May 16, 2024, 02:20:37 AM *
Author Topic: The Official Results of the 2012 AM Transmitter Rally!!!  (Read 10017 times)
« on: February 29, 2012, 10:31:20 PM »
Well, the results are in!  We had some upsets this year, and some very interesting statistics.
2012 showed a higher number of states worked by individual stations - 29 was the highest in 2011, 34 (a 4 way tie, actually) for 2012.
As usual, 80 meters was the most popular band, however 40, 15, 20 and even 10 meters made reasonable showings.  The 2012 data shows a greater distribution of band usage than we had in 2011.
There were fewer logs sent in this year, however, in general, the numbers were higher.  We made more contacts in 2012 than in 2011.  We logged the exact same number of unique stations in 2012 as we did in 2011 (513 stations); the highest contact and state counts were higher.
This year, there is more data available.  I wrote a reasonably involved routine to pull out rig and some tube data.  This is very interesting.  The band usage data is also derived.
Ok, who won what?  Wink
For overall highest points:  Congratulations go out to Jack W9T (W9GT) for a very impressive 187 points; 153 contacts in 34 states.  That is very hard to do.
In category A (classic commercial amateur equipment) Elizabeth W3K (WX3K) made an outstanding showing of 98 points running ONLY A RANGER winning the category!  Nice work!!
Jerry, KC8ZUL won category B (broadcast transmitter) with a poultry 12 points (no one else entered in that category), but he definitely takes the prize for the HEAVIEST transmitter (a Gates BC1F weighing in at some 2500 pounds!  Talk about HEAVY METAL!
Jack W9T (W9GT) takes category C (military transmitter) with his Federal Marine Rig - a real classic.
In the Home Brew world (category D), Steve KL7OF made a very respectable showing with 105 points.  Sounded good out here on the East Coast, that's for sure.  George AB2KC also did very well with his 4-1000 modulated by 304-TLs
The Class E category included W1E (WA1QIX) and Kerri KC2UFU both with very respectable showings, particularly in light of the fact that it was Kerri's birthday (Happy Birthday Kerri), and she had limited time to dedicate to the event, and Steve was in the beginning stages of the Norovirus (yuk!).
Category F (commercial transmitter followed by a linear amplifier) is always a popular category.  Our last year's winner, Ralph W3GL was the dominant force here, followed closely by Steve K4HX.
Category G (anything not covered by the above) is always interesting.  I think the K7DYY transmitters, the Flex rigs operating barefoot, barefoot rice boxes, etc. might need a separate category or even two categories.
------------------------------------------------------- Here is the data ---------------------------------------------------------
Opening file KB3OUK.CSV
Opening file K9PNP.CSV
Opening file W9A.CSV
Opening file W2E.CSV
Opening file KC2UFU.TXT
Opening file N2BE.TXT
Opening file W2VW.TXT
Opening file K0ARA.TXT
Opening file WA1LGQ.TXT
Opening file AB2KC.TXT
Opening file K4HX1.TXT
Opening file K9DO.TXT
Opening file KC7PH.TXT
Opening file KC8ZUL.TXT
Opening file KD4BAO.TXT
Opening file KL7OF0.TXT
Opening file KW7Y.TXT
Opening file KX5JT.TXT
Opening file W1AC.TXT
Opening file W1AEX.TXT
Opening file W1E.TXT
Opening file W1G0.TXT
Opening file W3GL.TXT
Opening file W3K.TXT
Opening file W8A.TXT
Opening file W9HW.TXT
Opening file WA1IIE.TXT
Opening file WD4LUR.TXT
Opening file WF0N.TXT
Opening file W9T.TXT
30 files processed.
All Rally submissions sorted by points:
       W9T: category: C, 153 contacts,  34 states, score: 187 <-- Most Contacts, Most Points!, 4 Way tie for most states
       W1E: category: E, 151 contacts,  34 states, score: 185 <--- 4 Way tie for most states
      W3GL: category: F, 120 contacts,  32 states, score: 152
      K4HX: category: F, 106 contacts,  34 states, score: 140 <--- 4 Way tie for most states
    KC2UFU: category: E,  80 contacts,  34 states, score: 114 <--- 4 Way tie for most states
     KL7OF: category: D,  79 contacts,  26 states, score: 105
       W3K: category: A,  80 contacts,  18 states, score:  98
    WA1IIE: category: A,  55 contacts,  19 states, score:  74
      W9HW: category: G,  53 contacts,  20 states, score:  73
      W1AC: category: A,  54 contacts,  18 states, score:  72
      KW7Y: category: G,  46 contacts,  19 states, score:  65
       W8A: category: F,  42 contacts,  21 states, score:  63
       W9A: category: H,  43 contacts,  17 states, score:  60
      WF0N: category: A,  41 contacts,  18 states, score:  59
     W1AEX: category: F,  38 contacts,  17 states, score:  55
      N2BE: category: A,  35 contacts,  18 states, score:  53
     AB2KC: category: D,  28 contacts,  16 states, score:  44
      W2VW: category: F,  27 contacts,  16 states, score:  43
     KC7PH: category: A,  27 contacts,   6 states, score:  33
      K9DO: category: G,  20 contacts,   6 states, score:  26
     KX5JT: category: A,  18 contacts,   8 states, score:  26
    KD4BAO: category: G,  14 contacts,  11 states, score:  25
    WD4LUR: category: A,  11 contacts,   9 states, score:  20
    KC8ZUL: category: B,  11 contacts,   1 states, score:  12
       W1G: category: A,   5 contacts,   5 states, score:  10
     K9PNP: category: A,   3 contacts,   3 states, score:   6
    WA1LGQ: category: A,   3 contacts,   3 states, score:   6
    KB3OUK: category: H,   1 contacts,   1 states, score:   2
       W2E: category: H,   1 contacts,   1 states, score:   2
     K0ARA: category: A,   1 contacts,   1 states, score:   2
Categories:
A = Classic Commercial AM Amateur Equipment (KW1, 32V3, DX-100, etc.)
B = AM Broadcast Transmitter
C = Military Transmitter
D = Home brew largely vacuum tube transmitter
E = Home brew solid state transmitter
F = Commercial amateur equipment followed by a linear amplifier
G = Anything not covered by the above
H = Unknown transmitter type
Submissions sorted by category, then by points:
Category A:
       W3K,  98 points
    WA1IIE,  74 points
      W1AC,  72 points
      WF0N,  59 points
      N2BE,  53 points
     KC7PH,  33 points
     KX5JT,  26 points
    WD4LUR,  20 points
       W1G,  10 points
     K9PNP,   6 points
    WA1LGQ,   6 points
     K0ARA,   2 points
Category B:
    KC8ZUL,  12 points
Category C:
       W9T, 187 points
Category D:
     KL7OF, 105 points
     AB2KC,  44 points
Category E:
       W1E, 185 points
    KC2UFU, 114 points
Category F:
      W3GL, 152 points
      K4HX, 140 points
       W8A,  63 points
       W9A,  60 points
     W1AEX,  55 points
      W2VW,  43 points
Category G:
      W9HW,  73 points
      KW7Y,  65 points
      K9DO,  26 points
    KD4BAO,  25 points
       W2E,   2 points
Category H:
    KB3OUK,   2 points
*** -->Total unique calls logged: 513
Special event calls logged:
W1E  W9T  W8A  W3K  W9A  W1G  W2E
Bands ranked by percentage popularity:
   80 Meters: 63.53 %    (84.34 % in 2011)
   40 Meters: 22.98 %    (11.92 % in 2011)
   15 Meters: 6.41 %     (0.00 % in 2011)
   20 Meters: 3.32 %     (1.75 % in 2011)
   10 Meters: 2.71 %     (0.08 % in 2011)
  160 Meters: 1.06 %     (1.91% in 2011)
Rig Types (sorted):
Home Brew: 43
Ranger: 28
Viking II: 23
--> 813 Tubes used: 22
Flex 5000: 20
Valiant: 20
--> 811 Tubes used: 18
DX-60: 15
Heath Apache: 15
32-V3: 15
DX-100: 13
TS-440: 13
Class E Rig: 12
--> 3-500 Tubes used: 12
FT-101: 11
TS-570: 11
IC-756: 11
FT-1000: 10
Viking 500: 9
TS-2000: 9
--> 4-1000 Tubes used: 9
FT-950: 8
FT-2000: 8
IC-7600: 8
Globe King: 7
--> 4-400 Tubes used: 7
FT-450: 6
BC-610 - HT-4: 6
32-V1: 6
IC-765: 6
Flex 3000: 5
Viking - Other: 5
FT-102: 5
Gates Broadcast Rig: 5
32-V2: 5
IC-746: 5
IC-706: 5
Gonset G-76: 5
--> 810 Tubes used: 5
Viking I: 4
AF-67: 4
FT-857: 4
FT-847: 4
T-368: 4
KW-1: 4
TS-940: 4
Desk KW: 4
B & W 5100: 4
IC-718: 4
K7DYY Senior: 4
--> 304-TL Tubes used: 4
Flex 1000: 3
Flex 1500: 3
Flex - Unknown: 3
DX-40: 3
HT-40: 3
Collins 20V3 Broadcast: 3
TS-930: 3
TS-480: 3
Eico 720: 3
K7DYY Super Senior: 3
Harvey Wells: 3
--> 805 Tubes used: 3
FT-900: 2
FT-897: 2
FT - Something: 2
Globe Champ: 2
Drake T4-X: 2
Drake TR-4: 2
Drake TR-7: 2
HT-9: 2
Bauer Broadcast Xmtr: 2
Electrocraft: 2
ART-13: 2
IC-735: 2
Retro 75: 2
Knight Kit T-150: 2
ARC-5 Military Xmtr: 2
MOSFETs used: 2
--> 304-TH Tubes used: 2
--> 5868 Tubes used: 2
--> 250-TH Tubes used: 2
FT-817: 1
FT-890: 1
FT-840: 1
FT-5000: 1
Globe Scout: 1
Globe - Other: 1
Collins 300G Broadcast: 1
HT-37: 1
HT-32: 1
TS-870: 1
TS-850: 1
TS-590: 1
32V-Something (not specified): 1
IC-747: 1
K7DYY Junior: 1
Kachina SDR/DSP: 1
Navy TCS: 1
Federal 167B Marine Xmtr: 1
--> 812 Tubes used: 1
States/Provinces/Counties worked, with contact counts:
114 New York:NY
109 Pennsylvania:PA
 86 Massachusetts:MA
 83 New Jersey:NJ
 76 Illinois:IL
 64 Ohio:OH
 56 Washington:WA
 52 Maryland:MD
 51 Maine:ME
 50 Connecticut:CT
 47 Indiana:IN
 41 Michigan:MI
 34 Wisconsin:WI
 33 Minnesota:MN
 31 Virginia:VA
 31 California:CA
 27 New Hampshire:NH
 26 Delaware:DE
 24 Florida:FL
 23 Tennessee:TN
 22 Colorado:CO
 18 Kansas:KS
 18 North Carolina:NC
 17 Missouri:MO
 17 Arizona:AZ
 17 Vermont:VT
 12 Alabama:AL
 12 Texas:TX
 12 Rhode Island:RI
 12 South Carolina:SC
 11 Louisiana:LA
  9 Wyoming:WY
  9 North Dakota:ND
  8 Oregon:OR
  7 Georgia:GA
  7 Ontario (Canada):ON
  6 Oklahoma:OK
  6 Nevada:NV
  6 West Virginia:WV
  4 Iowa:IA
  4 Idaho:ID
  4 South Dakota:SD
  4 Kentucky:KY
  3 Mississippi:MS
  3 British Columbia (Canada):BC
  3 Saskatchewan (Canada):SK
  2 Nebraska:NE
  2 Arkansas:AR
  2 Northwest Territories (Canada):NT
  1 Quebec(Canada):QC
  1 New Mexico:NM
  1 Alaska:AK
  1 Alberta (Canada):AB
« Reply #1 on: February 29, 2012, 10:34:17 PM »
Here is more data - the individual station counts (in how many logs the call sign appears), and all of the comments made about the station.
