The pix shown has the AirDux in the rear. It will be moved and parallel with the caps. The band switch will be moved way foreward from where it is placed on the mock-up.
The plate tune on the left needs a coupler. I have one for the loading. It's a reducer because that gear has to be replaced with a reducer (lower right) What is super-neat is the two shafts are at exactly the same height off the shelf. The switch will be integrated through some BC-1T HV stuff. All 3 parts will be positioned in a standard parallel layout allowing me to shove the tuning cap farther back making more room for the coupler and a venier tuner. The coil will be vertical with the 10 meter up top. The switch would be at the front. Basic tuner layout; standard pi net.
I need a similar coupler for the tune cap. Plate won't exceed 2750 volts. Thanks!
