June 09, 2026, 10:55:23 PM *
Author Topic: Omni VII on AM?  (Read 18436 times)
« Reply #25 on: October 14, 2012, 09:57:55 AM »
Only asking 15 watts carrier should be a pretty good ALC defeat already especially is the mic gain isn't too high.
I've heard some TS-590s that sounded OK. Same for the K3. OK means enough audio, audio response sounds like a human transmitting.
« Reply #26 on: October 14, 2012, 10:34:39 AM »
I have a question concerning a modern SSB rig with AM capability, and this includes the Omni VII. On AM when the audio peaks go above 100%, does the negative cycle stay on the baseline (like plate modulation), or does it reverse phase and make a "wavelet"? Whenever a "wavelet" is generated, we have DSB with reduced carrier. Here in order to receive without distortion, you must use either a product detector, or a synchronous detector. A BA with a diode detector will follow the "wavelet" and the resultant audio will sound like hell.
So if the Omni VII makes "wavelets", then hitting 100% modulation should be done cautiously so that only an occasional "wavelet" is generated.
I attach a picture of a "wavelet" being generated from my Central Electronics 20A where the upward modulation is at 140%.
« Reply #27 on: October 14, 2012, 09:23:17 PM »
The answer depends on the waveform feeding the balanced modulator.
Sinewave will do what you show.
Properly polarized asymmetrical waveforms will simply exceed 100% positive long before creating wavelets.
The junk you heard me with on 10 meters today does just that. It is more forgiving of my slow peak limiter than plate modulated gear. A wavelet or 2 doesn't seem to be a problem once in a while. Same processing on a Valiant needs less density in order to not whack the baseline.
