Offline
« on: July 21, 2012, 11:54:32 PM » |
I was told that a silver plated tank coil can have an increase of 10 to 15% effeciency as the Freq goes up. I was told that on the low bands the difference is little. I saw how my new J500 makes the same efficiency on the low vs high band and it has a silver plated coil. Anyone every use this: http://www.cool-amp.com/cool_amp.htmlIts a do it yourself way to silver plate a tank coil. C
KA0HCP
Offline
« Reply #1 on: July 22, 2012, 12:57:21 AM » |
Previous discussion on another board, the engineers conclude: silver plating is good for cosmetics and corrosion resistance but makes no difference to RF below UHF because the layer is too thin to help surface effect.
New callsign KA0HCP, ex-KB4QAA. Relocated to Kansas in April 2019.
Offline
« Reply #2 on: July 22, 2012, 01:14:41 AM » |
That is interesting. The guy I spoke with did tests on his rig and saw improvement. Thanks for the comments! I know that as far as improving the efficiency, the plate choke is the first place to go. The modern computer designed plate choke that is sold by RF parts, has produced BIG gains on my rig on the higher bands. I just wondered about the plating.
KX5JT
Offline
John-O-Phonic
« Reply #3 on: July 22, 2012, 03:48:49 AM » |
I think the reason we see great performance on the high bands on our Johnsons is simply because they DO use high quality overrated parts in the tank, silver plated or not!! Good engineering... they included 10 meters so they made it work right!
AMI#1684
KD0HUX
Offline
« Reply #4 on: July 22, 2012, 06:32:51 AM » |
I AM OF THE VERY SAME THOUGHT
N4LTA
Offline
« Reply #5 on: July 22, 2012, 10:06:58 AM » |
I silver plate some of my PC boards and my copper tank circuits but for cosmetic purposes as I have heard that the plating is too thin to make a difference unless you use very heavy electroplating. I have a simple immersion formula that works great for a quick thin coat. It uses silver nitrate and sodium thiosulfate (photo hypo). A quick dip makes things sure look pretty.
Nitrate based immersion silvering bath:
15 gm silver nitrate 30 gm sodium tiosulphate (Sodium Thiosulfate) 10 gm ammonium chloride 1 lit water
Dissolve nitrate in 50 ml water,add chloride dissolved in 5o ml water,to this mixture add tiosulphate dissolved in 9oo ml water
It cost about $20 for a liter as the silver nitrate is expensive now.
Pat N4LTA
aa5wg
Offline
« Reply #6 on: July 22, 2012, 10:10:31 AM » |
I have used Cool-Amp and have found its effect to be cosmetic rather than improved efficiency. I contacted silver plating companies and the thickness of silver they use was measured in micros of an inch. At HF this is cosmetic.
My silver plating papers are not in front of me but if memory is correct then to gain efficiency one has to silver plate in fractions of thousands of an inch (not microns of an inch) up to a thousandth of an inch or so. The thickness for improved efficiency varies on the frequency in use.
I know this is a vague answer but in most applications the effect of silver is cosmetic at HF.
Silver will help slow the oxidation of the copper. As you know silver will also oxidize. When I build a coil I give it a thin coat Caig Laboratories products such as DeoxIt or similar based products to slow the oxidation.
Chuck
W4NEQ
Offline
« Reply #7 on: July 22, 2012, 12:18:40 PM » |
Can any of the chemists in this group recommend an electrolyte solution for electroplating Silver onto copper that does not use cyanide or extreme acid ?
Chris
Offline
« Reply #8 on: July 22, 2012, 12:34:00 PM » |
Not an electrolysis solution, but: Clean copper to scoured shine. Polish with rouge. Clean and Dry thoroughly. Preheat piece in N2 atmosphere. Dip in molten, 99 pure silver with all slag possible removed. Dip again to achieve desired coating thickness. Drain excess Ag into w4neq coin minting molds. Spend coins for professionally crafted coil.
RICK *W3RSW*
KA0HCP
Offline
« Reply #9 on: July 22, 2012, 02:11:27 PM » |
Computer designed plate choke that improves efficiency?
Can you give us a point to that? (I didn't find anything quickly at RF Parts).
N4LTA
Offline
« Reply #11 on: July 22, 2012, 03:01:53 PM » |
I have used the cyanide electroplating method. If you are not familar with chemisty, I'd not recommend it, but it works very well. It is the best way to plate a heavy coating on. You need to do it outside or under a hood.
You need silver chloride but you can make it yourself easily by desolving coin silver in nitric acid and precipitating out silver chloride by mixing table salt with the disolved silver. I used a 1 oz silver bar as the sacrificial electrode. It worked very well.
I still have most of a Kg jar of sodium cyanide left from my experiment years ago. It's not easy to get rid of.
The Caswell suff is very expensive - you can have it done cheaper than buying the Caswell chemicals.
Pat N4LTA
Offline
« Reply #12 on: July 22, 2012, 03:47:42 PM » |
What advantage or disadvantage is there to (solder) tinning a coil vs. using silver or leaving it bare?
