May 04, 2024, 11:06:14 AM *
Pages: 1 2 [3]   Go Down
Author Topic: Can someone recomend a good BC band filter?  (Read 25122 times)
W2NBC
« Reply #50 on: December 28, 2011, 06:33:26 PM »
Excellent info on various BC traps, high pass, and notch filtering
http://www.dxing.com/tnotes/tnote06.pdf
« Reply #51 on: December 28, 2011, 06:41:18 PM »
Thanks fred.  I am going to just go to the doctor/clinic tomorrow.  Someone mentioned something called a Z pack that the doctor gave them and in days they where normal.
Jim WB5WPA
« Reply #52 on: December 29, 2011, 01:28:03 PM »
Carr's "Figure 3" (pg 6) High-Pass filter looks pretty good.
He says it has a cut-off frequency between 1700 and 3000 KHz and blocks some some AM BCB signals while passing all the shortwave frequencies.
" Figure 3 shows a design used for many decades. It is easily built because the capacitor values are 0.001 μF and 0.002 μF (which some people make byparallelling two 0.001 μF capacitors). "
Figure 3 below:
http://i39.tinypic.com/fxb9s1.png
« Reply #53 on: January 05, 2012, 05:45:12 PM »
W7TFO knocked on the Door today and handed me a JW miller 812-bc1 wave trap.  This looks like an IF can.  It has an adjustment to fine tune the trap.  I clip leaded the filter inline to the antenna ahead of the SDR and BINGO!  Problem solved. I can no longer here the Disney station anywhere on on the spectrum. I have attached Screen shots of the Primary signal with and without the Wave trap installed inline and of 75 meters with and without the filter.  As you can see 75 meters was not usable without the wave trap.
BIG thanks to Dennis for this little Gem.  I need to mount it to a box with connectors now!
« Reply #54 on: January 05, 2012, 05:46:04 PM »
These shots show 75 meters with and without the wave trap.
« Reply #55 on: January 05, 2012, 08:40:12 PM »
W7TFO wins the "Victory Over Disney Award"
Clark, Now the fun begins.
I bet you're close to heaven now.
« Reply #56 on: January 05, 2012, 08:55:51 PM »
I sure am. The SDR works great now Fred.  The ECSS, is really cool.  I can use the AM mode, Choose the Sideband I want and the software tracks the carrier back and forth auto!
« Reply #57 on: January 05, 2012, 11:40:31 PM »
I put a Galvanic isolator on the sound card input.  This is a simple 1 to 1 600 ohm stereo transformer.  This took the peak out seen in the plots.  The LO of the SDR shows up there without the isolator.  This Dropped the noise level of the radio down 2 full SU.  Its now very nice to use on SSB and AM.  Not bad for a $100 radio.
« Reply #58 on: January 06, 2012, 02:47:27 AM »
Friggin' old tech, saves bacon every day! Cheesy
« Reply #59 on: January 06, 2012, 01:12:10 PM »
Sure does.  It really worked perfectly Dennis.
The SDR is alot of fun now with out that LO signal in your way and with the BC station out of its ears.  One I learned how to adjust the AGC threashold, The noise disapeared and the stations came up.
Now I need a TR switch with 100DB pad so i can have this thing inline all the time.
Pages: 1 2 [3]   Go Up
Page created in 0.093 seconds with 20 queries.
