November 05, 2025, 04:41:51 AM *
Author Topic: Rca Transmitting tube manual TT5: page 299 unusual circuit  (Read 20399 times)
« on: January 03, 2012, 01:02:47 PM »
I wish I had time to draw this out in a usable form for the forum ... look at this one closely ... it is a push pull plate modulated stage using 813 tubes .... all seems to be orthodox until you look at the plate lead rf bypass cap (usually one lead to plate choke rf cold end, one lead to ground) .... it seems that the bypass cap is going to the screen connection and then to ground for rf but is a coupling cap for audio with low freq break point at 125 Hz
Also note that this 800 watt dc in stage is spec'd to be modulated with 150 w of audio
Whatduya think?
KC2ZFA
« Reply #1 on: January 03, 2012, 01:39:46 PM »
here it is:
« Reply #2 on: January 03, 2012, 02:01:52 PM »
C8 should go to ground and the B+ lead to C7 is also wrong. The rotor of C7 should be grounded in this shunt fed circuit.
L3 is there so the screen can self modulate to some degree which is better IMO than a big resistor off the B+.
T2 may be a typo and 450W was meant.
There should also be a RFC or 2-3K carbon resistor right at the input coil CT and bypassed at the cold end.
M1 is reading cathode current so grid and screen currents have to be subtracted to give plate current.
All in all its a pretty half assed circuit as published.
« Reply #3 on: January 03, 2012, 02:08:51 PM »
" T2 may be a typo and 450W was meant. "
Its the same value , 150 Watts, in the TT-4 Manual I've got.
N6YW
« Reply #4 on: January 03, 2012, 02:11:50 PM »
Point us to a full assed circuit please!  Grin
"Life is too short for QRP"
« Reply #5 on: January 03, 2012, 02:16:22 PM »
" Point us to a full assed circuit please!  Grin "
Here it is
http://www.amwindow.org/tech/htm/813/813.htm
N6YW
« Reply #6 on: January 03, 2012, 02:23:10 PM »
Here it is
Yup, that's pretty full assed alright. Thank you very much!
N6YW
« Reply #7 on: January 03, 2012, 02:26:50 PM »
On the 813 modulators, where does the bias come from? I see a -75v supply but the input modulation transformer centertap is grounded. What gives Jeeves?
« Reply #8 on: January 03, 2012, 02:35:13 PM »
At first glance it looks like the screen would be grossly overmodulated.  But looking at the values of coupling and by-pass capacitors, the grid is apparently self-modulated by L3, but with additional audio from the plate modulator coupled to the grid through C8, and forming a capacitive voltage divider with C5 and C6. The circuit looks like it would be ineffective at lower audio frequencies, given the low value of C8, so maybe this is to compensate for the high frequency roll-off of screen modulation that would result from the screen by-pass capacitors.
As for the audio power, they are probably talking about average audio power for voice modulation.  It would take a little more than 400 watts of audio to modulate it with a sine wave.  That was an old trick,  recommended by RCA right after WW2, to "voice modulate" a transmitter with smaller, cheaper modulator tubes running over-voltage on the plates.  I recall an ad, claiming a pair of 203-A's could be made to "voice modulate" a full KW DC input.
Kind of like what the leen-yar manufacturers used to do back in the early 60s when slopbucket was just first catching on in a big way, claiming their 2 or 3 sweep tube p.o.s. would run a "FULL KW INPUT (p.e.p.)".
With normal voice modulation, the thing would hit maybe 150 watts input on the plate meter at voice peaks, but if you whistled in the mike, the tubes would go into Chernobyl mode.
...the B+ lead to C7 is also wrong. The rotor of C7 should be grounded in this shunt fed circuit.
C7 and L4 are wired correctly. The full modulated +HV DC is series-fed to the final plates through the tank coil. This allows rf choke L4 to handle very little rf voltage and have negligible effect on the tank circuit tuning, since it is tapped onto the coil at a voltage node. With shunt-feed and rf blocking capacitor, the rf plate choke is always a problem with a multi-band amplifier, since the plate choke almost inevitably has a resonant point somewhere within the frequency range of the transmitter. With series feed, the rotor plates of the variable capacitor are raised to the same +HV potential as the stator, so that no modulated DC appears across the capacitor; the capacitor only has to handle the modulated RF, and much closer spacing can be used than if the rotor and frame of the capacitor were grounded. In the later case, the stator plates carry full +HV potential PLUS full rf voltage, effectively doubling the total peak voltage that appears between the plates of the capacitor.
« Reply #9 on: January 03, 2012, 02:57:32 PM »
The 813s in triode connection at 2KV plate voltage become zero bias triodes. No bias supply is needed.
N6YW
« Reply #10 on: January 03, 2012, 02:58:28 PM »
Interesting, thank you.
« Reply #11 on: January 03, 2012, 03:05:31 PM »
You're welcome. That's the beauty of this modulator. Simple, easy yet effective and it has plenty of reserve power (headroom). It can be built on a seperate chassis and used to mod a number of different finals.