Individual Station Log Counts and comments from all logs:
   W1E, 28, "CLASS E", "class e ", "Class E 24 MOSEFTs", "24 mosfet class e", "Class E homebrew (24 pill) Flex soft-rock receiver, 75A3 front end", "Class E Homebrew (24 pill)", "WA1QIX,  Class E Xmtr,   Great Sounding Station!!!!", "59", "Class-e inventor, lonley guy", "Class E", "Class E", ", "classy "E'  TNX STEVE   for making this happen!  i haD FUN", "Class E", "Class E", "Class E Analog Drive", "Class E", "w1aex    20/9", "Class E...etc", "Homebrew Class E Transmitter into dipole", "CLASS E 24 FETs, ", "CLASS E", "class e/dipole@90'", "WA1QIX strapping! CLASS E", "CLASS E", "TX Homebrew class E", "class e xmtr", "Class E 24 MosFETS, dipole"
  W3GL, 23, "3-500z's hb", "3 - 500z", "Kenwood TS-440S with 3-500 amp 300 watts carrier", "Kenwood TS-440 doublet", "200w 3-500z", "TS440, linear amp, 300w", "(2)3-500z@350w;200'Random wire", "tx rx? big group", "3-500Z's homebrew", "TS-440 pr 3-500Z's 200' Center-fed Zep", "200' center-fed TS-440 to pair of 3-500's", "TS-440 into H.B. Pair 3-500Zs", "TS-440 into H.B. Pair 3-500Zs", "3-500Z 200 foot zep ts440", "TS440S driving 3-500Z  ", "(2) 3-500Z, CENTER FED ZEPP, TS440", "(2) 3-500Z, CENTER FED ZEPP, TS440", "3-500Zs/TS-440", "TS-440, Johnson Match box, Zepp antenna", "200w", ", "3-500Zs , 200 ft ctr fed wire antenna", "3-500Zs , 200 ft ctr fed wire antenna"
   W9T, 21, "federal 176b", "Federal 167B 813s mod by 811s), R390, 70 foot inv. vee", "Federal 167B", "Marine Tx 813s X 811As / R390A", "Federal Marine TX (2x811 mod 2x813), Delta Loop", "Federal Marine TX (2x811 mod 2x813), R-390A, dip", "Federal 167B, Collins R390A", "Federal 167B(813  Final)811a", "Federal 167B(813 Final)811a", "indiana..ft 2000+amp 300wts..+beam LOUD", "FT2000", "FT2000", "FT-2000 3-500Z's Tr", "Federal 157B Marine Transmitter", "Fed Marine TX, Loop Ant", "fed marine tx", "FEDERAL 167B XMIT, R390A, LOOP", "federal 167b/collins r390a", "Marine TX 1943 813s/R390a", "Federal 163B, R390A, Full wave loop", "federal xmtr r390"
   W3K, 17, "viking inverted u", "Ranger 1, HRO-60, inverted vee", "Ranger/HRO50T WX3K 58", "ranger 30w inverted vee, call=wx3k", "Ranger, HRO-50T, IV", "Ranger, HRO50T", "ic756 mosley57b", "Ranger Inverted V HRO-50T", "Ranger - WX3K", "Ranger", "Ranger", "ranger", "ranger", "RANGER, ", "RANGER, DIPOLE", "Ranger/HRO52", "ranger"
KC2UFU, 16, "HB class E w/ class H mod @ 400 w", "Class E, 400w driven by an ICOM 746", "Kenwood TS-440 4-1000 GG 3 el monobander", "Kenwood TS-440 4-1000 GG wire colinear OWL", "ic-746 to class-e/h mod 160' ant @55ft, suductive audio.", "Class E TX, dip", "IC-746(exciter),Tx-Class E, Class H modulator", "TS440 +4-1000A", "Nice signal and nice to meet you.", "icom 756 class e", "H.B. Class E Rig, 8 MOSFETs", "ic 746 to class e rig", "IC746  Exciter feeding Class E Amp      160 centerfed d[pole", "IC746& CLASS E/H MOD, DIPOLE", "CLASS E", "ts440 plus amp"
  K4HX, 16, "ft1000", "FT-1000D + linear (350W) delta loop at 70 feet", "FT-1000 into a linear, 300W", "400 watts ft1000...linear /comm assoc , dipole ,tnx steve ", "FT1000D", "FT-1000D 2 El Delta loop array", "ft-1000d, SAME ARRAY AS 40M", "FT-1000D", "FT-1000-D into a linear", "FT1000-D Into a linear", "ft 1000d, cai amp", "Yaesu FT1000D into amp  dipole", "Yaesu FT1000D into amp  dipole", "FT1000D, CAI LINYEAR, DIPOLE", "FT-1000d, ampl, 2 delta loops", "FT-1000d, ampl, dipole"
   W8A, 14, ", "drake tx4 homebrew 8874", "T-4X, Amp (2x 8874), RCH receiver", "drake t4x+amp vert dipole  "made Homebrew potato chips yesterday" "The squirrels broke my 10M ant"", "Modified Drake T4X to a pair of 8874's WD8BIL", "Drake T4-X into a linear", "Viking Bud", ", "viking bud, rch receiver", "t4x to 8874's,  scott rch", "Drake T4X into amp", "Johnson Viking I Drake R4A  Dipole", "T4X", "Viking "Bud" xmtr, R4A, dipole"
WA3VJB, 13, "Collins 300G (810s mod by 810s) Broadcast TX (1946) SP-600 rx", "Collins 300G / SP-600", "300G, SP-600, dip", "Tx- Collins 300G,Rx- SP600", ", "2 X 810 by 2 X 810 (Collins 300G) and SP-600 ", "Collins 300G Broadcast Rig", "Collins 300G Broadcast", "collins 300g, sp600", "300g, sp600", "Collings 300G", "300G 810s X 810s, SP600", "300dCollins/SP600"
  K0KP, 12, ", "johnson viking 2 national nc77x", "DX-60, HR-10B, dip", "DX 60B", "  h..dx60b...hr10 rx   d104, dipole "10-12 watts carrier.".200ft long owl feeder..strong!!! hi for the day 10 deg   low-8 deg 522", "VIKING II    NC77X", "DX-60B and HR-10 Receiver S-9 +10dB!!!", "DX60-B - Strongest signal  from a barefoot rig heard!", "DX60B, HR10B, ZEPP", "dx60b/hr10b/dipole", "dx60b d104", "IC-7700"
 W0VMC, 12, "4x1", "homebrew", ", ", "HB 4-400   QS1R", ", "4-1000 X AL10-277 Modulators", "4-1000 mod by pair of NL-10277 Modulators", "hb 4-1000", "4-1000  NL1077", "4-1000, 277MODS, 160 LOOP", "4-1000, SDR rcvr, 160M loop"
 K3JRR, 12, "johnson", "Ranger, Desk KW", "Elecraft K3, amp 400, half square", "Heading from MD to VA QTH, FT450D, amp, 125 watts, HB whip", ", "Home QTH Criders, VA - Johnson Desk KW with HRO-60", "Johnson Desk KW", "Mobile in motion", "desk kw, hro60", "Mobile  FT450 into mobile amp running 125 watts carrier ! ", "DESK KW, HR60, DIPOLE", "Desk KW/HRO60"
KB3OMM, 12, "viking 2 811's", "Viking 2 external modulator with 811s, R-390", "Viking II w/ext 811 modulator", "Viking 2 ext 811 mod", "Highly modified Viking II", "modified vik ii, r390a", "modified vik ii,  r390a", "Johnson Viking II ", ", "VikingII/811 mods", "pr 6146s mod by pr 811As", "Viking II pr 6146s mod by pr 811As"
WA1IIE, 12, "johnson 400", "Johnson 500, NC-303", ", "Johnson 500,Tx-Valiant,Rx-NC303,open end wire", ", "Johnson 500", "Johnson 500", "Johnson 500", "johnson 500, nc303", "Johnson 500(400 al la TIMTRON)  ", "Viking 500, NC-303", "Johnson 500,  NC-303, ctr fed dipole"
 KL7OF, 12, "FT-102 4 el monobander on 6' post!!! Brian W1LYD in shack", "HB 2 x 813 modded by 2x 813, R-388, beverage rx antenna", "TESLA360 (813'S) RACAL 6790", "813'S X 813'SRACAL", "HB 813'S RACAL RA6790", "H.B. 813s by 813s", "813's x 813's,  dipole", "FT102", "FT102, 4 ELE@6FT", "hb 813's/500w", "813's", "FT-102, 10 m beam"
  WF0N, 11, "l4b flex 3000", "flex 3000 drake amplifier", "Flex 3000 L4B amp TA-33 antenna", "Flex3000,Drake L4B", "flex .... stay flexible", "Flex 5000", "flex3000 - l4b, dipole", "flex3000 - l4b, mosley tribander", "Flex 3000 pair 3-500Z  Dipole", "flex 3000/drake l4b", "Flex 3000, Drake L-4 250 w."