Offline
« Reply #13 on: July 23, 2012, 08:58:23 AM » |
I did a thread here about a year ago on a process that is safe and only needs 3 or 4 amps to do a great job. Chemicals cost about $40. My Brother, a Jeweler turned me on to the company he deals with. There is a link in the thread. We silver plated a bunch of copper straps. It looks nice but may help on higher HF bands
Offline
« Reply #14 on: July 23, 2012, 10:25:13 AM » |
Seems like it would be cheaper, and much easier to wind your coils from silver wire to begin with.
Or, maybe better, and definately cheaper would be Sterling Silver Filled Wire. Which is basically brass wire, coated with silver.
Not sure what Guage is needed, but 16 guage SSF is still less than $4 per foot.
KZ5A
Offline
Vikings Rule!
« Reply #15 on: July 23, 2012, 12:33:59 PM » |
The RF Parts plate choke (@$24.95) is also available from Ameritron for $20.00. I plan to use one in my BTA 1R1 multiband conversion. http://www.ameritron.com/Product.php?productid=10-1519773 Jack KZ5A
73 Jack KZ5A
Offline
« Reply #16 on: July 23, 2012, 01:53:43 PM » |
When I was still gainfully employed, largely at taxpayers expense at a large defense company, I and a few others ran substantial tests on the silver plating issue; on our own time of course From 2 to 250MHz there was no measurable difference at small signal levels or the 150W from the distributed amp used. Surface area was the only parameter that mattered. The silver plating was real Mil Spec, not brushed on. At 222MHz at high power there may be a small benefit and at UHF it appears to be universally accepted altho the 4CX250B cavity amp I built using copper pipe still puts out the same 250W on 440MHz FM at the same predicted efficiency as built around 1988-89 My bare copper flat plate 2M 3CX1000A7 amp has no problem at 1500W in the 25 years Ive been using it....no sign of any heat discolaration and the tuning doesnt drift during long key down testing. The only choice in an amp is to size the conductor properly and surface area matters. This means that a 1/2" diameter flat strap is more efficient than say a #6 wire or 1/4" tubing at 10M at the higher power levels since copper conductivity takes a nose dive when overheated. While many use well sized coils they then go to #14 or 12 as tap wiring to the switch, coax connector, tuning caps, anode, etc and defeat the purpose. It may be OK in a very compact amp with say a 3CX800 or 8877 and minimum lengths but the typical 4X1 amp has individual leads spread out a foot or more and then they wonder why its a dog on 10M, even with a new tube.....and sings like a birdy to boot. It also helps to have a tube thats still fully efficient at say 120-200MHz + for an amp that includes the higher HF bands. For you guys that believe the world ends at 7295KHz then most anything will work and this thread is moot. Carl
W4NEQ
Offline
« Reply #17 on: July 24, 2012, 08:46:21 AM » |
Carl's comments confirm the research I've done over the years. Thick, edgewound coils - common in the broadcast industry offer Q's that reach over 600 and are good for 20 amps without heating. They are silver plated, perhaps not so much for increasing Q, as to decrease the rate of corrosion and tarnish - which they do much better than bare copper. With long-term corrosion prevention in mind, and a periodic need to move the adjustment clip (or roller) - is there any good alternative to Silver plating ?
Chris
Offline
« Reply #18 on: July 24, 2012, 03:04:03 PM » |
Thanks for the information Carl. I think I might try some simple upgrades to the wiring and report my findings.
W4AMV
Offline
« Reply #19 on: July 24, 2012, 05:32:58 PM » |
One skin depth of copper and silver at 1 MHz is about 2.5 mils. Much much less at UHF. At UHF for cavity construction and unloaded Q its worthwhile and not very costly. At HF just beef up the gauge of Copper rod or strap, just not worth the effort and probably will not see its effect on Q. As a rule 4-5 skin depths would be nice and 10 mils of silver at 1 MHz is costly!
Offline
« Reply #20 on: July 25, 2012, 02:02:59 PM » |
Ok. Got it.. I studied the two tanks and what I found is what carl was saying. The coil is large diameter copper but the wiring is solid 16awg wire running from the swtich all the way back to the loading cap switch. no strap. That is likely why, alot of these radios fall off as you go up in Frequency.
Offline
« Reply #21 on: July 25, 2012, 06:21:15 PM » |
A note to silver users:
Oxidized silver turns white. Pretty rare in reality.
The black tarnish you see is silver sulphide, mostly brought on from atmospheric sulfur.
W4NEQ
Offline
« Reply #22 on: July 25, 2012, 06:41:52 PM » |
So, avoiding abrasives which might scratch through the thin plating, what's the best way to clean all this nastiness off of silver plate?
Chris
Offline
« Reply #23 on: July 26, 2012, 06:44:33 AM » |
Re-quoted for Truth. There's a LOT of ill-advised advice going around to the effect of "don't worry about that black on the silver, silver oxide conducts electricity as well as silver". Unfortunately as TFO pointed out, that's NOT silver oxide, and it does NOT conduct electricity well! Tarn-x makes easy and fast work of removing tarnish (silver sulfide). And you can tell - the chemical reaction results in a sulphur smell.
Offline
« Reply #24 on: July 26, 2012, 10:46:41 PM » |
So Tarn-X does not harm the silver? The Silver Sulphide is the result of harm already done?
