i appreciate the jokes and the name acronyms.
KS2AM, the ham swap meet is at the end of the month and the next VE exam i plan to go to is the weekend after that. maybe i can find some nice boat anchor material at the swap meet and just skip the ssb stuff all together (assuming i can past the general a month from now).
do any of you have a list of boat anchor brands and models that i should be on the lookout for? i cant spend more than about $100-150.
Hi Solomon,
If you are looking at boatanchor gear you are looking at a separate transmitter and receiver. $100-$150 is wishful thinking for a working combination unless someone is willing to help you out. You may be able to find an older working transceiver like a Yaesu FT-101 in the $200 range but YMMV. Anyone else on amfone have any ideas ?
Regardless of what HF gear you end up with, a good antenna is an important part of the equation if you want to be heard. Have you given any thought to what sort of antenna you want to put up ? How much room do you have ?
Sam
