April 06, 2026, 04:41:48 AM *
Author Topic: Bird slugs for 10M  (Read 3235 times)
K6JEK
RF in the shack
« on: November 05, 2011, 03:10:28 PM »
Should I be using the 25 - 60 MHz Bird slugs for testing on 10 meters instead of the 2 - 30 MHz versions which I actually have?  I'm measuring right around 29 MHz.
I'm trying to figure out where the power is going and am beginning to wonder if I should spring for some new slugs.
Am I really losing 13% of my power in the Ten-Tec 238 antenna tuner when it's in bypass? Questions like that.
« Reply #1 on: November 05, 2011, 04:03:41 PM »
2-30megs should work, otherwise Bird wouldn't label it 2-30megs.
« Reply #2 on: November 05, 2011, 04:46:20 PM »
Bird spec for 'ordinary' wattmeters is 3% across the passband.
Your slug ought to do just fine within that accuracy @ 10m, what Fred said.
Take readings incident and reflected, do the math, get your SWR.
Lost power goes the weirdest places you'd never expect.... Tongue
K6JEK
RF in the shack
« Reply #3 on: November 06, 2011, 11:20:53 AM »
Thanks.  I'll save the money for the slug and spend it instead on a really big microphone.
« Reply #4 on: November 06, 2011, 12:55:32 PM »
If you get too big of a microphone, you then may need a different slug.
Just thought I would give you a heads-up on that.
« Reply #5 on: November 06, 2011, 01:50:30 PM »
You're probably better off blowing mic money on RF stuff like feedline, antenna, rx preamp...Paul just mentioned in another audio thread that Best Buy has shure SM58s new on sale for $75.  That's all you need.
« Reply #6 on: November 06, 2011, 06:14:52 PM »
$75 Huh?for an SM58??
That's pretty decent mic......
Fred............and believe the losses through the tuner on 10M.
« Reply #7 on: November 07, 2011, 03:43:03 PM »
See if the switch is heating up.