  W2VW, 11, "non descript rice box", "non descript rice box", "junk", "kenmore", "ts440,2x8875's 4el monoband", "TS440", "TS440", "Nice signal", "ts-440, PR 8875, 124 WATTS", "ts440 pr 8875's", "TS-440, ampl pr 8875, "
  N2BE, 11, "dx100 r390 verticle", "Viking Challenger, 20w, dip @ 50ft, Howard BC779A", "DX-100, R-390", "DX100", "Viking Challenger", "j. challanger,  bc 779, dipole", "DX100  R390  into vertical ", "Johnson Viking Challenger  BC779A  Dipole at 50'", "DX100/vert/R390", "Johnson Challenger, BC-779", "DX-100, R-390, grd mounted vertical"
  W1AC, 11, "johnson 500 timmy place", "Viking 500, 75A-4, G5RV", "at Tron's place, big sig, 5/9+25!; Johnson 500, longwire", "JOHNSON 500  COLLINS 75A4", "House Sitting for Tim WA1HLR", "House Sitting for WA1HLR", "johnson 500 (at hlr mountion!)", "johnson 500.   (at hlr mountain)", "Johnson 500 75A4", "75A4/HOME BREW", "Junkston 600"
 AB3HT, 10, "icom 4-100a amp 350 watts", "icom rice to 4-1000 linear, sounded quite distorted", "IC765, 4-1000A Amp", "ICOM 765 into a 4-1000 linear", "ICOM 765 into a 4-1000 linear", "ic 765,  dipole", "ic765 - 4-1000, dipole", "IC 765 into dipole(Up 40')", "IC 765 into dipole(Up 40')", "ICOM 765, 4-1000A"
 N1XZW, 10, "g76 90 watts", "Gonset G76", ", ", "Gonset G76", "Gonset G76", "g76", "Gonset G76", ", "Gonset G-76, dipole"
 W1AEX, 10, "flex-5k to 2X 3-500z @220W", "Flex 5000", "Flex 5000 into a linear", "Flex 5000 into a linear", ", "flex  5000, amr 175 out", "Flex 5000A  Pair of 3-500A", "FLEX 5000, (2) 3-500Z", "nice sig", "4-400"
  KW7Y, 9, "appache  110", "dx60b", "dx60b", "DX-60B - 2 X 813 / HR10", "DX60B 2x 813 amp, HR10B", "807,x807,s HB 11 tube RX!  how many hb rxers have you heard about?  ", "dx-60b PAIR 813's", "Apache, HQ-110. 4 el yagi @70'        (Using FT-2000, pr 3-500Zs and KT34A tribander on ", "DX-60B, HR10 rcvr, pr 813s"
 K3SQP, 9, "Apache, NC-300, dipole at 50 feet", "Apache, NC300, dip@50", "Apache", "TX-1, NC300, DIPOLE", "tx-1, nc300, dipole", "tx 1, nc300", "Apache TX1 NC300 Dipole", "APACHY, NC300, DIPOLE", "Apache,NC-300, dipole"
WA0FDV, 9, "DX-100 / 51S-1  75 meter loop", "AF67", "af67+hb amp3-400's?  400watts....loud...75s4rx  "7=8 deg temp"  oyster stew for dinner,cigar for dessert", "elmac+ 4=400,s", "DX100B COLLINS 51", "Elmac AF-67  30 watts", "AF67 driving a HB linear", "af67/4-400's/75a4", "AF-68, pr 4-400s, 75A4, 1 1/2 wave loop ant."
 W1VTP, 9, "Flex 5000 Johnson Courier AMplifier", "flex-5k", "Flex 5000, Johnson Courier amp, 52w,dip", "Flex 5000 Inverted V", "Flex 5000 to a Courier Amp @ 52 watts", "Flex 5000 into a linear", "flex 5000", "Flex 5000  Johnson Courier Inverted Vee", "Flex 5000"
   W9A, 9, "w9ad flex-5k", "SDR5000 REMOTE", "SDR5000", "Flex 5000 into a linear - Remote from Mexico", "flex5000,  hytowers\", "FLEX500A, AMP, HYTOWERS", "flex via mexico", "Flex 5000, verticals, via internet control from XE land", "Flex 5000, Prometheus, vertcals, ampl, via internet control from XE land"
KD4BAO, 8, "ft450", "ft-450 @ 20w", "FT450, 20w, Fan dip", "FT-450", ", ", "FT-450 20W, dipole", "FT-450 20W, dipole"
WA2PJP, 8, "kw1", "Johnson 500, SX-88 rx, dipole at 70 feet", "Viking 500, SX-88", "Collins KW-1", "Johnson 500", "kw1, 75a4, dipole", "KW1/75A4, DIPOLE", "KW1/75a-4"
 AB2RA, 8, "Valiant, HQ-180, dipole", "Valiant/Timtron mods HQ 180 59", "Valiant, HQ-180, dip", "Valiant HQ-180 Dipole EV 607 Mike", "Valiant", "valient, hq180", "Johnson Valiant HQ180", "
 W1FRM, 8, ", ", ", "Mr. T - Homebrew Pair 813s mod by 805s", "TS-440 into a single 3-500Z amp", "mt "T"", "TS440 into 3-500Z 120 watts  200' Inverted Vee", "813/805 NC300 200ft Vee"
 KN4ME, 7, "ICOM 735/SB200", "Icom 735 with Heath SB-220 amp", "HB, 4-1000 mod by 813s. NC-183", "ICOM 735 into a linear", "ic735 - sb200, dipole", "IC735, SB200, Inverted V", "IC-735, SB-200"
 W8MNQ, 7, "ht9", "Collins,D104,Ranger Desk KW", "ranger -  desk kw, 75a4", "75A4, VIKING RANGER& DESK KW, ", "ranger/desk kw/75a4", "johnson desk kw", "75A4,Ranger, Johnson Desk KW, inv vee"
 AB2KC, 7, ", "dx100 sdr1000", "FT-1000D,Amp-Tempo@200w,Quad Antenna", "Flex 1000 receiver with DX-100 to 4-1000 amp", "4-1000 modulated by 304-TLs", "4-1000/304th mods, Flex receiving...", "DX100 driving 4-1000 304TL modulator  SDR Receiver"
WA2BAH, 7, "viking hro", "Valiant 1, NC-303, dipole", "Valiant, NC303,", "Valiant", "valient, nc303", "Viking Valiant HRO60 Dipole", "VALIANT/NC303"
 W2JBL, 7, "ht37", "Viking 2 with heath SB-220 amp, R-309, dipole at 40 feet", "Viking II, SB220, 225 w, dip, R-390A", "Viking II into a linear", "vikii, sb220, r390a", "ht37 - sb220, r390a,  dipole", "Johnson Viking II  Stewart Warner SB220  80 meter dipole"
 W3GMS, 7, "Ranger 2 into 3-500 linear, Ten-Tec Jupiter (RX) 260 foot center fed at 60 feet", "Ranger, 3-500z amp, dip", "Ranger amp, dip", "Ranger II into a linear", "ranger ll to  pr 3-500's 350 watts", "Johnson Ranger II (Highly Modified) driving a pair of 3-500Z's", "Johnson Ranger II into pair of 3-500Z  Centerfed dipole"
WA1IWQ, 7, ", "4-1000/8568", "4-1000 mod pair 5868's", "Modified Valiant", "H.B. 4-1000 modulated by 833As", "4x1, r390a", "HOMEBREW"
