May 07, 2024, 06:45:47 PM *
Author Topic: OWL is the Winner!  (Read 28375 times)
« on: March 26, 2012, 10:47:51 PM »
I ran a series of 80m tests to-day with the 440Ω untuned feedline between shack and balanced tuner at the tower, and compared to the 50Ω coax I have used for years.  The coax is 1 y.o. RG-213 elevated off the ground, using the same poles as the OWL.
The OWL is matched to the link-coupled transmitter final using a balanced L-network.  The coax is matched using a series variable capacitor between the link and the coax. In each case, the transmitter was  loaded up to precisely 120 watts DC input.
At the tower end, a balanced link-coupled tuner is used to feed the tuned open-wire transmission line that goes up the tower to feed the dipole. A thermocouple RF ammeter was inserted in one side of the OWL tuned feeder to measure the relative output from the balanced tuner to the tuned feeders that go to the  dipole.  Readings were taken at the extreme ends and the middle of the band.
With the 50Ω coax, a 3-turn link was used, tuned to resonance with approximately 250pf of capacitance in series with the  link. With the 440Ω OWL, 9, 9 1/2 and 10 turns were tried with the link, with no series capacitor.  The best match across the entire band was achieved with the 9-turn link, but the rf output reading was close to the same with all three links, once the transmitter was adjusted to exactly 120 watts input. With both the coax and OWL, reflected power was nulled with the tuner to barely perceptible readings.
Here are the results with the OWL:
3500 kc/s   0.76 Amps
3750          0.79
4000          0.71
With the 50Ω coax:
3500 kc/s   0.673 Amps
3750          0.71
4000          0.65
In each case, with the same DC input, the rf current to the dipole's tuned feeders using the coax transmission line from the shack was roughly 88 to 91% of the reading using the untuned 440Ω OWL.  That means the power delivered by the coax was only about 80% of the power delivered by the OWL.
Assuming 65% efficiency from the transmitter and tuners, the tuner is looking into roughly an average load of 135Ω across the band, as seen at the bottom end of the half-wave tuned feeder, +/-  j factor.
W8ACR
254W
« Reply #1 on: March 27, 2012, 12:43:04 AM »
Don,
I have always liked and used OWL for my transmission lines. The one exception is that I feed my verticals with coax, but loops and dipoles always get OWL. In the past, I have had a few transmitters that use the swinging link output arrangement, and I have always attached COAX to the swinging link, and the coax would then go to a balance tuner in the shack, and from there to the antenna would be the OWL. I have never used any sort of tuner external to the shack. Because of the properties of OWL, I have never felt the need, and my antennas have always seemed to work adequately. Your post has made me think that I could probably get better performance from my OWL fed antennas.
A few questions come to mind: 1. The shield of a coax attached to the swinging link at the transmitter end is at DC ground potential. Is some of that RF power actually lost to the ground? Obviously, RF energy acts very differently than DC energy, but I would think that some of that RF energy is heating dirt.
2. With your system, could you have eliminated the balanced L network at the shack end, and just run the OWL to the external tuner? Do you think this would have degraded the performance of the antenna system?
3. Alternatively, could you have eliminated the outdoor tuner?
4. In your test, where do you think the power is lost? In the coax itself? in plate circuit heat? a combination thereof?
5. I assume that "tuned feeders" at the tower are "tuned" by virtue of their length, perhaps I am wrong about that, but if so, they would be "tuned" at only one frequency (or a small bandwidth of frequencies). Is this a single band antenna system?
One of my recent acquisitions is a large transmitter using a swinging link output circuit. I had the notion that I might just run OWL all the way from the transmitter to the antenna with one tuner positioned somewhere in between. Also, if you have the time, it would be interesting to see schematics of your two tuners.
Ron
« Reply #2 on: March 27, 2012, 02:26:35 AM »
I think the coax is grounded at the transmitter, but I didn't make it a point to do so. It is not grounded at the tower end; it, the  link and the series capacitor are all left floating. I think the loss is cumulative, divided between the link at  the transmitter end, the coax and the link at the tower end. I have run a measurement comparing the output to the input of the line only, and the coax was 93% efficient while the OWL was 98%
The OWL is run without standing waves  between shack and tower.  I had to build a matching network to match the link to the line, and the L-network worked best.  I tried several designs.  With the coax, the series resonating capacitor matched it OK.  The OWL is  connected to the external tuner directly to the 9-turn link, with no resonating capacitor on that end.  If you get the link just right, it will resonate without an external  capacitor.  Without the matching network at each end, the OWL would  run with standing waves, or wouldn't take a load.
