May 15, 2024, 01:26:14 AM *
Author Topic: Do resistors actually make noise?  (Read 11840 times)
K6JEK
RF in the shack
« on: January 12, 2012, 12:17:37 PM »
Metal film resistors are advertised as "quiet".  Really?  That you'd notice?
I've been using them because they are cheap, precise and stable but I'm just finishing a 1946 Meissner 9-1065 home recorder -- makes 78's and 33's and the carbon comps sure look right in there.  Incidentally, what a cool little beast that is even if it seems to have been wired by a monkey.
On better electronics like the HRO-60 that I can't wait to get to, carbon comps seem appropriate in that pristine, not wired by monkeys beauty.
« Reply #1 on: January 12, 2012, 12:26:25 PM »
Carbon comps can become noisy but it would have to be extreme to be heard with an antenna connected. Its different in a stand alone audio amp.
Many, many NOS carbons have drifted high but Allen-Bradleys are as new at least in my experience. I dont know how reliable the current imports are.
« Reply #2 on: January 12, 2012, 12:33:41 PM »
I've seen wire-wound power resistors act as pick-up coils as most of them are somewhat inductive.
Makes hum & crap where you would not expect it.
W4AMV
« Reply #3 on: January 12, 2012, 12:35:31 PM »
Yes, resistors can create noise and it is above and beyond the KTBR value we all use and know. The noise, referenced as EXCESS noise can be found I believe if you do a search on that term... EXCESS noise in resistors. Carbon R's vs. metal film and the use of of metal film in low noise audio circuits as Carl referenced is preferred.
73' Alan
W4AMV
« Reply #4 on: January 12, 2012, 12:37:55 PM »
Yep. Look up EXCESS NOISE is your search engine.
« Reply #5 on: January 12, 2012, 01:04:45 PM »
Yes, as do crawfish   Grin
Crawfish’s influence and plant’s influence on the noise generator
Experiments were performed by Y.A. Popov at the Moscow Physical Engineering Institute in 1995.5 Small size heatproof film resistors (graphite on ceramics) were used in the noise generator. The generator was screened from electromagnetic interference. The quality of the screening was very high: a 1 kW, 50 Hz transformer placed close to the experimental setting did not produce any additional signal of the same frequency in the output.
      I. The measurement setup and the organisms (crawfish) were placed in different rooms separated by a massive brick wall at a 3 m distance from each other. The influence of the crawfish on the noise generator at the moment of their death (in boiling water) was studied. Results of the experiments are given in Figure 4.
Fig. 4. The amplitude (A) of the electric signals at the generator output.
T is the time elapsed since the start of the experiment. Below are shown the times when the crawfish was dropped in boiling water.
As can be seen from Fig. 4, pronounced peaks in the amplitude were observed at the generator output 10-15 sec after the crawfish had been put into boiling water.
http://www.whps.com/misaha/ArticleEngl-4.htm
Additional Info:
http://en.wikipedia.org/wiki/Johnson%E2%80%93Nyquist_noise
http://prola.aps.org/abstract/PR/v32/i1/p97_1
See section 10 of -  http://www.ti.com/lit/an/slod006b/slod006b.pdf
http://www.rle.mit.edu/avbs/publications/journal_papers/journal_16.pdf
Noise Calculator - http://www.sengpielaudio.com/calculator-noise.htm
http://en.wikipedia.org/wiki/Noise_(physics)
« Reply #6 on: January 12, 2012, 01:05:25 PM »
Yes, as do crawfish do   Grin
N4LTA
« Reply #7 on: January 12, 2012, 04:20:31 PM »
A very good description of resistor noise and the various types of resistors can be found here
http://www.eetimes.com/design/automotive-design/4009614/Strategies-for-minimizing-resistor-generated-noise
Pat
W4AMV
« Reply #8 on: January 12, 2012, 04:38:22 PM »
Thanks Pat. Good read.
