February 03, 2026, 09:14:49 AM *
Author Topic: 3725  (Read 17658 times)
WB2G
« on: January 30, 2012, 05:18:56 AM »
ND4JS,W4QCU,WI4M,W9AM, 10 over in central New York. Nice signals.
"I am a mortal enemy to arbitrary government and unlimited power."Benjamin Franklin
WB2G
« Reply #1 on: January 30, 2012, 06:21:25 AM »
All done.Nice group,will try again tomorrow at 4:30AM EST.
« Reply #2 on: January 30, 2012, 07:39:08 AM »
Tnx for the heads-up.
Will check it out Tuesday Ayem
Be on the lookout for the EuroAMers around there -- the band has been carrying long you may already know.
« Reply #3 on: January 30, 2012, 12:00:43 PM »
Euros at 4:30 AM EST?  That would be 9:30 AM in UK and 10:30 AM on the continent, too late in the day for transatlantic propagation on 80m.  More likely to be heard around 0430 GMT, which would be 11:30 PM EST. I have worked Jean, F6AQK many times around 0500 GMT.
At 4:30 AM, you would be more likely to work Hawaii, VK/ZL or Japan on 80m.
WB2G
« Reply #4 on: January 30, 2012, 01:16:46 PM »
I will be on at 4:30 am with the Valiant,was  using my Icom 746 Pro today and was still getting good reports.See You Than.Joe.
« Reply #5 on: January 30, 2012, 06:34:22 PM »
That is pretty late for EU but I've worked the UK numerous times just a few minutes before 0900Z, but only in the winter months.
Sunset in HI this time of year is around 0400Z (11 PM ET). JA would be about 0800-0900Z (3-4 AM ET).
WB2G
« Reply #6 on: January 31, 2012, 04:23:13 AM »
I'm on.
pe1mph
pe1mph AM from Holland
« Reply #7 on: January 31, 2012, 08:46:09 AM »
Thats correct!
Just after 05.00 GMT (often) AM between: 3705 - 3710
Mostly between 3707 - 3710 khz.
Becourse the heavy splattering from SSB on 3703...
We qsy-ing mostly a little up!
But are often AM stations from the usa using 3725 (and 3733 khz)?
If yes, I can monitoring those freq. between 5.10 - +/- 5.50 GMT.
Greetings,
Henk, PE1MPH, Dokkum, The Netherlands