WA9CGZ, 7, "homebrew, dipole", "HB SDR", "HB SDR", "50w/dipole", "50w hb dipole", "Home Brew SDR 50 W xmtr, dipole", "Home Brew SDR 50 W xmtr, dipole"
 KE3SX, 6, "dx60", ", "FT-950", "dx 100, dipole", "FT950 ", "DX100, NC303, DIPOLE"
  W9HW, 6, "7700", ", "dyy senior", "K7DYY Senior", "k7dyy sr. class e xmtr", "K7DYY Sr 300 w, Icom R-70, dipole"
 W3TIM, 6, "flex5000 al1500", "Flex5000, AL1500 amp, 350 watts", "Flex 5000A AL-1500", "Flex 5000 into a linear", "flex 5000, al1500, 630' zepp", "FLEX5000, AL1500 AMP"
KB3WFV, 6, "ts440", "TS440, dip@50ft", "TS-440", "ts440, dipole", "TS440 Heil  80 meter dipole", "
 W2PHL, 6, "ft2000 delta", "yeasu ft-2000d vee@40ft", "FT-2000", "Yaesu FT2000D   Inverted Vee", "Yaesu FT-2000", "SP2000D, INV V"
  KB8V, 6, "32v3", "32V-3, 75A-4", "32V3", "32v3/75a4/dipole", "32V3, 75A4, folded dipole", "32V3, 75A4, folded dipole"
  K5UJ, 6, "FT-1000 with TenTec 3-500 amp, 75A3", "Yeasu Mark 5 into a linear", "FLEX, INV L", "1000MP MK5, DIPOLE, 75A3", "FT-1000mp Mk5, dipole, 75A3", "75A3, FT-1000mp mk5, Ten Tec Centurian ampl 300W, dipole"
 W3EMD, 6, "32V-2, 75S-1  600ft horiz loop", "32V3 and 75S1", "32V3", "32v3, 75s1, loop", "32V3", "32V3, 75S1"
 K4AAM, 6, "HB TX 813's mod by 813s, dip@35 ft", "2 X 813 by triode connected 2 X 813", "Pair 813s mod by triode connected 813s", "813's x 813's, dipole", "Pair 813 modulated by triode connected 813's", "813x813, VIKING1 DRIVER, "
WA2ROC, 6, "Viking II, NC300, 80m loop", "tx 1, rx 1, loop", "Johnson Viking II NC300  Loop", "nc300/Viking2", "Apache TX, Mohawk Rec, Loop antenna", "Mohawk, Apache, dipole"
 K9EYE, 5, "k7dyy junior class e", "k7dyy Jr. Icom R75,D104,Double Bazooka", "k7dyy jr./icom r75/double bazooka", "k7dyy xmtr", "K7DYY Jr, R-75 rcvr, double bazooka ant"
KC8ZUL, 5, "bc1f @2700lbs", ", "gates bc1f/icom r9500/dipole", ", "BC-1F, Icom 9500 rcvr, dipole"
  K1KW, 5, ", "dual log periodics, high angle", "4 10 el logs..ricebox and amp  big  sig", "FLEX 5000", "log periodic beams"
 K0CDJ, 5, "dx60 n303 receiver hi gain explorer beam", "DX60, Explorer 14 beam", "Tx- DX60,Rx- NC303,Ant.-tri-band@65'", "DX60 NC303", "DX-60 Beam Explorer Hi-Gain NC-303"
 W2CHX, 5, "valiant r390", "Valiant 1, R390, dipole", "Valiant", "Viking Valiant R390  Dipole", "Valiant/R390"
WB1GGL, 5, "t368", "T-368 folded dipole", ", "FT-900 Barefoot", "
 W1MPY, 5, "flex 5000", "flex 5k into an amp", "Flex 5000", "Flex 5000 into a linear", "flex 5000"
KC9PCP, 5, "halicrafter", "2X 813s screen modulated & wire out the window", "homebrew, longwire sx140", "813's/sx 140", "pr 813s screen mod, SX-140 RX"
  WZ5Q, 5, "ts950", "TS-950, Alpha 89 amp, doublet at 60 feet", "Kenwood TS-950SDX / Alpha  89 AMplifier 3 el steppIR", "TS950 into a linear", "ts950sds - amp, 350 watts to 3 el stepper"
WB3FAU, 5, "B & W 5100, Collins 75A2, 100W, Diploe", "B&W5100, 75A-2, dip, 6" snow", "Boat anchors", "BW5100, 75A2, DIPOLE", "B&W 5100, 75A2, sloping dipole"
KB2OUA, 5, "TenTec Arognaut 5 w L-4B amp 160W. Drake 2B", ", "TenTec Argonaut 5 into an L4-B Linear", "dx40 - 3-500z's", "Argonaut , Drake 2B Rcvr, double ext zepp ant"
 W1FYO, 5, "ARC-5/BC-457 with homebrew modulator 35W 500 foot wire at 55 feet", "BC-457A FT-101CD", "ARC-5", "Arc 5", "ARC 5 BP548  35 watts center fed zep"
KA7NGT, 5, "Icom 707 into a linear, 150 watts", "ICOM 707 & AMP", "805'S X 811'SHQ120", "wa state patrol converted tx810'sx810's   cool...has all star radio rx..w/gloppy messes of solder", "icom+amp"
KC2UDZ, 5, "Kenwood TS-440 4-1000 GG wire colinear antenna", "class-e", "Class E", "TS4400S", "class e shaired with kerry"
  WS4B, 5, "ground mounted vertical", "Hybrid FT-102, 1/4wave vertical", "FT102", "Nice signal Brad", "Cutting through the noise!"
  W1UX, 5, ", "32V1 and 75A1", "Valiant - highly modified", "32v1,  75a1,etc, etc, etc...", "Valiant R390"
 K8VWX, 5, "T-368, SP600", "Homebrew,5868, super pro 600, Delta Loop", "T368, R390, DIPOLE", "4-1000 by 5868's/sp600/dipole", "SP-600, Home Brew pr 4-1000 mod pr 5868, loop "
 K4KYV, 5, "HB TX, 75A-4, dip", "2 X HF300's by 2 X 810's 75A4 Sherwood Synchronous Detector", "P/R HF400s mod by 810S", "hb hf300's, 75a4, etc...", "HF300x810s, 75A3, DIPOLE"
WA2CWA, 5, "Flex 5000, SB200", "IC756", "Flex 5000A", "flex - sb220", "Flex 5000 into SB200 "
  W3AV, 5, "Flex1500, Johnson Thunderbolt, delta loop", "Flex 1500 Johnson Thunderbolt", "flex 1500, diploe", "Flex 1500 Johnson Thunderbolt", "Flex 1500, Johnson Thunderbolt amp, doublet ant"
 W0NKL, 5, "Delta 500 Icom 7800", "Johnson 500", "d500/icom 7800/verticle", "Johnson 500", "Johnson 500, IC-7800, loop ant"
WA2CYT, 5, "Viking 2 FRG7700", "Viking II", "vik ii, frx 77, loop", "VIKING2/811A", "Viking II mod 811As 75W "
 N1GTU, 5, "Class E", "Class E", "Class E Rig - 400 watts", " hb class e", "CLASS E"
   W1G, 5, "Regular call is KB2WIG Ranger II - IC-706 for receiver", "Ranger II", "ranger ii, rx ic706", "Viking Ranger II", "RANGER 2, IC706 RCV"
 W1DAN, 5, "Class E", "H.B. Class E Rig", "ft1000 to class e", "FT1000 Class E Amp", "FT1000, CLASS E, DIPOLE"
 K5IIA, 4, "PR 813'S/MOD PR 813'S", ", "HB rig, 2x 813s mod by 2x 813, sdr", "813's x 813's..."