K6JEK
RF in the shack
« Reply #9 on: January 12, 2012, 05:26:12 PM »
Pat
Thanks, guys. Metal film for audio stages seem like a prudent choice.
KA0HCP
« Reply #10 on: January 12, 2012, 10:50:20 PM »
Resistors being resistors chant very quietly: "hell no we won't glow".
« Reply #11 on: January 13, 2012, 12:28:13 PM »
That Vishay article is excellent back slapping; so what are the competitors up to?
I doubt if our low level modulator stages can benefit from such extremes but Im tempted to open up one of the Vikings and do a before/after test.
KA0HCP
« Reply #12 on: January 13, 2012, 06:50:41 PM »
Note he didn't give any noise figure for the Vishay miracle resistor.  Wink
N4LTA
« Reply #13 on: January 13, 2012, 08:01:44 PM »
Maybe in a low level mic preamp. Most of the data that I have read indicated that the current has to be very low for even the Johnson noise or shot noise to be a significant factor in a conductor. That is not the case in a semiconductor.
« Reply #14 on: January 13, 2012, 08:10:43 PM »
Granted the thermal noise inherent to certain types of resistors may be higher than that of others, but doesn't the internal noise of the active devices in the circuit, whether tubes or transistors, swamp out any noise generated by passive elements such as resistors, assuming no arcs or other catastrophic break-down faults in the resistors?
« Reply #15 on: January 14, 2012, 10:38:12 AM »
and its gregorian
http://homepage.oninet.pt/862mch/rsetg.htm#prog
« Reply #16 on: January 14, 2012, 10:45:46 AM »
It all adds up.
« Reply #17 on: January 14, 2012, 01:33:09 PM »
It all adds up.
Which seems to be what many folks miss - the cumulative effect of multiple degraded or otherwise-faulty components/stages, if only from aging. Not always noticeable until after the refit is done.
Fortunately, most AM signals don't require the skills of working moonbounce to hear. It's pulling in the weak stations from across the pond etc where it can truly help out.
Still, it's all for naught if you don't employ an oxygen-free power cord and custom, wooden knobs.
N6YW
« Reply #18 on: January 14, 2012, 01:33:43 PM »
MTC...
Shot noise is inherent to Carbon Comp resistors. My understanding is the micro 'explosions" of oxygen under load. I had read somewhere that the British had come up with the idea of "Cracked Carbon" resistors to minimize this potential. In the (guitar) amplifiers I build, I use a simple rule of thumb. Metal film non-inductive resistors in the power supply & screens, and 1 watt carbon composition types everywhere else. I personally cannot tell the audible difference between the two as to sound coloration. I will leave that to the cork sniffer's. The many audio forum threads are rife with much hyperbole on this subject. I also tend to go with the rule that if a circuit calls for a 1/2 watt resistor, I go with a 1 watt where applicable except for screen resistors. Because they act as a fuse, best to keep them in the ballpark so to speak. Just sayin.
 Anytime a screen resistor installed is a carbon type, I promptly replace it with a metal film type. If and when the tube goes nuke, the metal film type will emit a soft white smoke as opposed to a cloud of black carbon that deposits all over the damn place, leaving behind lot's of little mini resistors in places where you can't see. Believe it. Been there done that.
Also, the use of Vishay resistors is a good one as I have had 100% success using their grade of components, never had a problem. The cheap garbage being pawned off onto the world by China is to be avoided, and there is a big presence of "Fake" Allen Bradley carbon resistors flooding the market. Buyer beware. Buy only known stocks of quality components, otherwise this rule ALWAYS applies: Garbage in, Garbage out.
Enough said.
"Life is too short for QRP"
N4LTA
« Reply #19 on: January 14, 2012, 02:11:39 PM »
Your buying into the Kool aid more than me.
