May 10, 2024, 11:28:04 AM *
Author Topic: SP 600 - 600 ohm audio output  (Read 6655 times)
W8ACR
254W
« on: September 20, 2011, 12:17:15 PM »
I recently picked up a Hammarlund SP600. The audio output jack on the rear panel is for 600 ohms impedance. I am trying to figger out the best way to hook up an 8 ohm speaker. I came up with five ideas and I'd like to hear what you all think is the best way to do this. The SP600 has a single ended 6V6 audio output tube. I think it has about 3 watt audio power.
1. hook up the 8 ohm speaker to the 600 ohm jack and put up with crappy audio.
2. Replace the audio output transformer with a new one - 5000 ohm primary:8ohm secondary
3. Attach a 600ohm:8ohm transformer to the output jack
4. Find a 600 ohm speaker
5. Take the audio off the IF - This one sounds good to me but I forget how to do it.  Undecided
Thanks,
Ron W8ACR
Ralph W3GL
« Reply #1 on: September 20, 2011, 12:37:54 PM »
Ron,
Its been many years since I even looked at an SP600 but way back
in the memory I seem to recall that 600 ohm output was made for
feeding the AF to a 0dbm line.
However, if it is the only load on the output of the 6V6, acquire a standard
500 ohm to voice coil transformer (radio shack used to carry them) or
if you have a small 115 volt to 6 volt (1 amp or so, not critical) filament
transformer handy, it's a great substitute...
73,  Ralph  W3GL
KE6DF
« Reply #2 on: September 20, 2011, 12:43:08 PM »
A 70.7v line to voice coil transformer would be a close enough match for the 600 ohm output, I believe.
KE5YTV
« Reply #3 on: September 20, 2011, 12:45:51 PM »
I use method #3. It works FB.  Grin Grin
Mike
KE5YTV  Dallas, TX
« Reply #4 on: September 20, 2011, 01:12:39 PM »
It really isn't a big deal, at least to me.  Hammond makes a high quality 600 ohm to voice coil transformer model P-T119DA.  It's a quality transformer - you only need to buy it once.  I can't count the times I've heard work-around solutions to this question.  Be nice to your great receiver (I have one of those too)  Get the transformer -- it will outlive you
73 es GL
Al
« Reply #5 on: September 20, 2011, 07:56:56 PM »
Correct, you need one that has a 10watt tap.  When you connect to the 10watt tap that is about 500ohms off a 70.7 constant voltage speaker system.  Some xfmrs only have up to 5 watt taps.  If you connect a 4 ohm speaker to the 8 ohm tap and then use the 5 watt tap you will be at the same 500 ohm load on the 70.7 volt line.
W8ACR
254W
« Reply #6 on: September 20, 2011, 08:55:55 PM »
I did a search on this website and found the thread started by KE7TRP regarding HI FI audio from an SP-600 by taking the audio off the diode load circuit point using a 470K resistor and a 10uf nonpolarized cap. Can someone draw for me a simple schematic of this circuit?
Thanks, Ron
SM6OID
« Reply #7 on: September 21, 2011, 06:07:40 AM »
Hi!
I only have one 600 Ohms speaker, so I had to find a way of matching the SP-600 (and oter BA's) to a speaker of 4-8 ohms. In the junkbox I found a small (20 VA) transformer, 230 V primary and 24 V secondary.
The BA to the primary side and the speaker to the secondary, and as far as I'm concerned, the problem was solved...
« Reply #8 on: September 21, 2011, 03:28:14 PM »
I now use the 600 ohm to 8 ohm transformers sold on Ebay. They are alot cheaper then the hammond and seem to work ok. I have no complaints about the hammond other then the price.
The audio amp hookup is best.  Just use a 22UF cap from the diode load and then to an RCA cable center.  The SHield of the RCA goes to nearby ground screw.  I used the resistor as the level was a bit high.   I got this from R390a.com but its dead. It works perfectly.
W8ACR
254W
« Reply #9 on: September 21, 2011, 04:19:02 PM »
Hi Clark,
Thanks for the post. Is there a paricular reason you stopped using the diode load output method? In your previous thread you seemed so amazed by the quality of the audio using that method.
73, Ron
« Reply #10 on: September 21, 2011, 05:12:29 PM »
I use the diode load on my SP600 with a small vac tube amp to an R46 hallicrafters speaker. Its Hi FI audio all the way.
On my other rigs, I use the 600 ohm to 4 ohm transformers.  I see no drawback using the Diode load.
