exciter where the drive and biass is sent down the line to it.
Slab, how long is that RG-142 run ?
Peter
« Reply #31 on: August 07, 2012, 09:05:40 AM »
Slab,
Peter
Peter,
          If memory serves me correctly, without opening up the transmitter decks, I would say it's somewhere between 12 and 18". Also I peeled some of the clear outer skin off and soldered ground lugs (and grounded them) just about everywhere I could.
So that way the floating length of the coass is no more than a few inches for it's entire run. Kinda like running through a piece of RF resistant pipe for sake of analogy.
This way there is also no chance of the outer braid "going hot" at some wierd frequency and the final then passing it.
« Reply #32 on: August 07, 2012, 02:40:53 PM »
What no magic beads on the coax?
KC2ZFA
« Reply #33 on: August 07, 2012, 04:30:33 PM »
Thanks Frank.
And the capacitance of the cable is in parallel to the tube's input capacitance, right ?
« Reply #34 on: August 08, 2012, 09:43:40 AM »
Thanks Frank.
C'mon, Frank, with the outer shield slobbered to ground every 2" or so, it shold have no trouble staying at RF ground potential and maintain it's shield effect.
(not to mention stay EXACTLY where you want it ) Don't forget that the inner conductor is carrying both RF and DC by design. That double shield silver teflon stuff is just great to work with. The silver plated braid just sucks the slobber right in, and with the teflon insulation, you can really pour on the heat without having to worry about melting and shorting it! ! !
Peter,
        the small amount of capacitance from the coass is not even noticed at those lower frequencies. The tune cap in the driver tank is more than capable of tuning it out.
N4LTA
« Reply #35 on: August 08, 2012, 10:22:07 AM »
Slab,
What type of driver tank are you using - a simple parallel tuned network with the cold end grounded through a capacitor?
Pat
kb3ouk
« Reply #36 on: August 08, 2012, 01:14:52 PM »
http://amfone.net/Amforum/index.php?topic=16319.0
Here's a post on Frank's 4-1000 rig, includes a schematic of the final amp.
« Reply #37 on: August 08, 2012, 01:46:35 PM »
just being a jerk Frank
« Reply #38 on: August 08, 2012, 01:56:49 PM »
Slab,
Pat
See attached PDF
* driver.pdf (10.01 KB - downloaded 220 times.)
« Reply #39 on: August 08, 2012, 02:19:35 PM »
I hope Frank lives long enough to wear out all the 4-1000s he got from me.
I hope I do also
I hope we all do
« Reply #40 on: August 08, 2012, 02:34:48 PM »
I hope I do also
I hope we all do
I do too! ! ! ! ! ! !
they are some tough bottles!!
After 12 years of running with the plate glowing pretty red,
I am still using the first one I bought when I built that thing!
I still say they are the best bang for the buck when it comes
to BIG power tubes. Good used pulls are still fairly cheap and
plentiful.
« Reply #41 on: August 08, 2012, 03:04:17 PM »
So you have not used any of the tubes you got from me yet.
N4LTA
« Reply #42 on: August 08, 2012, 03:19:46 PM »
If anyone has a 4-1000A that they don't need - I could use a spare for this transmitter.
I have one pretty decent looking pull that has no color on the glass.
Pat
N4LTA
« Reply #43 on: August 09, 2012, 08:53:03 AM »
Light the filament off first and make sure it hasn't lost it's vacuuuuuuuuuum.
They do have a slight tendancy to develop leaks around the pin seals.
Nah, the original one just won't die! ! !  It has outlived 3 plate transformers, though.
Page created in 0.063 seconds with 18 queries.
