April 29, 2026, 11:05:38 PM *
Author Topic: A few short stories dad asked me to post for him  (Read 123597 times)
w8khk
« on: July 14, 2012, 01:49:43 PM »
I had many long talks with dad during his last few months at home.  There are a couple stories that he had wanted to post, but just never was able to complete them.  He asked me if I would compose the text to share with all his friends on AMfone, and I assured him that I would do it as soon as possible.  One relates to some very early "hi fi" operating before FCC restrictions on AM content, and the other story dates back to his time as an FCC monitoring operator at the Allegan, Michigan FCC Monitoring Station.  I will do my best to include the content as accurately as possible.  Last, I will share a memory of my childhood, while listening to dad operate on 75 meter phone.
"AM in the Early Days of Ham Radio"
It was in the late thirties, I believe dad was around 17 or 18, living in Mt. Pleasant, Michigan.  He was running a homebrew 250TH rig modulated by four TZ-40s in push-pull parallel.  He used a velocity (ribbon) microphone, made by Amperite, (I still use that mic on occasion) feeding a speech amplifier with push-pull 45 triodes.  No steps were taken to limit the bandwidth, in fact the amplifier was used as a PA system component for many years.  He was still using that speech amplifier as W2FCY, (Dayton, New Jersey) in the 50s when I watched him talk with my grandfather (W8YNG) in Michigan.  At that time the 45s were replaced with 2A3s.
One of Dad's other loves was music, and he played the piano, trumpet, and string bass.  He had another ham friend, I believe in Ohio, who also enjoyed music.  In the late thirties, the FRC (Federal Radio Commission, predecessor to the FCC) had no restrictions on modulating a ham rig with music.  So Dad would get on 75 meters, and his friend on 40 meters.  Receivers and transmitters were operating simultaneously, on different antennas.  (A trap was needed on each receiver to reject the local transmitted signal.)  Dad played either Bass or Trumpet, and his friend would play piano.  They were able to practice and improvise in order to prepare to play together for live events.  He remembered setting a timer so that he could interrupt the music for periodic "station identification".   Perhaps this was the first simulcast event, which could be received in "stereo", if people had two receivers and knew where to tune!
"The Importance of CW"
Dad and several of the other fellows at the FCC Monitoring Station in Allegan, Michigan would periodically use a key and tone oscillator, or they would whistle Morse code across the room in idle chatter.  One afternoon they started a Morse discussion about the appearance of the administrative assistant, Miss Harriette Koster.  She was typing at the time, on two sheets of paper with a sheet of carbon paper in between.  When they finished their Morse conversation, she removed the paper from the typewriter, and handed a copy of the text to each of the Morse participants.  Little did they know she was proficient at copying Morse code!  Needless to say, each of the "gentlemen" blushed and were both quite embarrassed at the situation.  But it appears that all the comments were in good taste, because a few months later Mr. Walter Maxwell proposed to Miss Koster, and they were soon married.  Perhaps I, and all my siblings, owe our lives to Morse code.  Needless to say, I was displeased when the FCC dropped Morse proficiency from the amateur licensing requirements.
"Are Hams Liars?"
When I was about four years old, dad was once rag chewing on AM.  He was telling folks that he was working 75 meters. I thought I knew what meters were, and I had rudimentary counting skills.  I counted his meters, one in his HRO, one in his vacuum tube voltmeter, three in his Weston tube tester, five in his six-foot rack containing push pull 304TLs modulated by the quad of TZ-40s.  I counted a total of ten meters!  Why would he lie about something like that?  After he signed with the other operator, I told him I counted only ten meters, and he quickly explained that 75 meters is the wavelength of the transmitted signal when operating between 3.8 and 4.0 megacycles.  He then drew graphs of the relationship between frequency and wavelength, and explained that historically people referred to the bands by wavelength instead of frequency.  Then I understood why my short wave receiver had all those numbers in backwards order - wavelength!  This was one of the first of many of his teachings that enabled me to have an enjoyable and rewarding career in electronics.
"Color TV"
To break the ice, dad often liked to relate this tale at the beginning of some of his presentations.  I thought folks on AMfone might get a chuckle when reading it...
We got our first color TV in 1958.  It was a floor console with a twenty-one inch round kinescope.  When it was installed, the setup process was rather involved.  I remember watching Bonanza every Sunday evening, it was one of the few shows televised in color at the time.  Sometime later, the picture quality was degraded, and the colors were not clear or sharp.  I remember dad worked at troubleshooting the problem for quite some time. After testing tubes, performing many adjustments, and consulting with the engineers at the RCA Laboratories in Princeton, one of the engineers suggested degaussing the TV.  Dad brought home an electromagnet coil about three feet in diameter, plugged it into the 110 receptacle, and moved it all around the TV, then stepped away from the TV and unplugged the coil.  Magically, the color quality was restored to normal.  (More modern color sets include a degaussing coil that operates each time the receiver is turned on.)  After resolving the issue, dad decided to experiment with a permanent magnet to see how the color would change.  It was rather dramatic!   He called all of us to the living room and showed us what changes the magnet caused.   I recall saying "That's nothing new, I tried that two weeks ago!"
Rick Maxwell  W8KHK ex WB4GNR WB2HKX
KX5JT
John-O-Phonic
« Reply #1 on: July 14, 2012, 10:14:03 PM »
Thank you for sharing these wonderful memories of you and your Dad Rick!! I really enjoyed this!
