April 26, 2024, 01:26:36 AM *
Author Topic: Vintage WECo project boxes for sale  (Read 2462 times)
« on: November 09, 2011, 12:17:49 AM »
These were originally a WECo test set.  I remanufacture the two panels, so these are ready to go.
Excellent for a retro regen receiver, a portable qrp transmitter, bench supply, eTc.
They are approx !0" wide, 8" high, and 5" deep.  The case proper is made of aluminum, and the 1/2" thick panels are of marine-grade plywood with black formica on the outer surfaces.  These are easily engraved with your nomenclature, and filled with white paint for a really good looking project.
The top has four captive screws used to open it up, and there is a side (or bottom, depending on how you use it) panel about 5" X 3" for connectors and such.
Internally, there is a steel framework bracket that has bosses for an internal panel if wanted.  The panels and bracket are designed to come out of the case as a unit.
Good original grey wrinkle paint, leather handle. Comes with a 2" deep matching detachable lid.
These are very high quality, not some cheap mini-box.  Weighty.
You will need the skills and tools suitable to work the panels, such as holesaws and Forstner bits.
Please contact me for more info if interested.  I am ramping up to produce quite a few of these.
$50 per +shipping.
