Offline
« on: April 14, 2012, 08:32:38 PM » |
W1AEX
Un-smug-a-licious
Offline
Apache Labs SDR
« Reply #1 on: April 14, 2012, 09:38:29 PM » |
Looks like fun Jay. I know nothing about 500 KC sooooo... which sideband is used and what bandwidth would be optimal for listening there?
Rob W1AEX
Offline
« Reply #2 on: April 14, 2012, 09:56:17 PM » |
I'm hearing Bob quite well on the west loaded delta loop. Much better than the 75 meter dipole. Rob I'm running about 1.5 KHz bandwidth. Someone is just below him sending CW. Looks cool on the display. His signal is coming up as it gets later.
W1AEX
Un-smug-a-licious
Offline
Apache Labs SDR
« Reply #3 on: April 14, 2012, 10:07:59 PM » |
I've never listened down there before. There's quite a bit of stuff going on! At any rate, I picked out a few CW stations on or about 510 KC that are quite strong. The fades seem to be long and slow. The short attached mp3 is the ID for one that was floating in at about S-5: WD2XSH/5 which I believe is Dale KW1I.
I'm using an 85 foot triangular loop out at the treeline that's oriented for E-W reception. It seems to hear a few S-units stronger than the 190 foot center-fed.
Offline
« Reply #4 on: April 14, 2012, 10:33:40 PM » |
I was on .511250 LSB. I don't hear him now. Maybe he is taking a break. Really need something directive to the west to hear him well. When I go bidirectional the noise comes way up. I could barely hear him on the 75m dipole with all the noise.
Offline
« Reply #5 on: April 14, 2012, 11:14:18 PM » |
Hi Jay, I just tuned down and hear you and Bob chatting. Time I tuned in was 11:02 PM EDT. Its the first time I listened down on 500 Kc portion of the band and when I tied the feeders together on my 160M antenna both of you were coming in real well. I was using my Ten Tec Jupiter as a receiver. Joe, W3GMS
Offline
« Reply #6 on: April 15, 2012, 02:23:29 PM » |
Amazing stuff down at that end of the spectrum. The fades are very long and slow. Probably less selective fading at those low freqs. Fred
W1AEX
Un-smug-a-licious
Offline
Apache Labs SDR
« Reply #7 on: April 15, 2012, 03:22:32 PM » |
You guys are having some fun down there. Thanks for posting the spark "re-transmission" Jay. That's something you don't hear every day and I have to admit that I kind of like the "tone" of it!
Rob W1AEX
Offline
« Reply #8 on: April 15, 2012, 05:04:04 PM » |
Yes Rob, the tone was very easy on the ears. Also nice to look at on the display. I didn't listen later crapped out after a long day of yard work. The loaded delta loop really shines down on 600m. I think I am going to make them bigger. I was surprised with the improved signal to noise ratio.
W1AEX
Un-smug-a-licious
Offline
Apache Labs SDR
« Reply #9 on: April 15, 2012, 07:19:10 PM » |
Yeah, I confess to running out of steam early as well for the same reason as you. My loops aren't exactly potent performers down there, but I can hear well enough to keep me interested in tuning through the lower regions now and then. We need to do less yard work and more operating Frank.
Offline
« Reply #10 on: April 15, 2012, 07:30:28 PM » |
Bob is planning to be operational again tonight at the top of the hour starting 0100Z ... unless there are thunderstorms in his area.
Thanks for the report Joe. Glad you were able to monitor the QSO. I'm planning to work Bob again tonight at 0100Z.
May be several other stations about so try tuning the range between about 470 and 515 kHz.
Offline
« Reply #11 on: April 16, 2012, 05:48:41 PM » |
Rob W1AEX
Rob Just turn your noise blanker. That should cover it Al
Offline
« Reply #12 on: April 18, 2012, 04:51:47 PM » |
Directive antenna helps a lot more than a noise blanker
KA0HCP
Offline
« Reply #13 on: April 18, 2012, 05:25:35 PM » |
I listened during two hours during the first night, and couldn't hear anything here in Md. Of course, I'm in an apartment with a pipsqueak antenna.
New callsign KA0HCP, ex-KB4QAA. Relocated to Kansas in April 2019.
