May 31, 2026, 05:32:58 AM *
Author Topic: HT37  (Read 2668 times)
ve6pg
« on: May 10, 2012, 11:55:42 AM »
..hey guys...i need to know the 2 pins, on the back of the 37 which will power 115vac for an external T/R relay..there are all kinds of pins, for VOX, etc...i just need the 2 fer t/r...
..thanks..
..tim..
..sk..
W3FJJ
« Reply #1 on: May 10, 2012, 03:10:19 PM »
I don't think the jack provides 115v output, but does have two sets of relays that can wired to external 115v.
relay 1,
Pin 5 N.O
Pin 9 Pole
Pin 10 N.C
relay 2,
Pin 2 N.O
Pin 3 Pole
Pin 4 N.C
GL, Chuck
ve6pg
« Reply #2 on: May 10, 2012, 05:13:12 PM »
..so how does one wire a sx96 rcvr, to a 37, and provide ant. chang-over?..
..tim..
..sk..
w5rkl
« Reply #3 on: May 11, 2012, 08:21:12 AM »
..tim..
..sk..
Do you have the HT-37 manual? If not then you can download the HT-37 manual at the following link:
http://bama.edebris.com/manuals/hallicra/ht37/
Once the manual is downloaded, go to the page "3" and study the SO8 11 pin connector. Pins 2 and 3 are the relay terminals
inside the HT-37 that control an external user provided antenna change over relay. You have to provide the external antenna
change over relay and power source for the relay. All pins 2 and 3 are there for are to act as a "switch" turning the external
antenna change over relay ON/OFF. The HT-37 does not provide 120VAC for the antenna change over relay, you provide that
power source (see page 3 of the manual).
You can find the 11 pin plugs that fit the HT-37's rear 11 pin socket on eBay or from Radiodaze.com.
73s
W5RKL
