April 12, 2026, 02:42:13 AM *
Author Topic: Mounting distance between plate and mod transformers?  (Read 10858 times)
KC9LKE
« on: August 04, 2011, 03:47:49 PM »
I looked in the east and west handbooks and couldn’t find any practical info on this.
In an attempt to stuff 100 lbs of iron in a 50 lb footprint I run out of room fast, and going vertical is not really possible. Maybe I’m over thinking this but before I start the layout and bolt things down I would like to know my options.
The plate is 2kW, and the mod is 5ooW. They are both E I cores and I plan to keep the cores parallel to each other as viewed from the top. Also I am planning to keep the mod transformer away from the steel sides and back door of the rack cabinet. (noise)
Any suggestions on the mounting distance between the plate and modulation transformers?  My concern is coupling between the two.
Best Regards
Ted / KC9LKE
« Reply #1 on: August 04, 2011, 04:22:17 PM »
Many BC rigs, obviously concerned with noise & hum, mount them within 12" of each other.  Even open frame jobs like Electro Engineering & RCA.
They also set them 90 degrees, core to core, to stave off mutual coupling.
I'd go that paradigm and not worry.  If you do have a bit of hum outside ripple, try a bit of global rectified FB from RF to audio input.
I QSY'd to QRZ
« Reply #2 on: August 04, 2011, 06:01:44 PM »
you could always wrap a tranny in mu-metal.
« Reply #3 on: August 04, 2011, 06:05:31 PM »
Or fire up the plate transformer into a load, which could be an RF final running a steady carrier into a dummy load or even a real antenna, or load the transformer with a bank of resistors that will pull the rated current through the transformer at the rated voltage.  Then set the modulation transformer near the plate transformer, in approximately the same physical relationship as they  would be in the rig, and measure the a.c. voltage that appears across the mod transformer windings. If any measured induced a.c. is no more than a couple of percent of the total plate voltage, I wouldn't worry about it.  Try orienting the mod transformer for minimum coupling at the given distance (you will probably find a null point), note the orientation and mount the transformers with the same relative orientation in the actual rig.
I have used the same method for orienting RF coils in a multi-stage transmitter for minimum mutual coupling.
« Reply #4 on: August 04, 2011, 09:53:16 PM »
You can mount iron on the sides of a rack cabinet ....if it is strong enough...I have a transmitter with 20 v mod iron and mod choke mounted on the sides of the rack...one on each side ...above the floor mounted HV iron..
WB6NVH
« Reply #5 on: August 04, 2011, 10:21:55 PM »
As W7TFO says above, I was always taught to mount them at 90 Degrees to each other to prevent stray coupling when they are not the shielded kind.
Geoff Fors
Monterey, California
« Reply #6 on: August 04, 2011, 11:02:41 PM »
Actually, I never heard of a problem of stray coupling with high level transformers. Usually this is a problem associated with low level transformers, such microphone input. But still, I would take precautions like orienting the cores of closely spaced transformers 90° from each other, and keeping them as far apart as possible in the space available.
KC9LKE
« Reply #7 on: August 05, 2011, 02:18:16 PM »
Thanks all for the info.
Since I plan to load the plate supply and give it a workout before I go any further that will be the perfect time to verify mutual coupling.  90 degrees as far apart as possible is what I’ll shoot for but it will be a learning experience with load on the plate supply.  I do plan to keep the iron away from the back door, it doesn’t close very tight.  The sound of a Johnson 500 power supply when keyed is what I’m also trying to avoid.  So great, I’ll move on and give it a try.
Thanks again
Best Regards
Ted / KC9LKE
« Reply #8 on: August 06, 2011, 09:49:19 AM »
I would think a well grounded steel plate would eliminate coupling. Or hammer out a mumetal shield from an old scope.
Tom WA3KLR
« Reply #9 on: August 06, 2011, 10:25:25 AM »
A grounded steel plate is just an electrostatic shield and won't do any good for this situation.
« Reply #10 on: August 06, 2011, 12:46:51 PM »
It will ruin mu-metal to hammer it. Warning decals are posted on some scope tube shields against even letting it drop to the floor.
In their later transformers, UTC cast the cases of their top-of-the-line products with some kind of proprietary material called Hypermalloy that is supposed to make superior magnetic shielding. Interestingly, it is not attracted by a magnet. Light in weight and looks kind of like pewter or nickel.
But I agree that it would be an exercise in futility to try to place a magnetic shield between two transformers.  Better to space them as far apart as possible and experiment with orientation.
KA3ZLR
« Reply #11 on: August 06, 2011, 01:16:25 PM »
Hi,
Keep them Perpendicular of one another.
Jack
KA3ZLR
« Reply #12 on: August 06, 2011, 05:35:16 PM »
In most homebrew transmitters, is coupling really a problem??  In some engineer designed rigs, it doesn't seem like any thought was given to coupling issues...I see where it might be a problem but seldom is...
KE6DF
« Reply #13 on: August 06, 2011, 07:41:52 PM »
At the high level signals modulation transformer work at, it would seem unlikely you would get enough coupling to matter.
For a mod transformer operating at 2KV, even 20 volts of induced 60hz signal would only be one percent.
Now if you are talking about coupling between a power transformer and a microphone input transformer then even a millivolt would be a big enough signal to matter by the time it goes through several stages of amplification.
I wonder if anyone here has ever seen coupling between a power transformer and a large modulation transformer become a problem.
WB6NVH
« Reply #14 on: August 06, 2011, 08:02:43 PM »
I was thinking about a mic input transformer up above.  Seems logical that a high level transformer wouldn't have that consideration.  Probably pretty hard to go wrong with those no matter what you do...
Geoff Fors
