Hello Carl,
And I will post the same solution here too.
An update. I found the problem. Behind the fly wheel there is a nut.
The nut had some red loctite on it so I never gave it a thought.
I checked and it was loose. Tighten it and now no slip. The nut must
pull in the shaft which is what I was doing by pushing in from the front side.
Ken
Posting at different forums increases the probability for a response.
If a solution should be found more people benefit.
Sounds a lot like the NC-300 he asked similar questions about doesnt it?