 W0HRO, 4, "hro", "viking II", "viking2/sx28", "
 W9LRS, 4, ", ", "johnson 500/r8a", "vik 500"
 K7YOO, 4, "globe 500b", ", "ts2000 & amp", "Globe King 500 "
 NJ2MR, 4, "ranger", "Inverted Vee", "Ranger into a linear", "JOhnson Viking Ranger into 3-500 Z   R390  Inverted Vee"
 AB2EZ, 4, "ranger russian triode amplifier", "ranger to plate mod russian ts35Bx2 tubes with SS audio/step-up xformer / heising", "ranger - pr gsb 35b's, rx -flex 1000", "Johnson Viking Ranger into Russian triode amplifier in a heising configuration"
 KK7VY, 4, "ft101e horizontal delta loop", "FT-101E FL2100B (My first 15 meter AM contact ever)", "FT-101E, FL2100 amp", "FT101E into a linear"
 N1GTY, 4, "drake tr4", "TR-4", "Drake TR-4", "TR-4"
KA2MCU, 4, "valiant", "Valiant", "Viking Valiant National NC303", "VALIANT/HRO60"
KB1NFS, 4, "ranger", "Ranger / Radio Shack DX-160", "Ranger", "ranger, dx160 (radio shack rx)"
WB2DCU, 4, "apache", ", "Apache TX1 Mohawk RX1 Dipole  D104", "
KB1PJM, 4, "dx100", "BC610", "dx100, hro rx", "DX100"
 W1MPF, 4, "icom 150 watts", "FT-450", "FT-450 into a linear", "FT450"
  NT8W, 4, "Homebrew 250THs mod by 810s, 75A4, 160m. vee at 85 feet", "Homebrew 250TH X 810s  inv V @ 85'   820' feedline", "hb tx, inv v", "pr 250ths mod by 810s, 75A4, 160 M inv vee @ 85'"
 W2DAS, 4, "Apache, NC-303, 100w.", "Apache", "APACHE/NC303", "Apache, sloper dipole"
 N2DTS, 4, "813s, 32v3 driver 4x150as modulators, sdr1q recvr", "3 x 4D32, SDR IQ", "DX432", "3-4032  modulated by 811A's"
KB3KRJ, 4, "Flex5000, 3x 3-500s, 300w", "Flex 5000 into triple 3-500Z amp", ", "Flex 5000, "
KA1KAQ, 4, "KW-1, 75A-4, dip", "KW1 37 degrees in the garage", "kw 1, 75a4", "COLLINS KW1, 75A4, DIPOLE"
WA2DTW, 4, "Flex 5000A, SB220, IV", "Flex 5000A driving Heath Amplifier", "Viking II", "FLEX5000A, SB220, INV V"
 K1ETP, 4, "813 rig", ", ", "
KA2QFX, 4, "FT-101E, Amp", "TS-440", "Modified FT-101 into a linear", "FT010/AMP"
KC2TAU, 4, "Ranger, HQ-129-X, 80M Inv L", "Ranger 1 Hammarlund HQ-129X Inverted-L", "Ranger", "Johnson Viking Ranger I  HQ-129X  Inverted L"
KB3UOA, 4, "Apache, HQ-180, rotatable dip @ 40ft", "Apache TX-1 HQ-180 Hy-gain dipole", "Hallicrafters HT40  HQ180  Dipole", "Hallicrafters HT40  HQ180  Dipole"
 K2LMQ, 4, "Globe King 500B, 75A-4, dip@55ft", "glob king 500b,75a4", "Globe king 500B", "gk500"
  WV9R, 4, "ft101 ex Dipole Turner +3", "ft101ex/turner+3/dipole", "ft101 dipole", "FT-101EX,"
WA9EIC, 4, "OCF, Dipole,75A Receiver", "collins 32v1/75a1/ocf dipole", "32V, 75A", "FT-857, 75A, 32V, windom ant"
KC2QMA, 4, "Yaesu ft2000,heathkit sb220, g5rv", "ft2000/heathkit sb220/g5rv", "ft2000 - sp600", "FT-2000, SB220 175 w G5RV ant"
KA7WOC, 4, "811'S X 811'S", "GATES", "ran 4 rigs for me..811sx811,s..."Barney hb rig" ..Ranger and viking 1..strapper!", "gates 250 g boatyard bob"
KE7GPO, 4, "JOHSON DESK & NC300", "MCMARTIN", "johnson desk ,hq145x", "mcmartian BC TX  LOUD ,,,excellent"
 VE5NT, 4, "805'S X 813'S", "HB saskatchawan", "fantastic frank....  HB TX "imperial gallon "    813's in PP  807 driver  2200 volts===805 modulators   dipole w/owl ...rx hq110", "HB xmtr"
  K0JM, 4, "813'S", "the truth is I'm an old guy and I can't lift those boat anchors any more.", "Rice Box into a linear", "icom 7600/qro 2500 amp"
WA1CLK, 4, "QRP ICOM 703 - 3 Watts - VERY strong for the power", "QRP ICOM 703 - 3 Watts - Great Signal", "qrp, 3 watts, ic 703, dipole", "IC703 running 3 watts ! "
WD4LUR, 4, "DX100", "dx100, nc303, hitower", "DX100/NC303", "DX-100,4-1000 amplifier,NC-303, HyTower vertical antenna"
  W3UX, 3, "flex 5000 @40w inv v", "Flex 3000 into a linear", "Flex3000 AL1200"
 AA8DC, 3, "ranger 1", "Yaesau FT-101B with Dentron Amp, Inverted Vee", "Viking Ranger I"
KA9BQR, 3, "t150", "knight t150/hr10b/dipole", "
 W9WRL, 3, ", "ft101e/dipole", "
  K9OA, 3, "globe 500c", "globe king 500c/75a4/double bazooka", "
 WO9DX, 3, ", "collins 32v1/75a1", "
 K9AAL, 3, ", "kw1/75a2/dipole", "kw1"
 K4YAB, 3, "Harvey wells @10w  1500 recv", "Harvey Wells, Flex rcv, QRO amp", "Harvey Wells 10 w."
WA9NJR, 3, "g76 gonset on battery", "gonset g76/813's amp./fw loop", "Gonset G-76 xcvr, pr 813s 250 W.  full wave horiz loop"
 KD6OS, 3, ", "icom 747 pro w/amp. Telrex 20 ant", "ic746 3el beam"
 W7ISJ, 3, "l-mac pmr8", "AF-67/PMR-8 wire antenna Not mobile may be dupe dunno", "4 x5  tnx joe"
  K2PM, 3, "ft102", "FT-102 into a linear - Very good audio", "FT102 with amplifier"
WA2CJS, 3, "class d homebrew", "100 Watts H.B. Class D", "Homebrew Class D Collins 75A4"
 W1VZR, 3, "ranger", "H.B. 813 rig mod by 813s", "813/SX25"
 N2MIN, 3, "johnson viking 2 hammerlund", "Viking II", "Viking2/HQ129"
 K1KBW, 3, "icom", "hb pwm class e tx", "CLASS E"
KA2CAF, 3, "Viking II / R-392", "Valiant", "vik l, r392"
WA1GFZ, 3, "sdr to mri amp @300w", "Class E", "HP SDR Software Defined Radio into a solid state linear"
WA2UJX, 3, "756 pro @ 35W, knows pdm theory", "FN31 ami 1361 Icom 756 Pro2", "IC756 PRO II  "
 W2JTD, 3, "DX-100, NC300, dip, DX-60, amp (AL-811), R-390A", "dx 100/dx 60 - al811, r 390", "DX 60B into Ameritron Amp  "
  WB2G, 3, ", "ic 746p, mla 2500", "VIKING VALIANT, SX100, DIPOLE, MT3000"
 KD0HG, 3, "HB TX (2x 304TH 2x 304TL mods), R-390A, double zepp, 140ft", "304tls  la bamba dropped out during qso. wa happen?", "la bomba, r390a"
 W6OZI, 3, ", "20v2, sp600", "50 ft tower "tryin to keep my business afloat"voodoo man kenwood" also globe tx?"
 K6JEK, 3, "Class E", "always strong on my calif bev", "Class E Rig"
 K6JSI, 3, "Bauer 707, 1000 long horiz loop, 74A-4", "nc183d rx   strong sigs!!!  bauer bc tx   370wts carrier 1`000 ft loop", "BOWER 707   COLLINS 75A4"
 K1RMA, 3, "Viking II, SP600", "SP-600 Viking 2 80-meter loop", "Viking II"
 K1OIK, 3, "DX-40", "DX-40 SX-76 G5RV", "Heathkit DX40"
 K8WIK, 3, "FT-817, solid state amps", "Yaseau 817 QRP Rice Box", "ft817 driving 2 ss amps, expermenting..."
 AB7KT, 3, "Super Senior TX, 300w, 75A-4, dip", "Super Senior 300 watts", "k7dyy super sr."
WA6HCX, 3, "20V3", "20v3", "Collins 20V3"
KD7EDR, 3, "TS480, 25w, 130ft wire", "kenwood 480", "TS480"
KE7TRP, 3, "2x 4-400 mod by 2x 304TL", "big group -glob tx", "Pair 4-400s mod by 304TLs"
 W8NWF, 3, "Homebrew 6868 tube,4164's,TS930 receive", "homebrew 6868 by 4/6146's/ts 930 for rec.", "Homebrew 6858 xmtr, RME rcvr, dipole"
 W9MIM, 3, "Warrior,Yeasu Ft101", ", "ft101/warrior"
KC9LKE, 3, "art13, bc348, Dipole", "art 13/bc348/ dipole", "ART-13, BC-348"
  NN9T, 3, "Dipole,Icom703", "icom 703/dipole", "IC-756proIII, dipole"
 W9RGM, 3, "1613,  kenwood 570", "kenwood ts570", "TS-570, AL-811, G5RV"
 N8UUH, 3, " National l303, Globe King", "globe king/nc303", "NC-303, Globe King, Loop ant"
 KG8LB, 3, "NCL 83D, Globe Champion", "globe champion/nc183d", "Retro 75 receiver, K7DYY Super Sr, Globe Champ 300"
 W9JXN, 3, "Johnson Viking Ranger, collins5ij4, carolina windum", "ranger/collins 51j4/windom", "51J4 rcvr, Johnson Ranger, Carolina Windom ant"
  W0KH, 3, ", "k7dyy sr./drake r8", "
 VE8XJ, 3, "bc610 rca rx       canada Northwest territory  NWT ", "32V1, HRO60, 4 ELEMENTS, NORTH WEST TERRITORIES", "32V1, RCA CR 88 rcvr, tribander up 50'  Northwest Territories"
 KA0JW, 3, "32v1...75a4... working on viking 500", "collins 32v1/75a4", "
 KD0ZS, 3, "boatanchor tx---rx", "DX100", "dx100/r390urr"
 N1YAE, 3, "FT950", "FT-950 into a linear", "FT950/Dentron amp FB sig"
 KB5MD, 3, "Dr. ", "833's by 833's/75a4", "pr 833s mod by 833s, 75A4, phased verticals"
 W1MSG, 3, "SDR5000", "Flex 5000 to Commander 2500HF", "Flex 5000, Commander?"