That would make it a tuned line all the way from the dipole to the shack.  The problem is the length. The frequency error over each quarter-wave of tuned feeder is cumulative.  Too many quarter waves, and the tuning becomes sharp and critical with limited bandwidth.  Also, on 80m, I would likely have to switch from series feed to parallel feed at some point while QSYing across the band.  Keeping the line flat from shack to tower, and running the tuned line up the tower limits the number of tuned quarter-waves to two, and a simple balanced tuner with only one variable element can handle that. Since it is remotely tuned from the shack using a reversible motor, I am striving to limit the variable element at each tuner at the tower (have 5 of them ganged  togetther for various bands and antennas) to one variable capacitor. This already works with the  coax, so it is merely a matter of adapting each tuner to be fed with 440Ω balanced line instead of 50Ω unbalanced.
See no. 1
It is multi-band.  I work 160-40m using that same dipole and tuned feeder.  The lengths are so that it uses series tuning on 80 and parallel tuning on 40.  On 160 I switch in an additional 60 ft. of resonant feeder to get an even number of 1/8 wavelengths, and parallel tune it.
I also feed the tower, which is base insulated, as a quarter-wave vertical on 160.  I rarely use the dipole on 160, but that was the only antenna I had for the band when I first built the tower, before installing a radial system. I never wasted my time trying to load up the vertical with no ground system.
I'll try to post some diagrams as soon as I get the whole thing operating.
« Reply #3 on: March 27, 2012, 09:20:07 AM »
The meaning of "tuned feeders" has changed over the years I think.  From what I have read in my 1930s Handbooks (ARRL) the term at that time referred to balanced flat lines engineered to match the load Z at some frequency by way of length and spacing.  I now hear the term used to refer to any balanced line with a balanced matching network.
I went to one of the popular on-line loss calculators http://www.ve3sqb.com/hamaerials/ocarc/
and put in Belden 213, 120 feet flat 50 ohms 1:1 vswr 1 KW in on 3500 kc and the calculated loss was 100 w. (900 making it to the other end).  .435 dB loss.
Generic 600 ohm ladder line:  same power, length, 1:1 vswr flat line, 3500 kc loss .043 dB -- 990 watts making it to the other end.
this is why I avoid long runs of RG213, but it is great for jumpers and 5 foot runs.
What about something like 1/2 inch heliax.
For LDF4-50,  all same condx just different feedline, we do a little better but not as good as OWL:  967 watts at the load end, .145 dB loss.
Caveat: I don't know how the on-line calculator works i.e. what the equations it uses are and without that, you have to take this data with some precaution.  However, it agrees with Don to the extent that OWL is indeed the winner  Cheesy
« Reply #4 on: March 27, 2012, 10:13:55 AM »
Don...does rain , snow, or ice make much tuning difference with your setup ? Does it snow in TN? Keep up the good work...Steve
« Reply #5 on: March 27, 2012, 11:49:19 AM »
We get it all here.  Rain, snow, ice, fog, hail, sleet, etc.  No snow or ice this year, but this could be called the year without a winter. Fortunately, ice doesn't occur too often, maybe a light icing a few times per winter.  Every decade or two we get a major ice storm that takes down power lines, trees and antennas.
Ice is the worst about detuning the antenna.  I can usually re-adjust the tuner and make it match well enough to get on the air, but a couple of times  when we  had heavy ice (fortunately the antenna held up) I couldn't get the transmitter to take a load no matter what, and just had to wait till it melted.  Rain and fog sometimes detune it enough that I have to re-set the tuner away from normal settings, but it works OK until it dries, then I have to re-tune to normal settings.  Dry snow doesn't seem to affect it much, but heavy wet stuff that accumulates on the OWL spacers sometimes detunes it much the same as light ice.
Rob, I believe the term "tuned feeders" has always meant knowingly running a transmission line with a significant standing wave. I would consider anything running a VSWR greater than about 3:1 as tuned feeders, but I'm not sure what the industry standard is, if there is one.  Untuned theoretically means the transmission line is running perfectly flat with no standing waves, but in actual practice most "untuned" transmission lines regardless of type (coax, OWL, "window" line, solid ribbon, etc) show some reflected power, but the transmatch, tuner or output network in the transmitter is able to compensate for the reactive component and mismatch, if it isn't too great. Real OWL makes the most efficient tuned feeders.
