May 07, 2024, 05:18:44 AM *
Author Topic: Plate to line transformers backwards  (Read 4617 times)
KE6DF
« on: September 12, 2011, 07:23:11 PM »
I have a couple Stancor WF-36 low level p-p plates to line transformers.
These are broadcast quality audio transformers and are knockoffs of the UTC A-26 units.
My question:
Would these transformers work as low level line to grid transformers if connected backwards?
Would they likely give as good audio response as a UTC A-12 or a LS-12 input transformer?
Obviously, the step up ratio would be less, but other than that....
« Reply #1 on: September 12, 2011, 07:56:19 PM »
Should work, except for the step-up ratio would be less.   Probably not as class B drivers, but low level audio they should work.  They would work as class AB1 drivers.
« Reply #2 on: September 12, 2011, 08:53:38 PM »
What is the plate impedance of the primary?  I assume the secondary is 500/600 ohms line output.
I probably have a real UTC A-series line to p-p grids transformer, and I know I have a LS-12 or 12X.  If the primary impedance of the Stancor is something I could use, wanna swap?
KE6DF
« Reply #3 on: September 12, 2011, 11:09:02 PM »
P-P primary impedance is 30K
Attached is a page from the Stancor catalog.
Yes, I'd be happy to swap.
Dave
* stancor_1952.pdf (2510.99 KB - downloaded 383 times.)
« Reply #4 on: September 13, 2011, 11:48:30 PM »
Dave,
Check your PM box, regarding what I found in my transformer stash.
KE6DF
« Reply #5 on: September 14, 2011, 01:41:39 AM »
Thanks Don,
The swap will let me compare the A-11 to the WF-36 since I have two of the WF-36s.
Dave