AMI#1684
K7EDL
« Reply #2 on: July 14, 2012, 10:22:46 PM »
Great stories, thank  you for sharing them with us
Eric
« Reply #3 on: July 14, 2012, 10:33:04 PM »
Indeed. As well as growing up through such technically-interesting times, it had to be quite interesting have Walt as a dad.
Thank you for sharing these stories.
N5RLR
Extra With A Side Of Fries
Supremely Lurking
« Reply #4 on: July 15, 2012, 12:52:21 AM »
...After resolving the [color TV-degaussing] issue, dad decided to experiment with a permanent magnet to see how the color would change.  It was rather dramatic!   He called all of us to the living room and showed us what changes the magnet caused.   I recall saying "That's nothing new, I tried that two weeks ago!"
I can totally relate!  Cheesy
Thank you for sharing your dad's stories, Rick.  Wink
Michael
Licensed Since 1990  Cheesy
« Reply #5 on: July 15, 2012, 08:27:41 AM »
Rick,
I am glad you posted those great stories of your Dad.  As we discussed, I lost my Dad a little over 4 years ago.  He was not a Ham but if he was I am sure I would have my list of technical stories as well.  I do have a lot of other stories about him though.
I will never forget the time back when I was 14 and it was my day to mow the acre of grass with a small non self propelled 18" push mower.  I was working on getting a new transmitter working and I did not want to mow the grass that day since I was dealing with a deep technical problem.  I was so upset that I had to mow that I purposely ran the mower over a pipe that was sticking out of the ground!  Well that sure killed the lawn mower and it was not worth the price I paid for that act!!
Joe, W3GMS
« Reply #6 on: July 15, 2012, 04:28:28 PM »
Those are great stories, exactly the type that should be preserved. When my paternal Grandmother was in the nursing home I would visit, and ask her to tell me stories of when she was young, about my grandfather (died at 42), and about when when my dad was a boy. Though very demented, she still remembered the old stories. I'm not saying your dad was suffering dementia, just speaking of Grandma. Anyway, she really was happy while telling the old stories, even if it was hard for me to keep her on track and she'd forget she'd told me them after a few minutes. They were not ham radio tales but they were a picture into another time.
« Reply #7 on: October 06, 2019, 12:11:12 AM »
Bump....
Great stories, Rick!
I missed it the first time in 2012.   Maybe some others did too.
Later -
Carl WA1KPD
« Reply #8 on: October 06, 2019, 11:28:08 AM »
Missed em too. Thanks for reposting thge thread!
Carl.
WA1KPD
« Reply #9 on: October 06, 2019, 11:53:23 AM »
As always, Rick is the reigning "Bard of Radio".
K4EMF
« Reply #10 on: October 07, 2019, 08:30:08 PM »
Great stories, thanks for sharing them.
W4EWH
« Reply #11 on: April 23, 2025, 10:54:01 PM »
Rick,
Joe, W3GMS
When I was turning ten, my dad gave me a Birthday present by taking me out to a jobsite, and letting me explore it during the lunch hour. When his crewmates arrived and started work again, I saw the ends of two pipes, coming out of the opposite sides of a trench someone had dug from the buiding toward the street. I jumped into the trench, intending to swing on the pipes, but as I reached out to them, one of the men yelled at me: he screamed "Kid"! "Stop!", and ran over and ordered me to back up to where he could pull me up, and he was able to do so within a few seconds, while all the other worknen gathered around me, and they were telling me that grabiing pipes was very dangerous and I could get badly hurt. My dad came back from his work, and called an electrician over after he'd sent the other men back to their worksites. The Electrician told me that the Edison power company had installed the lights in the neighborhood a long time ago, and they had used only one wire to bring the power to that building, so they had to use the water pipes to get the power back to their generating station up the road, where they strengthened the power so they could send it back to every building that connected to the "high tension" wires on the tops of the telephone poles. My father thanked him, grabbed me by my shirt collar, and nearly threw me into our car with orders not to leave it. I asked him where the bathroom was in case I had to pee, and he pointed to the "half moon" huts beside the road, and ordered me to use one of them if I needed a bathroom.  I fell asleep in the back seat, and woke up when my father pulled out at the end of the day. He gave me a very short, but to-the-point lecture on not telling my mother how I almost died.
Years later, after a tour in Vietnam and a college degree, I worked at New England Telephone and Telegraph company - at a time when they still rented telegraph lines. I was studying a "range extender" device called an EMX-1, in preparation for a tour I had been chosen to give to the company's legal staff, because we had aisle after aisle of  EMX-1 units, many still in use by burglar-alarm companies like ADT and the Boston Fire Department, both of which still used "telegraph" circuits. The technical description of the units included a section on how to "strap" their settings to match the local ground resistance "plus 1250 ohms," and I realized that our telegraph lines, although they no longer used ground-return signalling, were the way that Thomas Edison wired his newly invented light bulbs way-back-when. Consider:
  • In Edison's time, telegraphs used ground-returns and a single "high wire" on the tops of the telegraph poles
  • Edison was a telegrapher
  • Telegraphs, in Edison's time, used Dynamotors to power the telegraph lines, which generated about 120 volts. Edison used them, too. His company rated then according to the number of "lamps" each could power.
  • The voltage we now use in most US homes is 120 volts RMS, which approximates 120 volts DC- the voltage on the old telegraph lines
I'll stop there, In hopes nobody accuses me of jumping to conclusions.
Biill, W4EWH