I have sold over 500 Guitar amp kits in that past 20 years and I use those "garbage" Xicon 1/2 watt resistors - and as far as I can remember I have never had a "bad" one - I use them because C Composition resistors are demanded by the buyers. I don't think there is any difference in those and a Metal film 1% - not in simple tube circuits.
If they work why in the hell would you spend $1.50 for an Allen Bradley resistor?
Chinese Garbage is very relative - Lots of good quality parts come from China - It depends on the specs that they are manufactured to.
For personal stuff I use metal film or metal composition resistor or Metal Oxide  in the larger sizes.
N6YW
« Reply #20 on: January 14, 2012, 02:24:54 PM »
Like I said, MTC.
I don't buy Koolaid. I have had numerous problems with cheap components of no specific brand and to be on point with your post. Xicon isn't one of them. I also do not spend a 1.50 on an AB resistor because I already own 1000's of them, but then again it's always a matter of choice isn't it? As a cautionary measure, I choose not to use a certain off brand component to minimize potential failure. Guess what? Not a single failure in the amps that I have built for my clients. Also to your point, providing an economic and workable product for your clients is a good thing. Many a happy kit builder I'm sure. The point I was making is about carbon composition resistors making noise and my experience with what I have already stated.
Your assumption about me is without merit and beyond the scope of this thread.
N4LTA
« Reply #21 on: January 14, 2012, 03:03:19 PM »
Sorry if I may have offended you  - I didn't mean it that way - but I just don't buy in to the NOS resistor NOS capacitor (used Black Beauties) stuff that the many guitar amp guru's sell. I have never heard a resistor have any sound coloration.
I have heard too much BS from the Gurus and the so called experts. I am one of Gerald Weber's hated "engineers' that just don't understand  how old stuff works - as if the laws of physic have changed since 1950. According to Guru Gerald - We just don't understand the physics of tube electronics - this from a guy who suggested that a good speaker simulator was the old voice coil removed from a speaker - Because it was actually from a speaker???
When I build custom amps - and I have built some - I don't use the Xicon CC - I do use new  IRC  C Comps in the signal path and  USA Name brand metal oxides and metal films. When I build them for my son - I use metal film throughout. I doubt that the meatl films have any effect on noise - but I still use them.
Pat
KC2TAU
« Reply #22 on: January 14, 2012, 07:32:46 PM »
http://www.geofex.com/article_folders/carbon_comp/carboncomp.htm
If you have both why not have a little fun and try them both and see what you hear?
« Reply #23 on: January 14, 2012, 07:50:04 PM »
Shot noise is inherent to Carbon Comp resistors. My understanding is the micro 'explosions" of oxygen under load... Metal film non-inductive resistors in the power supply & screens, and 1 watt carbon composition types everywhere else. I personally cannot tell the audible difference between the two as to sound coloration. I will leave that to the cork sniffer's. The many audio forum threads are rife with much hyperbole on this subject.
Looks like a call for "oxygen-free" carbon resistors.  Grin Grin
I understand some metallic film resistors are packaged to look just like carbon composition ones.  About the only way to tell the difference is to grind through the body of a sample to see what's inside.  I hadn't heard of counterfeit resistors; I reckon the Chinese have branched out from Rolex Watches. Most of mine are pull-outs from salvaged equipment or n.o.s., so I'm probably OK.  But I always check the resistance; many of them have drifted in value over the years.
Sometimes if I can't find a specific value of resistor, but run across a drifted-value one that reads the sought-after resistance on the ohmmeter, I'll use it on the theory that over time as the resistance has re-adjusted itself, it has actually become more stable and will hold to its shifted value. I wonder if anyone has actually ever checked that out?
N0BST
« Reply #24 on: January 14, 2012, 09:04:12 PM »
Don't know how it affects radios, but I was rebuilding an old RCA BC-3 audio console, and by swapping out the carbon comps for metal film I was able to reduce the noise some 6db.
Scott Todd
Page created in 0.087 seconds with 20 queries.