N6YW
« Reply #12 on: January 03, 2012, 03:47:11 PM »
I have a ton of parts, just not the big modulation transformer. Where does one source this kind of iron?
Also, what rating should be considered when choosing iron? The power supply should be rated for 100% duty cycle or higher?
« Reply #13 on: January 03, 2012, 05:25:09 PM »
And the RCA note has another error:
L4 is a three turn link that should be in the center of th L5, not L4.
Phil
« Reply #14 on: January 03, 2012, 09:12:55 PM »
Considering an application engineer must have drawn it, knowing the standards I am held to as one, and the standards the RCA engineers would have been held to, it's hard to accept that there's an error in that volume. No one's perfect I guess, not even the old masters! But I do not have an issue with C8. I had something else in mind for that kind of coupling scheme involving not only a capacitor but a resistor and a transformer, but have not tried it.
« Reply #15 on: January 04, 2012, 10:47:32 AM »
Nope, C7 rotor should be going to a good RF ground. As shown connected to the B+ it is not going to work since its floating for RF.
If you want to eliminate the RFC then ground C7 rotor thru a cap and use narrower plate spacing.
RCA TX and RX tube manuals have many incorrect circuits.
« Reply #16 on: January 04, 2012, 12:57:04 PM »
I don't see how it's floating, Carl.
C7 is basically 2 caps in series in parallel with L5.
A simple parallel resonant circuit. L4 isolates the junction of C7a and C7b from L5 but allows the DC potential to be as Don described.
« Reply #17 on: January 04, 2012, 01:02:02 PM »
thanks to all who responded (so far )  .... there may still be more to this circuit than first meets the eye ....
Patrick : ... please check both transformer phasing marks, not in phase as drawn ... circuit is interesting
Don: ... a nice analysis ... if C5,6,8 act as a voltage divider (4:1) then with 2000 V swing out of secondary of mod xfmr would yield a 500 V swing to screen which would have cut off the 813's by a 100 V or so on neg swing ....splatter city .... it is possible that this circuit operates on a lesser secondary swing of say 1500 V which would require a different analysis as to functionality
KC2ZFA : ...sorry don't know your name .... thanks for posting the schematic from the manual
I promise that this was not a rhetorical question about how this works unless Carl is right and it is just imagnary ....73
« Reply #18 on: January 04, 2012, 01:20:50 PM »
Looks like they are counting on C8, C5 and C6 to provide the rf ground to the rotor of C7. Probably not absolutely the best possible rf ground for the capacitor, but you also want to avoid, if at all possible, an additional capacitor from the rotor to ground in order not to have too much capacitance across the modulation transformer. I believe that has been an issue with high frequency audio response in the T-368, which uses series HV feed through the tank coil. Note that all 3 of those caps in the 813 final are 5 and 6 kv micas.  If they are good quality low rf impedance transmitting caps and the wiring is physically laid out properly, using 1/2" or wider copper strap instead of plain wire for all the interconnections between ground, the three caps and the rotor of C7, it should be OK if the leads can be kept reasonably short. Also, EVERY ground connection associated with that stage should be grounded to one and only one common point on the chassis, even if a shorter lead could have been used directly to chassis right where the component is mounted. Grounding C2, for example, to one point on the chassis and C4, C5 and C6 to a different point (or worse still, a multitude of different points) on the chassis is just asking for parasitics, instability and squirreliness in the final stage, since there are inevitably rf impedances and thus small differences in rf potential, at different points along the chassis, and a common rf impedance between plate and grid to ground may exist.  This can result in undesirable rf coupling and therefore feedback between the grid and plate circuits. And every grounding point in the stage should use its own separate lead to that chassis ground; it is important to avoid daisy-chained RF grounds.
Everything should initially be laid out as symmetrically as possible, but sometimes in a push-pull final, perfect symmetry can actually result in parasitics, so that the leads to one tube may have to be slightly lengthened relative to the other to get the final to settle down.  Another precaution is to make the plate OR grid leads as short as possible, but not both. You should intentionally leave one or the other somewhat longer, to avoid inadvertently turning the final into a VHF TGTP oscillator.
One thing they did do correctly, avoiding a common mistake in homebrew (and some commercial) amplifiers, was to ground the rotor of grid capacitor C2 DIRECTLY to the common chassis grounding point. A by-pass capacitor/ rf choke combination in the grid circuit AND one in the plate circuit is a TGTP oscillator waiting to happen. This does put more voltage across the plates of the grid capacitor, but here you are dealing with the rf grid voltage + grid bias, so capacitor voltage rating is not so much a problem as it is in the plate tank circuit. Also, they are correct in using wirewound resistor R without an RF choke, for the reason just mentioned above. The WW resistor inherently has some rf choking action, and its internal resistance tends to quench any tendency to cause oscillation.
BTW, I have seen push-pull final circuits in which both the tank coil and capacitor were left floating, but that always concerned me that it would be a problem if everything, including the load, were not perfectly balanced.  You can leave the cap rotor floating and ground the midtap of the coil, but I seem to recall reports of instability with that configuration, and the exact midtap point would likely have to be experimentally determined to get perfect balance with the push-pull tubes.
