April 26, 2024, 08:30:27 PM *
Author Topic: rockbound test. 7145  (Read 7595 times)
VE3LYX
« on: February 17, 2012, 02:46:15 PM »
Got a Dx60B this week. I think I have everything working now and would like to do an on the air test. I have only one crystal in a reasonable section of 40M  7145. This evening or tomorrow, if possible. I will be checking freq on the hour as long as I am home.
Don Ve3LYX
KX5JT
John-O-Phonic
« Reply #1 on: February 17, 2012, 06:27:11 PM »
Don Ve3LYX
Okay, sounds like a plan... IF THE SSBers will leave you a hole.!! I'll be listening when I think about it on the hour and throwing CQ is clear.
73 John KX5JT
AMI#1684
VE3LYX
« Reply #2 on: February 17, 2012, 09:49:11 PM »
Thanks John. I will give it a shot at next hour , that is 10 PM here.Then off to bed but will try again tomorrrow.
Don VE3LYX
VE3LYX
« Reply #3 on: February 18, 2012, 08:00:37 AM »
Willl be on in 2 minutes and all day testing on the hour.
Don VE3LYx
KX5JT
John-O-Phonic
« Reply #4 on: February 18, 2012, 08:51:36 AM »
Don VE3LYx
The sideband was horrendous around 7.140... I did move to 7.160 when I found it clear and called CQ and made a few AM contacts... 3 of them were on Flex 3000s and when they set their audio level with my help, they sounded excellent.  (I didn't go into equalization and all that just gain level so, one was set way low and two others were set too high).
AMI#1684
VE3LYX
« Reply #5 on: February 18, 2012, 01:29:02 PM »
it is quiet now!
It is the only rock I have for the rig that is on the phone section of the band. I do have a old signal gen down stairs. Later I may put a plug on it and use it as a VFO. If I like it I may build one for it.
Don VE3LYX
VE3LYX
« Reply #6 on: February 19, 2012, 07:49:05 AM »
WIll be giving it a shot (7145) this morning on the hour and half hour from now till 9 am
It is currently 7:47 am here.
Don Ve3LYX