 KC2KJ, 3, ", "K3", "K3"
 W1JDR, 3, "32V3 with a 75A4", "32V3", "32V3 75A4"
 W3FJJ, 3, "FT-1000D barefoot", "g-76, 40 mtr dipole", "ft 1000d, vert"
 N8LGU, 3, "B & W 5100", "5100B, HQ110, Vert", "Viking II, HQ110 "
 W8IXY, 3, "K3 into a linear", "elecraft k3/811 amp", "K-3, ampl, dipole"
  K3YA, 3, "Collins 30K4 R390 ", "32V3 75A3", "32V3, 75A3"
WB8UHZ, 3, "DX-100, HQ-140X , Dipole", "DX-100, HQ-140X, dipole", "DX-100, HQ-140X, dipole"
WD8DWR, 3, "75A4, Valiant, loop ant.", "4-400s mod by 4-400s, 75A4, loop antenna", "Ranger II, 75A4, dipole"
WA9VRH, 2, ", "af67/dipole"
KD8CVY, 2, "kenwood 570 clippeerton amp", "TS-570, amplifier, dipole"
 N8ECR, 2, "32v3", "pr 250THs, R-390A, wonder wire ant"
  KZ7L, 2, "rci 2970", "RCI 2970 10W carrier 100W peak IMAX 2000 antennt"
 AD7FX, 2, "icom 746", "Icom 746 (original model) ALS 600 amp 40m dipole"
WA8TWM, 2, "halicrafter sx111", "DX-60"
WA0STX, 2, "ts440", "
KA2DZT, 2, "171 watts! homebrew", "Homebrew 813 modulated by 811  National HRO M Full wave loop"
 K1VYU, 2, "viking 2 sx71 receiver", "Ranger 1, dipole, SX-71"
 W1GHL, 2, "flex 3k", "Flex3k"
 N3JUH, 2, "globe king", "Globe King"
  W5JO, 2, "icom 756 pro", "IC756Pro, tribander"
WB2ENI, 2, "Viking 2, HQ-170", "Viking II, dipole"
  NE7X, 2, "32V-3 / 75A-1 ", "32V3, 75A1, 10 m yagi"
 K0ETD, 2, "Kenwood TS-850 Heath amp dipole", "TS850"
 N9HSB, 2, "harvey wells bandmaster to b&w 1000a (2X 813s)", "Strong sig for abt 30 secs and then faded away  short qso "
WA4PGI, 2, "Apache, Mohawk, dip", "tx-1, rx-1, inv v"
 N8AFT, 2, "IC718, ALS600", "IC-718, ampl, dipole"
 W0HIO, 2, "Viking II, R-4B, horiz loop", "Viking II w/ screen mod, R4B, dipole open wire"
 N9UYC, 2, "FT857, ALS500 24 degrees", "FT-857, ampl, "mystery antenna" inv vee"
 VE6PG, 2, "Viking 2 CDC, SX-101, 160m loop", "VIKING  2CC, SX101, 160 LOOP"
WA3JYU, 2, ", "gc 500c,  r 1000, dipole"
 W1GHW, 2, ", "200 watts"
 KD3CN, 2, "Eico 720, SB200", "eico 720, fr 75, folded dipole"
KA8WTK, 2, "HB 4-400 TX, R-390A, dip", "r 390 rx"
 K0ARA, 2, "HB Rig", "Millen P/R 812s mod by 811s"
 W6TJK, 2, ", "turned it over very fast....contest style   rice box"
WB8CTC, 2, "25w 80m dip", "Low Power"
 W6SGJ, 2, "GLOBE SCOUT & GLOBE AMP", "32V2 NC125"
WA3QGD, 2, "ICOM 7800", "icom,all band dipole"
WA7DOC, 2, "32V1R390A", "32v"
 VE7RZ, 2, "RANGER & AMP", "ranger+amp canada clip leaded together"
 W7NWC, 2, "RANGER 811'S X 813'SR390A", "nc 300 rx ranger driving 813s x 811's.."
 N7KLV, 2, "RANGER AMP", "do=dah...d0=dah ranger into 4x 813's linear.300 watts..gentlemen and others"
 W7BNZ, 2, "BC610", "bc610..r390a "sunshine until the stars  came out""
 K7RLD, 2, "K7DYY SENIORAND NC400", "dyy senior nc400"
  W9AD, 2, ", "flex 5000 "
« Reply #2 on: February 29, 2012, 10:35:06 PM »
WB6QKO, 2, "Hallicraft Tx and RX", "RANGER 2950DX@9 WATTS, 4 ELE SPIDER BEAM"
 K4GHT, 2, "TCS-13(US Navy) HF Transmitter&Receiver", "Mobile"
KA0SKK, 2, "northern radio tx,sx101,inv v 100 watts ", "
  K0OJ, 2, "32v3 75a2", "32v3 ami#155"
  W0FT, 2, "ts 2000 +amp", "ts2000 amp"
 W7JSC, 2, "32v3,75a4,dipole", "
KC7GOL, 2, "ic746,collins amp", "ic746 g5rv"
 KC7PH, 2, "k7dyy super senior racal 6790", "dyy supersenior tx "
 N8AGJ, 2, "hb 4-400s x 304tl,s  r3-90    LOOOOUD", "hb 4-400"
 KF0OW, 2, "hb 813x811's 300wts.  sx101 rx", "813's by 811's/sx 101"
WB0TTW, 2, "apache ,doublet,", "APACHE"
KK5D/XE1, 2, "SONORA MEXICO  IC 7600+amp 250watts", "IC760"
  NY6L, 2, "orange,ca ricebox", "Globe King 400"
VE3OWV, 2, "TS870", "SP-600 1/4 WAVE VERTICAL"
 W1GCI, 2, "Johnson Ranger, 75a-2", "ranger - 25 watts, 75a4, dipole"
KB1IAW, 2, "IN-AND-OUT", "Valiant"
  K1MV, 2, "Icom Dipole", "Ranger"
  N1PS, 2, "Class E", "Mobile in motion - using a rice box"
WA1OBD, 2, "IC-706", "Icom 706"
WA1ZCQ, 2, ", "IC703 running 4 watts using a solar panel for power lead acid battery - 2 phased verticals"
 W1RKW, 2, ", "retro 75"
 W2NBC, 2, "Class D as in "Douche"", "hb class d tx"
 W1TAV, 2, "Stock Ranger", "32V3"
KD2AOT, 2, ", "FT 950, Dbl bazzuka"
 W1ZZZ, 2, "Valiant", "
 W1GRC, 2, "Ranger, modified", "Ranger/Matchbox "
 N1YTN, 2, "HB 813 mod by 811s", "
WA1LGQ, 2, "Viking I ", "Viking One R390"
WB2FOU, 2, "DX-60", "DX60  HR10"
KB2KNX, 2, "DX-40 1st time on AM !", "DX40 75A2"
  K1NR, 2, "T4X-B", "T4XB/R4B"
KC2WTS, 2, "Valiant", "Valiant, BC-779, dipole"
  W1IF, 2, "Cochina rice box", "Katchina 505DSP"
WA3WBC, 2, "Valiant", "val ii, 75a4"
KJ4MCZ, 2, "TS2000", "TS2000"
KA1MQM, 2, "Flex 5000 into a linear", "FLEX5000/AL82"
WB2ERS, 2, "Flex 1000 into a linear", "sdr 1000"
KB3RDT, 2, "Viking II", "vik ii, sp600"
  N2XD, 2, "20v3, 75a4", "Collins 20V3, 75A4, Inv Vee"
  K3ZS, 2, "af 67, gsb 101, hq 140x", "AF-67, Gonset ampl 175 W, PMR-7, doublet"
  K2FW, 2, "eico 720, 75a4", "EICO 720 into amp EICO 722  75A4"
KC9TTR, 2, "FT897, DIPOLE", "FT-897, dipole"
  W9QI, 2, "collins 32v3", "32V3, R4C rcvr, dipole"
 N8RWS, 2, "kenwood ts940/re27/commander hs2500", "TS-940, Commander ampl, dipole"
 W5FFK, 2, "ranger/warrior/r4a", "Ranger, Warrier amp, Drake R-4A, full wave horiz loop"
 AA0PO, 2, "ts 2000", "TS-2000, ampl, long wire"
WB9GKZ, 2, "ft 101e/2100b", "FT-101E, ampl, dipole"
  K9DO, 2, ", "K7DYY Sr 300 w, Icom R-70, dipole"
WA3MJY, 1, "sx101 sb220"
  KA2J, 1, "t368a"
  K8IH, 1, "chyanne heath kit"
  K8TV, 1, "hb fet @60w"
  KOKP, 1, "dx60b hr10b"
 K8EYE, 1, "dyy jr"
 K9ACT, 1, "class e fet"
  K5HX, 1, "ft1000"
 WAGFZ, 1, "
  N8UH, 1, "icom pro 3"
KB3OUK, 1, "yaesu 150 watts"
 KD2TT, 1, "icom 7700"
WA1GNB, 1, "icom 746"
KC7OVS, 1, "
 KU4SD, 1, "756 pro 3 ameritron"
WA3HVR, 1, "flex 5000"
 K9GAS, 1, "icom 7600"
 K3WJL, 1, "icom 7000"
 AB1QM, 1, "ft 2000"
VE2JWH, 1, "ts140 40 watts"
 N1VIV, 1, "homebrew 6146 hammerlund ht110"
 W4FWB, 1, "kenwood ts2000"
 W3AGB, 1, "tr7"
  AK3E, 1, "flex 3000"
KB3WCW, 1, "yaesu747"
  N0BD, 1, "drake b line 20 watts"
 K0LSW, 1, "yaesu ft990"
 K8WIL, 1, "yaesu"
 W5JJG, 1, "kenwood 570"
 K0CRX, 1, "dx100"
 W2ICQ, 1, "Collins 310B VFO INTO Homebrew 4-250 with 810 modulators 75A4, 500W, 2-HALF-WAVES antenna"
KC2HWY, 1, "Icom 718 - 35W, long wire"
VA3VFO, 1, "FT-102"
 N9HMA, 1, "Viking 2, FRG-7 rx"
W7ISJ/M, 1, "Radio Shack Mobile 7 watts!"