And equally importantly, you NEVER want to make a direct (or even a poor) rf connection between capacitor rotor and mid tap of the coil.
N6YW
« Reply #19 on: January 04, 2012, 03:30:54 PM »
Sort of on topic...
My interest has been whetted by the inclusion of the 813 schematic by KB2WIG.
I indicated earlier about having a lot of parts. Where can I find the Iron and choke(s)
necessary to make that circuit a reality? That modulation transformer must be hard to find.
Point me in the right direction and I'll start digging.
KC2ZFA
« Reply #20 on: January 04, 2012, 05:24:34 PM »
shouldn't that be for the under-chassis grounds only ?
Say C8 is grounded instead (so that the rotor of C7 is grounded through it as in the standard P-P)...are you saying that the ground end of C8 should pass through the chassis and get connected to the common ground point of C2, C5, and C6 underneath ? I thought that the under-chassis stuff had to be RF tight from the over-chassis stuff. Can you straighten me out Don ?
Thanks for all the info above !
Peter
« Reply #21 on: January 05, 2012, 12:31:16 AM »
A good question. I suppose if the chassis base is used as an rf-tight shield, for example with all the grid circuitry underneath and thoroughly isolated from all the plate stuff mounted on top, one could use one under-chassis common point for the grid circuit components and one above-chassis point for all  the plate stuff. I never built a transmitter that way, so it's something I never really thought about. If I did use separate above-chassis and below-chassis common points, I would locate them on opposite sides of the sheet metal at the same spot using the same mounting screw, and run a lead through a near-by adjacent hole from one to the other.
Everything needs to be at the same rf ground potential, and due to the skin effect, the top of the chassis is effectively isolated from the underneath side, rf-wise. A similar example of this is coax cable.  Coax can be thought of as having three-conductors: the inner wire, the interior side of the braided shield, and the exterior side of the braided shield. That's why a W2DU type balun works. The hollow ferrite cores break up the exterior braid into isolated sections at radio frequencies, while the inner conductor and inner side of the braid are unaffected.
In both my homebrew transmitters only one common point per stage is used, and for the one or two grounded components mounted on the opposite side of the metal shelf, the ground lead goes through a hole in the sheet metal to the common point on the other side.
I would pass the ground end of C8 through the chassis and connect it to the common ground point of C2, C5, and C6 underneath, and do the same for the rotor/frame of C2 if the grid tuning capacitor were also mounted on top of the chassis (but for a power-sensitive tube like the 813 I think the grid capacitor should be mounted on the underneath side). Or else mount C8 underneath the chassis and run the ungrounded lead through the chassis to the frame of C7.  The only "RF-hot" components on the top side of the chassis would be the plate leads from the 813s, the stator plates in the tuning capacitor(s), and the ends of the plate tank coil, assuming of course that the plate tank components are mounted on the top side of the chassis.
« Reply #22 on: January 05, 2012, 10:50:37 AM »
Hamfests are one place to look. Another would be to place a want ad here and other buy/sell venues. You'll want to get a 250 watt or larger transformer. You can get some model/part numbers at the link below.
http://www.amwindow.org/tech/htm/modtran/modtran.htm
Sort of on topic...
KC2ZFA
« Reply #23 on: January 05, 2012, 01:56:19 PM »
doh! thanks for this reminder  Embarrassed
Peter
« Reply #24 on: January 05, 2012, 02:32:28 PM »
Look again carefully and redraw if necessary.
Then tell me what is at the junction of C7, C8 and T2.
While Dons last explanation winds a RF ground path thru C5,6, and 8,  'splain to me how that even comes close to good engineering by placing some level of the plate RF on the screen pins?Huh I also dont buy into the wandering explanation about grounding and an absolute need for a common point ground at low ham frequencies. Heck, that circuit doesnt even have any parasitic suppressors which limits its frequency anyway to low bands where the 813 parasitic paths are effectively swamped.
The only thing really needed for stable construction/performance is very low inductance grounds as well as RF connections. Any amp is going to have multiple hardware connecting to the chassis top AND bottom assuming the external tooth washers get a good grip; the more the merrier and it will make the complete surface a single RF ground. Ive followed that procedure with a single or a pair of grid driven 4X1's many times for 160-10M and nary a trace of instability.
I also detest an unswamped by a carbon resistor RFC in the grid circuit and always do that when substantial grid current is involved and a 2-3K carbon resistor alone is impractical. With a RFC and a HF effective value bypass the TGTP possibility is slim to none but it still opens the possibility of a LF oscillation which can often go undetected without an SA scan.
And why in hell would anyone use an RFC to the  L5 CT and then feed RF in to the bottom end that has to wander around before finding some sort of compromise ground?
Then please show me any published circuit that does that...on ham bands?? Maybe there are a few but even earlier RCA manuals didnt do it that way.
It looks more like something developed after a bad time at the bar the previous night. Roll Eyes
Page created in 0.064 seconds with 17 queries.
