May 04, 2024, 12:36:01 PM *
Author Topic: Twin lead Marconi to the rescue  (Read 3936 times)
N6YW
« on: July 17, 2011, 10:54:28 AM »
This was sent to me by my friend Jim K6SXD. It may be the only way I will get my station
on 160.
http://k1ypp.home.comcast.net/~k1ypp/160MAN_D-MSword.html
"Life is too short for QRP"
ve6pg
« Reply #1 on: July 17, 2011, 03:19:59 PM »
..this makes no sense...if you have the space for 125-130ft of  wire, just run 1/4 wave on 160 (125ft) feed it with coax, and attach a ground system to the ground side...i see no advantage to this...and this is not a marconi anyway...
..tim..
..sk.
W0BTU
« Reply #2 on: July 17, 2011, 05:21:13 PM »
Tim is correct. Just put up an inverted-L and a lay down some radials.
http://www.w0btu.com/Optimum_number_of_ground_radials_vs_radial_length.html
http://www.w0btu.com/160_meters.html
73 Mike
www.w0btu.com
« Reply #3 on: July 17, 2011, 09:04:12 PM »
..tim..
..sk.
  The antenna as shown was in an old Bill Orr book. So increasing the feedpoint impedance 4X over a just a wire antenna of the same length would decrease the ground current 2X. That is a 6DB decrease in ground loss in my book, and when the Z with a single wire is low, like 10-15 ohms, doing the 4X impedance transformation gets you up near 50 ohms. I guess this is like 1/2 a folded dipole.
YMMV.
Oh, an antenna that is a DC short has some advantages as well over the single "floating" wire antenna.
Page created in 0.096 seconds with 18 queries.