WA0GAG, 1, "B&W 5100B 75 watts 75A-4/D-104 TA-33 @ 40'"
KC2UZD, 1, "Kwnwood TS-440 4-1000 GG 3 el monobander"
 KX5JT, 1, "Viking II D-104 / ICOM R-75 GP antenna"
KC2UDZ/M, 1, "Kenwood TS-440 Homebrew vertical in bed of PU truck"
  K6AM, 1, "Kenwood TS-950 / TL-922 AMplifier"
KA4MHQ, 1, "ricebox 30w"
KC4LNX, 1, "icom-pro, mosley @ 60f"
 WW4AM, 1, "tentek w/ 300ft loop, openwire"
 W1GBA, 1, "kenwood697 carolina windom"
KC8ZME, 1, "IC718, dip"
WB2FCN, 1, "Apache"
 W8BCQ, 1, "IC7700, Tokyo Hipower amp, 200w"
 KF4TV, 1, "
  K4XK, 1, "Viking II,"
 W4MIL, 1, "32V-2, 74A"
 W9FAM, 1, "
 K2VXV, 1, "
KA9NCR, 1, "Globe Champ 300"
WB3FOU, 1, "DX 60, HR-10B, double bazooka"
KB0NMQ, 1, "DX70, 2el, first time on AM"
KB0NWT, 1, "DX-60, HE-30, dip@30ft"
  N4AK, 1, "Viking 500, SX-115, 160M G5RV"
KA9NJR, 1, "gonset g76,homebrew815,horizontal loop"
 AB7YD, 1, "DX60H &HR10"
 W7JKY, 1, "RANGER HT110"
WB6VMI, 1, "KENWOOD TS 440"
 W7RHZ, 1, "KENWOOD TS 570"
WD8KDG, 1, "JOHNSON 500R390A"
KA7KSN, 1, "KACHINA SDR"
 W9UIE, 1, "
 W9VRH, 1, "
KA9DQR, 1, "
 K9UIE, 1, "
  K4HF, 1, "FT-1000D,Amp@350w,(2)Delta Loops"
 K3LQB, 1, "Rx- Collins 75A,Tx- Ranger2,Amp-AL1200@300w"
 K3KKA, 1, "Tx- Heathkit Apache,Rx- Halicraft SX-28A,Amp-Warrior@200w"
 K7EWE, 1, "qso w/w7isj Gates BC 250, 275 watts,NC 300 "
WA0SPM, 1, "32v,75a4"
VE6GY/W7, 1, "ts2000+amp"
 W7TRO, 1, "drake tr4 pissweak"
KE7NUB, 1, "flex 1500 +amp"
WA7HMU, 1, "ranger..wishin for the amp "
WA7HTP, 1, "just popped in on am  ca tx"
  NX6D, 1, "another fast talker... rice box?"
 KF7EH, 1, "ground wave..25 mi path  icom w/ 10 M loop"
 KE0VH, 1, "757 rice box"
 N5VEZ, 1, ".mississippi 750 ft antenna rice box"
 W6EDC, 1, "ft890+amp"
WB6MAX, 1, "rice box  first time AM"
 WA4RG, 1, "drake 4 line"
 K5RHD, 1, "ft897+amp vert ant  first AM contact "
KC6VMB, 1, "ft847"
  K7PP, 1, "hq170 valiant"
 AB2KT, 1, "index labsuper senior tx  75a4 rx"
 K6PLR, 1, "vertical dx60 +amp"
 W7TOW, 1, "vik 2 "
W1LYD/MO, 1, "alaska hwy mobile rice box british columbia CANADA"
  K5XU, 1, "TS570"
 W9AFB, 1, "TS570"
WA4NJY, 1, "VALIANT DRAKE 2A"
 K0MVJ, 1, "FLEX 1500"
 N5LUL, 1, "FT857D"
WN2FMM, 1, "TS570"
 K0IWI, 1, "FT2000D"
  W9VG, 1, "IC765"
KB9ZTF, 1, "FT450"
KD0CZM, 1, "FT857D"
KC9ATD, 1, "TS440"
 W9SBE, 1, "TS930"
KH6ITY, 1, "APACHE MOHAWK"
KI4NSP, 1, "IC756"
VE4ATL, 1, "TS930"
 N5XCX, 1, "TS480 REMOTE"
 WB2YL, 1, "FT5000"
 K1ZPZ, 1, "TS590"
KG6OJO, 1, "TS570"
 W6PSS, 1, "FT840"
WA5VGO, 1, "2E26 TRANSMITTER THEN KW-1"
  W0VT, 1, "Hello Lee! (qrp)"
WD5JKO, 1, "Gonset G75 ->G201"
 K5LYT, 1, "Little Yellow Taxi"
 W5JGI, 1, "Hi Jim!"
  W5SU, 1, "Hi Carl!"
KA5RHK, 1, "Hello Ken!"
 K5KZQ, 1, "Sounds great"
  W3AM, 1, "Very nice callsign!"
 N4RSP, 1, "Nice bike! and great QSO"
  K5RB, 1, "87 yrs young! GREAT QSO!"
 W1TNT, 1, "DX-100-B HRO-60 Ten-Tec 238B Inverted V"
WB1ETL, 1, "FT-900"
 AC2EU, 1, "
  K1BF, 1, "PMR67 QRP PW Net"
KD1MCV, 1, "6L6 Millen Modulator 20 Watts"
KA1CIV, 1, "32V2 with a 75A3"
 W2DEW, 1, "Heath Cheyenne @ 40watts with HQ-170A to an 80 meter full wave loop"
   W2E, 1, "Flex 5000"
KA1WER, 1, "Suffered an "Unscheduled End of Transmission" A.K.A. a crapout!"
 K1REC, 1, "Rice Box"
 W9CGZ, 1, "HB 50 watt transmitter SDR"
KJ4BIX, 1, "32V3 into a linear"
WB2HUP, 1, "Globe King 500B"
 K2TML, 1, "ICOM 756"
 W1KRX, 1, "ICOM 706"
KB1RNX, 1, "Yeseau 450 into a linear"
 N3FTL, 1, "FT-101-D"
 W2KIX, 1, "FT1000"
 K9PNP, 1, "Viking II"
 KA1BW, 1, "SB101"
KC2CKO, 1, "Apache"
WB3AGB, 1, "TR7"
  K1ZS, 1, "ICOM 706"
 K6XYZ, 1, "B & W 5100"
 K4DSA, 1, "1st on am since the early 60s FT950"
  KM3F, 1, "Kenwood TS480 into a linear"
 K2LYC, 1, "32V3"
  W6FE, 1, "Flex 5000 into a liner"
 K6FMB, 1, "Bauer Broadcast Rig"
 AA4MD, 1, "Hallicrafters HT32-B"
KA4BAO, 1, "FT 450, Fan dipole"
 AC2EV, 1, "FT 450, Vert."
 W3PYF, 1, "Fathers boat ancher, from eastern PA"
KD4JRX, 1, "FT 102, Vert"
KB3RQU, 1, "ft 859 - hl 2200, 40 dipole"
 K2UPI, 1, "tx-1, 75a2, dipole"
KA3BVJ, 1, "ht 40, sx 111, dipole"
  W1ZB, 1, "ht 9, 75 watts out, sx 24, inv v"
 N8YHP, 1, "ts 440, al 811"
 N5ACR, 1, "modfied valient, super scott rx (blind!)"
 N3EVW, 1, "ft 101e, d 104"
WA2VMO, 1, "vik cd, sp 600   "
KA3ICD, 1, "qrp, g5rv"
 K3GBA, 1, "ic 746pro, dipole   (91 yrs old!)"
KB3LDA, 1, "ht 40 -sb 200, hq180"
VE3VDO, 1, "vik 500, hro 5, inv v"
WA3WMI, 1, "145 watts  to g5rv"
 W8PWP, 1, "ft 847, folded dipole..."
