March 11, 2026, 04:41:33 PM *
Author Topic: DRAKE TR-4C  (Read 4362 times)
AE1CT
« on: June 23, 2011, 10:43:48 PM »
DOES ANYONE KNOW HOW MUCH POWER THE DRAKE TR-4C PUTS OUT ON AM? I HAVE A CHANCE TO GET ONE AND WOULD LIKE TO KNOW IF IT WILL WORK FOR ME ON AM. I KNOW IT DOES 150 WATTS ON SSB AND 130 WATTS ON CW BUT DONT KNOW ABOUT AM POWER OUT.
Jim KF2SY
« Reply #1 on: June 24, 2011, 12:21:45 AM »
My TR4CW/RIT does about 12 watts resting carrier with no modulation.  When you talk, the controlled carrier goes up to about 40 watts carrier (about 160 Watts pep).  Hope this helps.
« Reply #2 on: June 24, 2011, 11:11:28 AM »
It transmits only one sideband on AM which is generally not a problem.  However if the station in contact with you has his receiver set up to receive only one sideband that will be an issue.  I have run into this a couple of times as a net control operator when I select one sideband on AM receive to avoid QRM above or below.  In most operation this will rarely be an issue.
The controlled carrier system used by the Drake 4 line works very well with linear amps designed for SSB and many can be used at their full SSB rating with this system.
« Reply #3 on: June 24, 2011, 11:28:52 AM »
http://www.amwindow.org/tech/htm/t4.htm
Here's some simple mods to make the T-4 Drake line sound FB on AM.  (Seven simple steps)
I have personally done the T-4X and understand that the TR3/4 models use basically the same circuitry for AM.
Take out your schematic and see if it applies to your TR4-C.  The fidelity obtained with these mods is well worth the effort.
Tom, K1JJ