You don't necessarily have to use a full-fledged tuner with open wire tuned feeders.  For instance, an end-fed zepp with a quarter-wave feeder will show low impedance at the transmitter end of the feeders. If the feeders are cut to just the right length, a link coupled transmitter can be made to see exactly the capacitive reactance needed to tune the link to resonance; the transmitter will take a load and the antenna will work great within a narrow range of frequencies.  To make that antenna work across the entire band, cut the feed line slightly short and insert a variable inductor in series with the link.  The inductor will serve to tune the system to resonance.  Or you can make the feeders a little too long, and tune to resonance with nothing more than a variable capacitor in series with the link, or preferably, two variable capacitors, one in series with each side of the link.
A couple of long-time Hammy Hambone misconceptions include the old wives' (or husbands'?) tales that the reflected power comes back into the transmitter and heats up the final tubes sometimes causing them to run red, and that you can "trim" the length of the coax to get the SWR down.  If you have to trim the feed line to get the antenna to load, you are in fact running a tuned feeder and adjusting its length for the best match the transmitter output network can handle, as described in the previous paragraph. Trimming the length has no effect whatever on the SWR on the feed line.
Too many of the antenna discussions I hear over the air, especially those using the "other mode", sound something like thisGrin
« Reply #6 on: March 27, 2012, 01:41:00 PM »
Try the OWL again during a good rain both with no retuning and with.
The answer to coax loss is to use CATV hardline....mo betta in long runs.
Running any OWL here except maybe a 70' run of light window line to an 80M sloper would be about impossible and that crap goes bonkers in the rain....tried it decades ago.
« Reply #7 on: March 27, 2012, 03:41:19 PM »
My #10 spaced 4 inches with Johnson spreaders might need a slight tweek if the line is iced up otherwise twice a year. When the leaves come out and when the leaves drop. Rain doesn't do anything
« Reply #8 on: March 27, 2012, 10:22:18 PM »
Not surprising.  That stuff is nothing more than heavy duty TV ribbon with little rectangular holes punched in the dielectric.
There was also a type of coax that consisted of copper tubing as the outer conductor, and the inner conductor was solid copper wire with little ceramic beads crimped on every few inches.  The rest of the dielectric was air.  In should  be almost as efficient as OWL, if you can keep the moisture out.  Broadcast stations would slightly pressurise the line with air, or preferably, with dry nitrogen.  Don't know if it is still in production or not.
« Reply #9 on: March 28, 2012, 06:47:41 AM »
This is correct.  I went and looked in my 1932 ARRL handbook.  I got it exactly the opposite.  An untuned feeder is a flat line.  A tuned line has standing waves on it.   Sorry about that.
W4NEQ
« Reply #10 on: March 28, 2012, 08:44:37 AM »
There is a 5kw 3-tower DA here in Bowling Green, Ky that uses the circa 1948 line you mention.  The center is actually copper tubing too, and I believe it's some funky impedance like 64 ohms.  I spliced it a few years ago after a mowing accident.
BUT, if you really want to tune coaxial cable from the shack with an unbalanced tuner, this coax will rival the low loss of open wire line even at high VSWR:
http://w4neq.com/img/low_loss_coax.jpg
Chris
K3ZS
« Reply #11 on: March 28, 2012, 08:58:58 AM »
I use the "brown crappy" window feedline.    It is the heavy duty made with #14 wire.    The rain is no problem on 80M, a slight change on 40M, the upper bands the tuning goes wild.  It has been durable, however, the antenna and feedline have been up at least 15 years.  Will change to OWL at the next opportunity.
« Reply #12 on: March 28, 2012, 09:04:03 AM »
That's just 3 or 4 inch heliax.  It won't rival OWL in terms of the loss to your bank account in $/foot plus the nitrogen and associated hardware needed to pressurize it once you get done paying for it.
W4NEQ
« Reply #13 on: March 28, 2012, 11:04:36 AM »
Actually, it's Andrew HJ9-50 - five-inch Heliax.    At 2 MHz  it loses 0.011 dB per 100 feet and will handle 633 kw average power.  When I bought some last, it was running about $60 per foot.
Personally, just by sheer coincidence, on 80 / 40 I run the same OWL as Don - #10 bare copper spaced 2 inches.
The only real disadvantage of tuned feeders is that with really long runs the bandwidth gets pretty narrow, so re-tuning with QSY must be done from a look-up table.
I have always thought about using tuned feeders for a 40 / 80 ground plane up above the trees.  But I've never been able to come up with a suitable balun design to do it over a wide bandwidth with low loss.