 W4KSO, 1, "ic 7000, g5rv"
KJ4RRE, 1, "ts 2000,  dipole  35'"
KA3PTX, 1, "val., sp600"
KA2FWN, 1, "ts 2000, 25 watts"
 W8RPW, 1, "ft 1000 mk5 to amp, vert r390a"
KB3AHE, 1, "hb screen modded 4x1, sx28"
WA2BTW, 1, "flex5000 - sb220, inv v"
KD4DFA, 1, "ft 950 - al811h, dipole"
 K1LDL, 1, "FT990  Collins 75A3"
  NY1M, 1, "FT950"
WA1HFF, 1, "Knight T150"
 K2JRR, 1, "K3 into amplifier "
WA2JID, 1, "DX100"
 W1XZW, 1, "Gonset G76"
  WT2W, 1, "Hallicrafters HT-45"
 N2LJO, 1, "TS940 TL922 Dipole"
  K2TW, 1, "EICO 720 with 730 modulator"
 W2GLN, 1, "
KB3OUA, 1, "TENTEC ARGONOT, DRAKE 2B, L4B, DIPOLE"
VE3VDL, 1, "VIKING 500, HR060, INV V"
KB9SFH, 1, "ft101ee/fl2100b"
KA4BIX, 1, "32v3/51j4/thunderbolt"
 AB9MQ, 1, "flex 5000a/qro 2500"
 N9JBH, 1, "art 13"
KB1MCV, 1, "Viking/sx28"
 W4TAB, 1, "Johnson Challenger, SB200, R390A, Inv V"
WB4BFS, 1, "IC-765"
  NQ0D, 1, "FT-ONE, AL80B, Inverted L"
  N0BF, 1, "
WB0GKW, 1, "viking 2"
 W6QMU, 1, "2e26 rig"
WB0ZNY, 1, "valiant"
  W5CZ, 1, "3ok"
  W0FD, 1, "desk kw hro"
 N0TYL, 1, "vil 2 inverted vee"
KD4GNM, 1, "FT-847, vertical"
 K4JEE, 1, "FT-950, Henry 2K, 350 W, cage antenna"
  KE8Y, 1, "DX-60B, SX-99, dipole"
VE3AWV, 1, "813 rig, TS-570 driver/rcvr, inv vee"
  W8FK, 1, "FT-2000D, 80m dipole"
WA4GZK, 1, "300 w , vertical "
WB8QKE, 1, "Ten Tec Omni 7, 25w."
WB9APZ, 1, "IC-7700, long wire ant"
 N8XPK, 1, "Ranger II, dipole"
 KJ8CQ, 1, "BC-1G, inv vee"
  K8JK, 1, "Flex 5000, amplifier"
 K9KEU, 1, "Gates 250GY, 75A4,dipole @50'"
 N8CSU, 1, "IC-718, pr 3-500Z, 75S1 Rcvr, dipole @ 15ft."
  K8TG, 1, "Kenwood Twins 599T  599R 20 watts, dipole"
  W8KJ, 1, "IC-756proII, dipole"
  W9PT, 1, "FT-847, trap inv vee"
 K8UVC, 1, "32V2, 74A4, dipole"
  W8CO, 1, "K-3, dipole"
KB9WTM, 1, "IC-706. inv vee fed w/ ladderline"
 W4ISH, 1, "K-3, 160m loop"
WA8OMQ, 1, "IC-756pro, Swan ampl, stealth antenna #26 wire"
  N0HN, 1, "FT-1000d, dipole "
 W8RMJ, 1, "FT-950, dipole"
 N9KGR, 1, "Viking II, SX 101, 40 m beam"
 AA9DH, 1, "DX-60, HQ-129X, OCF dipole"
 AA8WL, 1, "Flex 3000"
WA9MIM, 1, "Tempo One, 75 M Loop"
 K9LWI, 1, "Cheyenne, Commanche, 31' vert. ant"
 AF1SH, 1, "DX-100, 75A4, Zepp ant"
  W8VU, 1, "Valiant, ARC-5 R-26, dipole"
  W8PU, 1, "
KB8BKU, 1, "Apache, R4A rcvr"
KC8JOZ, 1, "
WD8QKE, 1, "Omni 7, Centurian ampl,"
  NI9Y, 1, "IC-775DSP, inv vee"
 K8CHA, 1, "813 mod by 811As, R-388 rcvr, dipole"
 K8ATV, 1, "T-368, R-390, dipole"
WB9JIA, 1, "
 W8BUD, 1, "4-811s, IC-738, delta loop ant."
 KD6SW, 1, "Valiant, NC 303"
WB8YQJ, 1, "FT 2000, 2el hex beam"
KJ6KIH, 1, "
 VE6KQ, 1, "DX-60,tribander"
  NY6J, 1, "Drake C line, inv vee"
 N4LZY, 1, "Omni 7, dipole"
KD8KQS, 1, "TS-940S, 160 M Loop"
KC9NEA, 1, "Apache, Mohawk,"
 W8CRK, 1, "Icom IC-756 pro, dipole"
 W2REK, 1, "TS-2000"
  W9SX, 1, "AK-68, ampl"
 W9CRS, 1, "
 W9HAM, 1, "
  K9EA, 1, "TS-940"
WA0LZI, 1, "Viking II, HQ-140X,vertical"
 W8ZLK, 1, "TS-2000, ALS-600, dipole"
KA4ERK, 1, "IC-857, double bazooka"
KA8THW, 1, "TS-570SD, dipole"
 N9HSW, 1, "Harvey Wells, 75A2,dipole"
 W0SAC, 1, "Apache, R-390, 160 M windom"
 K9QET, 1, "32V3, 75A3, Delta Loop"
KA3MHM, 1, "TS-570"
« Reply #3 on: March 01, 2012, 06:11:07 AM »
Once again Steve you have done a magnificent job.  I always cut and paste the results into a flat text file I can do string searches with in the future.  cat <file> | grep <string> or something like that.  Thanks
« Reply #4 on: March 01, 2012, 07:33:50 AM »
Fantastic job compiling all the results thanks to your programming work!
Other conflicts kept me from operating more than a hour or so this year, but hopefully next year I will have more time to dedicate to the event.
It very interesting to look over all the "data" surrounding the event!
Joe, W3GMS
« Reply #5 on: March 01, 2012, 08:29:45 AM »
Nice Job Steve.
I had fun!
W9GT
« Reply #6 on: March 01, 2012, 10:28:12 AM »
Thank you very much Steve for a fun and challenging event!  I don't think that I have ever heard more AM activity on the bands than what we experienced during this rally.   I thought sure that good ole Ralph 'GL would have beat me again this year.  Of course, also Kerri was working lots of stations and I thought she might win, as well.  Thanks to all who participated and if you need a card for W9T, just send me your QSL and an SASE to W9GT (good in QRZ.com).
Thanks and 73,  Jack, W9T / W9GT
73, Jack, W9GT
« Reply #7 on: March 01, 2012, 02:28:43 PM »
I like that we have statistics to be able to say "more than 500 stations" took part in the event. (unique call tally)
That number beats the turnout for other, more publicized events regularly covered in the ham radio magazines.
« Reply #8 on: March 01, 2012, 03:41:07 PM »
Hi Paul,
That's very interesting!  Had no idea, but then again, I don't know much about some of these other events.  We ought to try to get some publicity about out little event - maybe we can get even more participation for next year  Cool  And of course it's great for AM and for the "main stream" to recognize it's a whole lot more popular than they might have imagined.
« Reply #9 on: March 01, 2012, 03:50:09 PM »
Thanks for the data dump Steve. This is very interesting reading. I heard Jack on at least 5 bands so I can see how he made so many contacts. Good job!
I'm gunning for you next year Ralph. If 10 meters wasn't so poor this year I might have passed you.  Wink  Congrats!
Thanks to Steve for heading up the event and to all who participated. Hope I hear all of your before the 2013 AMTR.
Ralph W3GL
« Reply #10 on: March 01, 2012, 03:57:28 PM »
Jack, congrats...
You can be assured, if it hadn't been for my 40 over 9 local noise level without the blanker in line and even with it the signals were at least 50% noise modulated, I could have done much better than 120 Q's...    Noise =  giant headache =  much aspirin...
Hopefully next year the noise will not be present and I'll be around to continue my quest for #1...   Grin Grin Grin
73,  Ralph  W3GL
« Reply #11 on: March 01, 2012, 04:00:54 PM »
I sure appreciate the thanks, but this is an AM community event  Cheesy
One of the cornerstones is AMFONE and the folks who run it - without which, we would not be able to get the word out nearly as well.  And, of course the AM community at large really makes it happen with all of the support and participation which is what makes it real.
By the way, I will still accept logs and update the results as logs are received.  The more information, the better, and it is also likely we can get the call count up even higher.  Hey, how about you folks out on the West coast?  We need more from your part of the world  Wink
N8LGU
« Reply #12 on: March 01, 2012, 06:45:03 PM »
Thanks, Steve. I was approached by local ham who asked me about it knowing I was an AM'er. He was very impressed with the QSO content and also the great audio quality of AM. Guess what? He wants to get on AM! I'm going to loan him an HQ-140x and a Globe Scout 65 until he can get his own gear. He getting his dipole up now. Everyone can give themselves a pat on the back for showing others what AM is like at its best.
"Rock Cave Dave"
« Reply #13 on: March 01, 2012, 08:30:07 PM »
Thanks for all your hard work. The event was a great success for all.
Page created in 0.094 seconds with 18 queries.
