I am charging up the battery on my camera. I will add a picture of the actual oscilloscope waveform (associated with the shortened connecting leads... but still showing a reduced level of the effect) to my original post... a little later today
Patrick
Thanks for pointing out my error (50kHz => 50MHz). I corrected my original post. I'm using a doorknob capacitor that I purchased from a fellow in the Ukraine:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=400208024169&ssPageName=STRK:MEWNX:ITThe capacitor may have some inductance... but when I cut the length of the connecting wires approximately in half... the frequency of the superimposed parasitic sine wave went up by a factor of 2 (from 14 cycles per period of the fundamental frequency to 28 cycles per period of the fundamental frequency)... and its amplitude went down. Also, having shortened the connecting wires, the parasitic sine wave now seems to be attenuating noticibly during the flat part of the fundamental frequency cycle of the Drain-to-Source voltage waveform. I'm going to try shortening the interconnecting leads even more. Based on this, I think the interconnecting leads are/were the problem.