Chris
« Reply #14 on: March 28, 2012, 12:45:43 PM »
Trilogy makes a mostly air CATV coax, Im running 200' of their 1" to the 144 and 222 antennas, all from local installers surplus.
The 7/8" goes to the 10M stacks which fell down in an ice storm.
I also have some of that old 50 Ohm stuff but it requires pressurization and is long useless by now. It will go to a scrap dealer when copper peaks.
« Reply #15 on: March 28, 2012, 01:11:13 PM »
That's true for anything with copper in it.  But the price of copper products seems to be rising at a faster rate than  the price of copper, not unlike the price rise in university tuition and medical care, compared to the rate of inflation.  Yesterday, I was at Lowe's for something else, and went over and took a look at what they are charging for ordinary house wiring.  Incredible! Sticker shock!  Several times the price per foot that I paid last time I bought some. This morning I looked in the commodities section of the local newspaper. To-day's price (NY Merc) is $3.8790/lb.  A few years ago, as I recall, it was about half that, but the price of copper wire in the store was probably less than a quarter what they are selling it for now.
K3ZS
« Reply #16 on: March 28, 2012, 01:37:46 PM »
Go to garage sales for wire, especially the ones where people are moving out of their homes to retirement places.    I just got a spool of zip cord that had an original price of $29 marked on it.    I think I paid $1 or less for it.
« Reply #17 on: March 28, 2012, 09:08:50 PM »
I think when I was putting in my ground system, I was buying those 500' rolls of insulated no. 14 solid at home depot because they had the best price, $14 / roll.  I think they're around $45 now. I saw last time I was there that they now sell 100 foot rolls, part of the trick to make it seem cheaper.  Since I wasn't looking for 20,000 or 30,000 feet I settled for the 500 foot rolls and discovered that the wire with insulation was cheaper than the wire without, I guess because uninsulated no. 14 is odd and there is economy of scale with the insulated.  The thing that is a downer is that it was hard before to persuade some hams to invest in a good ground system, but with the price of wire today it's about impossible.
What I miss are the wide spaced insulators like what you can see advertised in Handbooks and QST from the early 1950s.  I wish someone still made those pyrex (or whatever it was) thin lightweight 6 inch spacing ladder line spacers.
« Reply #18 on: March 28, 2012, 09:53:46 PM »
If wire with plastic insulation is cheaper, then use it.  It won't make any difference in performance, but it will protect the wire from minerals in the soil and the radials will last longer.  That's not a problem in our soil here, but in areas with highly acidic soil, bare copper will gradually erode away. The kind of plastic insulation they use now should remain intact in the soil for decades, if not centuries.
But still, I can't see why bare wire should be more expensive than insulated.  The companies that manufacture the insulated wire buy the bulk stock in bare form from other manufacturers, who in turn bought the copper in ingot form, melted it down and extruded the wire from the molten mass. These vendors don't sell to the general public, but only to the manufacturers that make the finished product, at the prevailing copper price plus their "extruding fee".  It would be cheaper for the finished product manufactures to simply reel out wire from their stock and sell to customers as-is with  some mark-up, than to go to the trouble of adding insulation to the wire before selling it. That's how I got my copper wire for the radial system; my old room mate's father ran such a wire manufacturing plant in RI, and he sold me 16,000 feet of #12 softdrawn bare at his cost.  I paid $400 total, for the wire in 4 spools back in 1974.  It wasn't cheap even back then, but quite a bit less than what it would have cost at the local electrical supply retailer. The guy who owned the factory and sold me the wire thought I was totally freakin' nuts when his son told him I planned to bury all that wire in the ground.
When I had cut the 16,000 ft. of wire into 120 pieces, each 133' 4" long, I bundled the pieces all together and laid them out on the ground before installing them into the ground system.  The solid bundle was between 4" to 6" in diameter and 133' 6" long. Wouldn't that have made to-day's copper thieves drool!  And the wire sat out openly in the field unguarded for several weeks before I got it all laid out and buried.
« Reply #19 on: March 28, 2012, 10:10:50 PM »
Not much new here.
Window line sucks when wet.
Coax sucks with high SWR.
Open wire line sucks to install properly.
All can work just great if people understand their limitations.
« Reply #20 on: March 29, 2012, 12:47:30 PM »
Maybe there's no logic--they just set a price and since it is unusual, if someone wants it, they must want it bad enough to pay the price.
Or, there's a small market for it (no. 14 bare for example)  but the shipping and plastic spools and inventory management and labeling and wrapping and so on all cost just as much but fewer buyers are paying for that so it is more.  Just speculating.
Since I did not have room for a complete ground system in all directions, I drew a map of my lot with all the obstructions on it and mapped out where the radials would go and how I would angle them to stay inside my lot but parallel to the horizontal part of the inverted L over head.  I drew quadrants around the feedpoint and subdivided them on the map.  I knew if I just went out there and started laying down wire willy nilly I'd get about halfway done and discover I'd screwed it up so I made a plan.  Then I went out there and strung out radials two at a time each hand holding a wire spool dividing up a quadrant until it was full.  Walking along on the ground I'd follow the plan and when I had reached the end, marked by an obstruction, lot line or 120 foot limit I'd cut the wire and walk back with a bucket of staples and a hammer and spaple them down into the ground.  This was in Nov. 2003.  I worked on weekends and for about 90 minutes after work on weekdays before it got dark.  It took about three weeks but I eventually got 101 radials down.   I was going for 120 but I decided no one would notice them on my signal and that wire might be more useful for other things.  I used no. 14 solid insulated.  I think I spent about $90 on wire.   the vertical wire is bare no. 14 hard drawn stranded.
« Reply #21 on: March 29, 2012, 02:13:08 PM »
I haven't checked Wire Man lately, and compared their prices for bare copper wire to what I could get at the local big boxes or at a dedicated electrical supplier.  I have bought from them at hamfests, but they usually don't bring along their complete line of products.
Something I find baffling is that one particular size of solid copper wire is extremely hard to find.  It is easy to find #'s 18, 16, 14, 12, 10, 6 and 4, but for some reason nobody wants to stock #8, which I find useful for coil stock, as well as for constructing OWL. Fortunately I have the big roll of #8 copperweld, which seems to work OK for my untuned transmission line, but the skin depth is small enough that I'd be a little leery of using it with high SWR.  I would want solid copper for that. Also, odd number wire sizes are almost non-existent, except at motor re-winding shops. OTOH, at fence suppliers, some odd number steel wire sizes are readily available.
« Reply #22 on: March 29, 2012, 03:46:48 PM »
At one time #8 solid was a standard house ground. Maybe there is a conspiracy to force #6 to be used by everyone including Harry Homeowner, the weekend electrician and his cousin Hammy Hambone. I still have a partial reel of #8 solid copper I bought around 1975
« Reply #23 on: April 13, 2012, 06:27:11 PM »
Data has been collected for the 160m dipole configuration.  The dipole is approximately 135' long, fed on 160m with a total of 186' of tuned feedline.  Thermocouple rf ammeter was placed at the output terminals at the feed point of the tuned line going up the tower, approximately 125' from the antenna feed point. One dipole leg plus the whole tuned line is close to a full wavelength on 160.  DC input to the transmitter was 75 watts, so rf output power is estimated to be approximately 50 watts.
1800 kc/s: with OWL, rf current reading was 3.05 A.  With original coax configuration, 2.62A   Load impedance calculates to 5.38Ω.  Power delivery ratio, OWL vs coax: 1.36:1
1900 kc/s: OWL, 2.75A.  Coax, 2.4A. Load impedance, 6.61Ω  Power ratio OWL vs coax, 1.31:1
2000 kc/s: OWL 2.45A.  Coax, 2.1A.  Load impedance, 8.32Ω. Power ratio OWL vs coax, 1.36:1
The load impedance for the short dipole calculated much lower than expected. I was expecting something between 10 and 20 ohms, since the rf ammeter is placed midway between a current and voltage loop. Efficiency of coax feed vs OWL feed averaged about 75%. Increased power loss  probably occurs in the transmitter coupling system to coax line, as well as loss in the coax itself. Previous tests into a dummy load indicated more power delivered to the 440Ω load with balanced L-network, than delivered to the 50Ω load feeding with coax and capacity tuning of the link.
« Reply #24 on: April 13, 2012, 08:37:37 PM »
In the 50's at my parents the Viking 1 loaded fine on 160 into a 80M dipole fed with 72 Ohm twin lead. Worked the commuter mobiles several days a week with no tuner plus loaded on 80 and 40 where I worked plenty of DX on 40 CW.
The 15M folded dipole was made the HB way with hollow phenolic dowels spaced 6" apart and fed with TV ribbon also loaded fine and I worked the world including WAC as a Novice with a HB 6AG7, 807 and later with the V I. Thats the last time I came close to anything resembling OWL.
OWL, old fashioned tanks, and tuners are overated  Tongue Shocked  Different strokes for different folks.......what works works to paraphrase Yogi Berra.
